#1 |
Member#: 6140
Vehicle:2002 WRX 5MT Sedan WR Blue. Cobb Stage 2 |
I just completed the 'grounding mod'. Man, what a difference!
My WRX had a bad stumble or hesitation between 4 and 6,000 rpm even when fully warm. After adding several ground wires the stumble is gone! I added 5, 12 gauge, THHN ground wires: one to each strut tower, one to each side of the intake, and one to the firewall. The last 3 are existing factory ground points. All 5 wires terminate at a two-piece solid copper lug on the neg. battery terminal. I used "Copper Shield" anti-oxidant on all connections. Also, I found that the factory ground at the firewall was done over painted metal (lame), so I cleaned that up. I am amazed at the difference this mod made. I was skeptical but figured the cost was minimal and I had nothing to loose. Last edited by sajohnson; 03-11-2002 at 11:35 PM. |
#2 |
Member#: 8282
Vehicle:2002 WRX Sedan |
Okay -- I am skeptical. Where can I get detailed info about this?
#3 |
Member#: 7777
Vehicle:2002 impreza WRX Blaze Yellow |
I would like to know more also
#4 |
Member#: 6140
http://www.i-club.com/forums/showth...threadid=141932
Also see the thread, "Stumble During Acceleration" |
#5 |
Member#: 4402
NESIC
Vehicle:2005 WRX STi(gone) CGM (and missing it) |
link does not work??
T. |
#6 |
Member#: 2918
Vehicle:2002 Impreza WRX Silver Sedan |
#7 |
Guest
Member#:
donrgolf
user name Us Texans actually do have a few tech posts! ![]() |
#8 |
Member#: 862
Just did this mod yesterday as well. Holy S, what a difference!
Here is how we did it, and I will post pics soon. 2 gauge wire from Neg battery terminal to ground distributor block. 8 gauge wire from block to 5 separate ground points. Hesitation is gone, accel surges at low rpms, gone. And for those of you who follow my compaining, my EVC-4 is now functioning properly at all boost and RPM levels. Entire cost of project, $40. Time under the hood, 1-2 hours. One of, if not the best mod I have ever done. Highly recommended, especially for those experiencing accel surges and bucking. Good luck, speed safely. Pete |
#9 |
Member#: 8282
And this works for ALL '02 WRXs, not just chipped cars, right?
#10 |
Member#: 8343
Vehicle:2006 Impreza WRX 1x PS F250 |
Jorge (riftswrx) did this a few months ago as well. www.projectwrx.com has a writeup on it. I've never heard any bad things come from doing this mod to any level of car.
#11 |
Member#: 7958
Vehicle:09 GH B+ |
sajohnson,
As a electrically challenged person (ECP ), I am unfamiliar w/ the acronym THHN when refering to ground wires, could you please explain? Also unfamiliar w/ your 2 piece solid copper lug you mention. What did you use for ends at your contact points?Sorry for all the questions, but an also experience a slight hesitation occasionaly and would like to end it. Thanks in advacne, Big Sky |
#12 |
Member#: 6162
South East
Vehicle:2002 WRX MBP, 1st WRX Ever in FL. |
THHN is the stiff, solid core wires used in home wiring. It's cheap, and can be had at most any home improvement store. Watch the jacketing on heat sources, it doesn't like heat. I have a 1000 foot spool in my car room as we speak
#13 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
THHN = Thermoplastic High Heat Nylon
It refers to the insulation on the wire, which is spec'ed to 90 C. It's mostly used by builders and such. Most silicone insulated welding wire is also spec'ed to 90 C. |
#14 |
Member#: 8571
Vehicle:2002 wrx |
there's probably a wide range of wire you can use...
