Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 07-23-2008, 11:50 PM   #1
DemiSlayer
Member#: 120339
02 WRX
Alliance Motor Sports
Default Hydra 2.6. + boost controller ?
going to be running a hydra 2.6. is there any reason to keep my AVCR boost controller? i like the gear specific boost control auto adjustment for waistgate goals etc. Thanks.
DemiSlayer is offline   Reply With Quote
Old 07-24-2008, 02:34 AM   #2
cubuff
Member#: 38345
2004 WRB WRX
I am going to keep my dtec bc when I switch to hydra with my new setup. I think its important if you want to change boost settings on the fly. I for one dont want to plug my laptop in every time I want to turn the boost up/down.
On top of all of this I want to have gear selected boost.
cubuff is offline   Reply With Quote
Old 07-24-2008, 08:03 AM   #3
DemiSlayer
Member#: 120339
02 WRX
Good point. Thanks.
Old 07-28-2008, 05:56 PM   #4
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
The Hydra has gear specific boost control, coolant temp control, air temp control, and TPS control so it's very sophisticated. I'm currently also altering the PWM map used to a 3D map and that has worked great on our 2008 "Street" Time Attack car.
As mentioned the number 1 reason to run a stand-alone boost controller is for on the fly changes to boost levels. On our Unlimited car I like the TurboSmart E-boost 2.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
To anyone using a Hydra 2.6 on a 2.5RS gumby647 Other Engine Management 0 05-20-2009 07:41 AM
Hydra 2.6 Nemesis Brand new with wideband sensor and launch control harness PLATNiUMSTi Engine/Power/Exhaust 11 04-24-2009 05:26 PM
Hydra 2.6 Launch Control anubis328 Other Engine Management 3 10-01-2008 08:19 PM
Two Thumbs UP for Hydra 2.6 and Hydra USA! Dyno Flash Other Engine Management 28 06-15-2008 04:03 AM
Hydra - 2.5RS Boost Control??? Sko Other Engine Management 1 06-15-2006 08:55 AM
