Old 07-23-2008, 12:41 PM   #1
nethngbtstk
Member#: 184748
2008 STi
Default Just got back from Subi service, no help from them
I posted my issue in the Suspension thread but didn't get to much help so I made an appointment with Subaru. I just picked up an 06 WRX and its ridding on Cobb springs. it definitely has the rear clunk which I thought was the struts. Subaru looked at them and there fine. Other then suggesting new springs they didn't really help. I guess i could but i doubt that will fix it. Now I have used the search here and there are allot of possible solutions. I just would like to hear from someone who really knows first hand what i cant do to fix this.
Sorry for the long story, just need some help.
Thanks
nethngbtstk is offline   Reply With Quote
Old 07-23-2008, 12:53 PM   #2
big16gwrx
Member#: 129459
check to make sure your endlinks are tight... it could also be the rear diff smacking around.... when does your car make the clunk....
big16gwrx is offline   Reply With Quote
Old 07-23-2008, 01:06 PM   #3
nethngbtstk
Member#: 184748
2008 STi
When they had the car on the lift i was under there with them and everything looked really good. I felt the end links by hand and there weren't loose but idk if thats a fair test. The clunk happens on any bump or uneven pavement. it sounds almost like a hollow clunk and its coming from the right rear. Again there suggestions were maybe somethings not seated right or the springs are hitting something. But nothing looked out of place. All i know is its driving me nuts.
Old 07-23-2008, 02:58 PM   #4
Super_HKS
Member#: 154434
2009 WRX Hatch <@_@>
My guess would be rear diff issues. WIth my girlfriends 2000 legacy GT the CV joint is either bad or needs grease because when turning at a slow rate of speed, it clunks around
Super_HKS is offline   Reply With Quote
Old 07-23-2008, 04:33 PM   #5
CynicX
Member#: 48199
06 WRX
Can you open the trunk and kneel in it and bounce around to simulate the clunk? Then my next question is do you have a friend that can pin point it or do the bouncing?
CynicX is offline   Reply With Quote
Old 07-23-2008, 05:00 PM   #6
nethngbtstk
Member#: 184748
2008 STi
At the dealer this morning we were bouncing the back and the no clunk. i was thinking maybe side to side but i doubt it. I talked to the tech line at Cobb and they gave me a few suggestions. Gonna check all the bolts and if thats not it I'm just going to have to take the strut out and see what i find. Sucks.
Old 07-23-2008, 05:30 PM   #7
stoney curtis
Member#: 185238
2005 sti
black
i had a clunk from my right rear , when i brought it to the dealer they said it was normal, but it sure didnt sound normal. i made a pest of myself and they replaced the strut under warrantee and that solved the problem. things i also checked were the spare tire, the wing mounts , and anything els back there that could work loose and clunk aroundwhen i hit a bump
stoney curtis is offline   Reply With Quote
Old 07-23-2008, 11:41 PM   #8
mannac
Member#: 161038
2005 LGT
'72 Datsun 240Z
I had/have a similar problem. Your exhaust might be hitting the rear sway bar. It sounds similar to the strut clunk but a tad different. I've been through both of those scenarios
mannac is offline   Reply With Quote
Old 07-23-2008, 11:49 PM   #9
SpooksRex
Member#: 141863
04 Forester XT
if you have a stock exhaust, then maybe that's not the problem.
i tightened the piss out of my endlinks on my cobb rear sway bar when i first installed it, and i started getting a 'clunk' problem and my mechanic buddy said it was a bad strut. tightened the sway bar on the passenger side a hair more and haven't heard it since.
just my .02 cents
SpooksRex is offline   Reply With Quote
Old 07-23-2008, 11:54 PM   #10
thunder_lizard_1976
Member#: 145642
2007 WRX Ltd
Cuz Chicks Dig The Wagon
Did you take the tech for a ride in the car with you, and point out the noise? Often times a good tech will hear a noise, and know right where to look (then again, this is the Subaru dealership we're talkin about here). IMO, if it's only over bumps, it has to be in the suspension.. possibly a broken/ worn strut.. or something with the new springs (not seated right.. too short for struts). When/ how did the noise start?.... was it right after you installed the springs, or some other event?
thunder_lizard_1976 is offline   Reply With Quote
Old 07-24-2008, 11:13 AM   #11
nethngbtstk
Member#: 184748
2008 STi
Yes i took the tech for a ride and he heard it right away. He put it on the lift and said the struts are fine, no leaks and are still perfectly firm. Other then scratching his head he didn't really know. Yeah it only happens over bumps or uneven pavement where the suspension is moving. After a day or reading and talking to people this weekends project is...
Check the end links on the sway bar.
Check sway bar clearance.
Check the springs to see if the powder coating is coming off indicating the springs are rubbing.
Check top nut assembly.
Check the top hat .
Take strut out and check for damages.
Disconnect sway bar and test drive.
Disconnect strut bar and test drive.
Oh and install new Borla hush exhaust
If that doesn't fix it I give up.
So I just got back from the VW dealership, and have to go back tomorrow... Layman Off-Topic 41 03-23-2006 05:23 PM
Just got back from a 50 mile test drive of my MRT header back system. scootr Normally Aspirated Powertrain 1 06-12-2001 09:57 AM
('93-'01) Just got back from www.importstreetscene.com @GMU WRX4me Impreza Forum 2 06-09-2001 07:20 PM
Just got back from TSD RallyeX Southern California Impreza Club Forum -- SCIC 6 06-02-2001 11:22 AM
Just got back from Lebanon Valley... Camaroman New England Impreza Club Forum -- NESIC 7 10-17-2000 05:28 AM
