Old 07-24-2008, 05:55 PM   #1
saintluciascooby
Member#: 109527
1997 GC8 [email protected]
blue
Default coolant pipe blocking
There are two pipes that go from the water pump to on top of the block one feeds the turbo the other feeds the heater and returns to the crossover pipe. I want to block the coolant pipe to the heater as I am using the return port on the crossover pipe for a sender are there any problems blocking this pipe?.
Jon
saintluciascooby is offline   Reply With Quote
Old 07-25-2008, 12:24 AM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
This was from my thread.... I think this is what you want to do, I did it, no issues.
Below is a picture of the stock cooling circuits, the oil cooler is #8 in the picture. Notice that the LH side of the block, 12,13 & 14 do not have the oil cooler pass through. This is why I think I can just block them off?
To make it easier for you to see what I mean, this is what the coolant circuit will look like after the removal of the oil cooler and the blocking of the coolant passages.
Remember that I no longer have the stock oil cooler installed so this coolant passage really would just be a pass through IMO and does nothing?? Agree ??
mick_the_ginge is offline   Reply With Quote
Old 07-25-2008, 10:05 AM   #3
dunk
Member#: 15359
If you want a clean way to block off that line, you can take a punch and remove the steel nipple that's pretted into the water pump housing. Then take a 1/2 NPT tap and insert a brass plug. This can be done without removing anything from the car.
Here's a picture.
Duncan
dunk is offline   Reply With Quote
Old 12-10-2011, 07:42 PM   #4
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
edit never mind
No Limit Motorsport is offline   Reply With Quote
PN for the oring-gasket that goes between the upper coolant pipe and the block? 240sxguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-14-2009 12:34 PM
FS: PS Pump, Y-Pipe, STi Pedal, Coolant Pipe beaviscih Engine/Power/Exhaust 7 09-13-2008 08:23 PM
Coolant pipe going into heater core and out to other coolant pipe: Safe to block off? caterpill Service & Maintenance 4 06-05-2006 12:19 PM
Throttle body coolant bypass = blocking flow instead of rerouting? athakur999 General Community 7 04-13-2006 08:33 PM
Do I need to drain coolant in block MY02 WRX? Gethin Service & Maintenance 4 05-11-2004 01:27 PM
