Old 07-23-2008, 06:04 PM   #1
wychk99
Member#: 124326
2007 STI
Default Direzza Sport Z1 Star Spec Fitment Questions
I have a 07 sti with RCE Yellow and Ohlins Struts. I m interested in Direzza Sport Z1 Star Spec in 245/40/17 to go with my stock rims, but I saw many post saying these tires are much wider than other 245's. Will I have fitment issues? I m still thinking should i pay like $200 more to get a set of RE-01R instead? Thanks.
wychk99 is offline   Reply With Quote
Old 07-24-2008, 10:23 AM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
no you won't have fitment issues. i'm on 255/35/18s with rce yellows with no rubbing on the rolled rear fenders. 05+ have more room in the rear.
Old 07-24-2008, 11:11 AM   #3
2superblus
Member#: 33526
2013 WRB W/Gold BRZ
08 STI WRB w/Gold, 02 WRX
Good luck finding the Star specs though.
2superblus is offline   Reply With Quote
Old 07-25-2008, 02:40 PM   #4
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
OP,
a 245/40/17 will work nicely on the stock wheels with your setup.
either RE01R or StarSpec.
05's have more room stock to stock, but a rolled 04 has significantly more room than an 05.
-T3h_Clap
WRX8XB is offline   Reply With Quote
Old 07-26-2008, 12:37 AM   #5
indolegend89
Member#: 139849
2011 STi
im thinking about running these as well, where, besides tire rack can these be bought from?
indolegend89 is offline   Reply With Quote
Old 07-26-2008, 09:50 AM   #6
JohnST2k6k
Member#: 178465
2006 WRB STI
Precision Built and Tuned
No where. I searched high and low for these. Whenever a tire gets comparable rate to a bench mark tire.. and are way cheaper... one of two things happen
A) They sell out nation wide
B) The price is bumped up very quickly
Good luck tire rack said they were getting some in in couple weeks i just went with RE 01r s can not be happier =)
JohnST2k6k is offline   Reply With Quote
Old 07-26-2008, 11:30 AM   #7
purduephigam
Member#: 90500
2005 WRX
I'd like to know if there's any truth to this. I'm considering this tire with some 17x9 for my 2005 wrx. Even with a coilover setup I'd still hope that a "fatter" tire wouldn't be an issue for me.
purduephigam is offline   Reply With Quote
Old 07-27-2008, 12:22 AM   #8
wychk99
Member#: 124326
2007 STI
http://forums.nasioc.com/forums/show...7&postcount=15
i saw the above post and got me worried.
Old 07-29-2008, 08:54 AM   #9
purduephigam
Member#: 90500
2005 WRX
So those of you running 245/40's, what's the "actual" width of your tire? I'm assuming most, if not all should be around the 9inch mark. If the Star Spec is in fact a wider tire, should I drop down to the 234/40? Luke, Tirerack, where ya at on this one? Thanks.
Old 07-30-2008, 04:28 PM   #10
purduephigam
Member#: 90500
2005 WRX
Anyone have any insight on this? I e-mailed Luke, but haven't heard from him. If a standard 245/40 measures ~9" should I think about getting the 235/40 Star Spec? Keep in mind I'll be having a 9" wheel, and I'd like to avoid the "stretched" look. Thanks.
Old 07-30-2008, 04:43 PM   #11
WC LATHE WERKS
Member#: 175549
Buy my SHIFTKNOBS
www.LatheWerks.com
That is my post with the pictures of the tires. All I can tell you is that my 235/45's measure exactly 9.25" wide from sidewall to sidewall using a caliper accurate to 0.001" inches. That converts to exactly 235 mm.
Since the tire curves inwards at the edge, there is about a solid 9.0 inches of meat actually contacting the ground when the car is sitting. This is inflated to 32psi if that matters
WC LATHE WERKS is offline   Reply With Quote
Old 07-30-2008, 05:05 PM   #12
WRX8XB
Member#: 45323
if you put a 235 on a 9" wheel it will looked stretched. 9" wheels when you include the bead are really 10"s wide. so you'll want a tire with a section width near 10"s to get a square side wall. anything narrower will have a stretched look.
what width wheel was this on?
Old 07-30-2008, 05:17 PM   #13
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
I haven't mounted a set of 235/40/18 Z1 Star Spec's on a 9" wheel but here's this tire on a 18x8.5 wheel. The sidewall was pretty much vertical on these and the tire offered some curb protection on the 8.5" wide wheel. I'd say on a 9" wheel it would have a very slightttt stretch, not much though.
Rota SVN 18x8.5 +45 Gun Metallic with 235/40/18 Dunlop Direzza Z1 Star Spec
-Dan
suby_dude is offline   Reply With Quote
Old 07-30-2008, 05:44 PM   #14
purduephigam
Member#: 90500
2005 WRX
-Dan
So would you recommend going with the 235/40 Star Spec, or just going with the 245/40??
Old 08-08-2008, 11:01 AM   #15
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
Any direct front/rear or side views of those tires on the wheel?
It doesn't look stretched at all in the first pic, but a very very slight stretch on the side view.
Magnum626 is offline   Reply With Quote
Old 08-08-2008, 11:20 AM   #16
WC LATHE WERKS
Member#: 175549
Buy my SHIFTKNOBS
www.LatheWerks.com
8" wide
Old 08-08-2008, 07:49 PM   #17
REX8
Member#: 24038
Think you made a typo there. A 9" wheel has exactly 9" from bead to bead. I guess you meant the outer lip?
Old 08-09-2008, 01:10 AM   #18
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
Chris (WC LATHEWERKS) gave the exact width a few posts up...
But for some reference/comparison, my 235 Direzza's are a hair wider than my friends 245 REO1R's...
So, as Chris stated - our 235 Direzza's measure up to exactly 235mm, which must mean that some other tires/brands dont measure up to the size that they should be... Just my $.02
RonJitsu is offline   Reply With Quote
Old 08-09-2008, 10:51 AM   #19
WRX8XB
Member#: 45323
yes, when you include the "lip"
my mistake.
so, you ordered a set of the new Direzza Sport Z1 Star Specs ... please read! [email protected] Tire & Wheel 46 06-23-2009 09:22 PM
Dunlop Direzza Sport Z1 Star Spec, Opinions/Reviews? suby25 Tire & Wheel 112 05-14-2009 06:03 PM
Anyone using these Direzza Sport Z1 Star Spec gtasti Tire & Wheel 9 08-29-2008 10:37 PM
Any local tires shops have Dunlop Direzza Sport Z1 Star Specs in Stock? I_wanna_STI_now Southern California Impreza Club Forum -- SCIC 1 08-02-2008 05:25 PM
