Old 07-23-2008, 11:50 PM   #1
winston856
Member#: 170133
2006 WRX Wagon
Gray
Default Will a Kartboy SS fit in a '95 L ? (pics, 56k)
Hey all I bought a '95 L and I'm going to swap the trans into my '96 GT.
Anyway I've been reading about the kartboy short shifters and how there might be some issues with them fitting older transmissions.
Here's pics of the stock shifting assembly:
I measured the opening the shifter would fit into there, the "barrel" I guess it's called. It's 1" or 2.54cm (25.4mm), does anybody know the dimensions of the one that's for the "97-99" legacies?
winston856 is offline   Reply With Quote
Old 07-24-2008, 01:08 AM   #2
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Originally Posted by winston856 View Post
Hey all I bought a '95 L and I'm going to swap the transmission from it into my '96 GT.
While I don't know anything about kartboy short shifters not working with older manual transmissions, I feel the need to state the obvious here:
The '95 L 2.2 Liter motor with the 5-speed typically has a 3.90:1 Final Drive ratio, whilst the '96-'97 2.5 Liter motors typically run with either a 4.44:1 or 4.10:1 final drive.
On AWD Subarus this final drive ratio is in both the rear differential and in the FRONT differential/transaxle assembly (that is part of the "transmission"). If you swap the Transmission/transaxle from the older vehicle, you should also swap the rear differential, as running with different final drive ratios can cause all sorts of unpleasent problems.
Jonathan is offline   Reply With Quote
Old 07-24-2008, 02:45 AM   #3
winston856
Member#: 170133
2006 WRX Wagon
Gray
Yeah, I have the whole car, I'm going to swap that trans and diffs too so everything matches up.
Sorry, I thought that was implied
What about converting the shift linkage to a newer one that'll fit the kartboy. The linkage in it now is a cable style and the '97+ uses a hydraulic style.
What are my options for shift linkage swaps?
Old 07-24-2008, 01:27 PM   #4
winston856
Member#: 170133
2006 WRX Wagon
Gray
Is the shift linkage from an '02 WRX what I want?
Old 07-24-2008, 11:34 PM   #5
beat22
Member#: 113763
15 sti launch
04 wrx wrb
i have an 04 wrx shift linkage setup in a 2.2 95 L. had to grind opening slightly larger for 1,3,5 shifts =D
beat22 is offline   Reply With Quote
Old 07-25-2008, 07:26 PM   #6
winston856
Member#: 170133
2006 WRX Wagon
Gray
Well it appears the '02 WRX linkage is what works, so I've got one of those on the way
Will the Tein SS fit properly..... ScrambleBoost Brakes, Steering & Suspension 4 01-21-2003 05:28 PM
will theWRX stock turbo fit in MY98RS? Sin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-07-2001 11:34 AM
Will a kartboy shifter work in a 96 L? 96Lconversion Normally Aspirated Powertrain 2 01-18-2001 09:14 AM
How will a 2.5L fit in a 1.8L Bay? Tkacik Technical Forum Archive 8 07-13-2000 01:51 AM
