Old 07-23-2008, 08:33 AM   #1
attitude
Member#: 52043
04 sti
Default who has phuzion & titan ics headgaset experience?
my regular cometic failed on my last build, gonna be running much boost. any opinions?
attitude is offline   Reply With Quote
Old 07-23-2008, 09:48 AM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
what was the head and block RA and headstud (or did you use factorybolts) torque procedures on the last build?...
also can you describe the failure? as I doubt the gasket was the issue.
Old 07-23-2008, 12:56 PM   #3
attitude
Member#: 52043
04 sti
50 RA as suggested by Cometic, ARP headstuds, torquing specs recommended by ARP & subaru manual sequence. did i do something wrong? i managed 13,000 miles with a T67 25G @ 25-30 psi before the thing started using coolant.
anyways, any info on either one of the gaskets?
Old 07-23-2008, 02:18 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
arp and subaru have a different spec....that's the main question is who's did you follow?
I've heard great things from the phuzions but have no first hand experience on them.
Old 07-23-2008, 03:27 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
I know Cometic doesn't reccommend backing off in the torquing sequence....so you have issues on whos directions to follow. Since it's the gaskets you're worried about keeping a seal on, I would go by their directions.
I don't know if Cometic has a Fuzion application for the Subies yet, but I can find out.
Jay Storm
Old 07-23-2008, 06:03 PM   #6
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I thought we wanted <20 RA finish?
modaddict is offline   Reply With Quote
Old 07-23-2008, 06:25 PM   #7
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
That's what I said Cosworth wanted in another thread.
methaddict is offline   Reply With Quote
Old 07-23-2008, 07:03 PM   #8
attitude
Member#: 52043
04 sti
what i meant by that was ARP's torque amount, and subaru's order
and cometic calls for 50. look on their website right now
Old 07-24-2008, 02:22 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
yes, cometic calls for 50 as a minimum...doesn't mean that its the best. The more pressure you run, the better a sealing surface you should naturally want to have!
Old 07-24-2008, 02:49 PM   #10
attitude
Member#: 52043
04 sti
god, quit hating on me. since i got no help here, i'm going to use cosworth....
Old 07-24-2008, 03:13 PM   #11
jays05
Member#: 78165
05 STI 35r + e85
I don't see any hating in this thread at all.
I had a HG failure using ARP studs and OEM gaskets and did a lot of research on HG failures. Seems that many failures are caused by a poor sealing surface (heads not resurfaced, warped, or RA too rough), or by the head stud installation procedure... and most if not all of the major suby engine builders are using a different install procedure than what ARP recommends.
jays05 is offline   Reply With Quote
Old 07-24-2008, 05:27 PM   #12
modaddict
Member#: 95840
sold to a good bud
awaiting next car
why are you so turned off to the OEM gaskets?
Old 07-24-2008, 08:55 PM   #13
Homemade WRX
Member#: 33782
96 bastard child
I think you are confusing input and legitimate questions with hate...
didn't mean to step on any toes...
Old 07-24-2008, 09:09 PM   #14
attitude
Member#: 52043
04 sti
i was just kidding on the hate. just wanted some input on real world head gasket shiz
Old 07-24-2008, 09:11 PM   #15
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
I will help you out if you can afford them buy the ics titans,I haave had great success with them and have a few cars with them makind well over 600whp.If you get on sce's site they will explain the weaknesses of the mls gaskets.I have also talked to ARP and they told me the torque spec(72lbs) they send with the studs is only 75% of the studs yeild so they told me I could increase the maximum torque spec if I wanted to so I run mine up to 85lbs and after I torque it I go back thru and back off everythig and torque it all back down again so the gskt gets prestressed and squished since we cant really retorque it in the car like an evo.
john 1badSTI is offline   Reply With Quote
Old 07-24-2008, 09:13 PM   #16
attitude
Member#: 52043
04 sti
i was told to recheck the ics's often because they could distort over time
Old 07-24-2008, 09:25 PM   #17
john 1badSTI
Member#: 77470
What do you mean by distort--the ics gskts have a built in fire ring,sce told me that the gskts would hold to 50psi no problem-- also i would see a gskt with multiple layers more prone to distorting and leaking between the layers.If you look on sce's site you will see a pic of the ics gskts and how they would keep the combustion chamber sealed even if the head started to lift.Its up to you to read the facts and make your decision but true world results speak for themself and I can honestly say that a lot of the so-called experts on the forums have no practical experience just what they read and give advice. I'm just trying to offer you my knowledge and experience in this application to help you make the best choice. good luck,john schroeck pronounced shreck
Old 07-24-2008, 10:27 PM   #18
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
ICS Titan ---> nothing for the EJ22T
Kosmic is offline   Reply With Quote
Old 07-24-2008, 10:54 PM   #19
john 1badSTI
Member#: 77470
did you call or e-mail them they may not list it but may make it .
Old 07-25-2008, 04:25 AM   #20
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
I emailed them twice about ej22t gaskets and never got a reply back.
speed_freak27 is offline   Reply With Quote
Old 07-25-2008, 07:00 PM   #21
bjm
Member#: 87090
Jay Storm
It seems you can already buy Phuzion gaskets for the EJ257...
Click me for EJ257 Phuzion Gaskets
But the question still remains... which is better ICS Titan or Phuzion???
bjm is offline   Reply With Quote
Old 07-27-2008, 03:06 PM   #22
attitude
Member#: 52043
04 sti
still no answer bump
Old 07-28-2008, 12:04 AM   #23
Storm
Member#: 5218
96L Most Over-
Developed Beater
I know that the fuzion was developed with alot of input from the R&D on turbo diesel applications at over 60psi.
garrett gt3076r rotated location .63 hotside & SCE ics titan copper head gaskets toyjunkie Engine/Power/Exhaust 17 04-03-2010 02:33 AM
('93-'01) Who has experience with Paradise detailiers bryanw Impreza Forum 0 05-07-2001 01:52 PM
('93-'01) Who has had experience with SubaruParts.com? kaos200 Impreza Forum 4 04-16-2001 11:31 AM
Who has experience programing DSBCs or ellectronic boost controllers? DeliciouSpeed Bay Area Impreza Club Forum -- BAIC 1 03-28-2001 11:15 AM
Big brakes, who has them & how well do they work? MD20 General Forum Archive 1 06-16-2000 07:26 PM