I used 10 gauge primary (stranded) automotive wire and soldered and crimped ring connnectors |
#15 |
Member#: 3928
Vehicle:2002 WRX sedan WRB use to be MBP |
i did this mod today. i used 8 gauge audio wire crimped to terminal connectors. my mods are mbc, intake, and exhaust. i dind't notice much, i did experience though that it was easier to take off from a stop in 2nd gear and i can shift to fifth at 38mph or above and not get vibrations instead of 40mph and above. but the weather could have played a roll.
dennis |
#16 |
Member#: 13726
Vehicle:2002 WRX - 264 AWHP ION-Turbo&LINK 12.83@106 |
You wouldn't have noticed anything if you didn't have a problem to begin with. This is not a performance mod and you will not notice better starts. What you may have noticed is better performance due to resetting your ecu.
It only fixes a problem with a mild hesitation while accelerating throught 3-5K rpm. If you are having problems with a slight jerk at 3-5K rpm do this mod. It works... fixed me anyway. -Jonathan |
#17 |
Member#: 6140
The THHN I used is stranded and gas and oil resistant.
The insulation would be more important if we were running +12 volt supply wiring. From a safety standpoint since these are Neg. (-) ground wires, they could be bare. From a funtional standpoint though, bare wire might be problematic because any place the wire came in contact with metal would become a potential ground point. |
#18 |
Member#: 5796
Vehicle:2007 STI, 07 Tundra 99RS |
one far out crazy question about this. they say if you get struck by lightning that it will ground out threw your rubber to the ground. is this going to help or hurt this cause? weird, wild, question just was thinkin bout this.........
#19 |
Member#: 11049
Vehicle:02 WRX, BLACK WAG Somewhere around stage 4 |
Rubber is an insulator, the lightning will not ground out through the tires.
If lightning hits your car it will travel on the outside of the car's 'shell' of an metal enclosure. Goodies learned from the Boston Museum of Science. |
#20 |
Member#: 5796
thanks PDG.....good good good.........
#21 |
Member#: 6140
Well there's one less thing to worry about!
#22 |
Member#: 5118
here is my story...
my car was "surging" a bit at low partial throttle in the 3-5K RPM range... I am not in this range very often without being near WOT, so I hardly ever noticed it, but every once in a while... when I read about this "miracle mod", I went out and purposefully searched for the surging... after a bit, I found that I could produce it in a very repeatable manner... 3200 RPM, low throttle, mild acceleration - I would get a surging not unlike feathering the throttle... I have done an ECU reset since noticing this issue, and it had no effect, so I decided to give this mod a shot and see what effect it had... I didn't want to run 5 wires without knowing that I really needed to, so I started with a single 8gauge woven cable from a local stereo shop that I cut to length and crimped on eyelets... I connected this wire from the bolt through the negative ground cable on the battery, to the drivers side ground bolt on top of the manifold on the engine... I then went out for a test run... there was a noticeable improvement - the surging still there, but much more faint, almost imperceptible... I then made a second cable and ran it from one of the passenger side strut top mount bolts to the passenger side manifold ground bolt... went for a second test run: GONE!!! all traces of the surging gone, I worked really hard at trying to reproduce any surging, and could not under any condition... I'm going to drive for a few more days and make sure I don't suffer any additional surges... after that, I think I'll remove the wires and see if it comes back (tho I'm almost afraid to)... just a bit more information for everyone to think about... I do not have any better idea about what this does, other than good grounding is a good thing, but it made a marked improvement in my car... Paul |
#23 |
Member#: 862
Hey Paul
I had a similiar experience, but unfortunately and came back and went away again, and now its back. That leads me to believe that this is the way in which to fix the problem, now I have to just isolate exactly where the problem is stemming from pay special attention to grounding that. I will keep everyone up to date as this progresses. Good luck Pete |
#24 |
Member#: 5118
well maybe I won't "unground" for the sake of science... LOL
please keep me in mind when you do figure out what worked... |
#25 |
Member#: 6140
Whatever gauge wire you use and wherever you decide to add extra grounds make sure you use some type of conductive inhibitor. Try these links:
http://tnbsun4.tnb.com:8080/tnbcat/t...alog_home_page http://tnbsun4.tnb.com:8080/tnbcat/t...ch_indic_flg=T If they don't work, I used Thomas and Betts Kopr-Shield (P/N CP8-TB). Their site is www.tnb.com |
