Old 07-24-2008, 08:34 PM   #1
Ekeenan86
Member#: 155493
1999 Legacy Outback
Default Loud Tapping or Clicking Noise From Engine!
I recently heard a loud clicking type tapping noise coming from engine. Its a 2.5l with about 170k miles. The clicking has become more pronounced over time and as you rev it the speed of clicking increases. It sounds like its coming from the left side of the engine. Any ideas here??? Thankss
Ekeenan86 is offline   Reply With Quote
Old 07-24-2008, 09:35 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Any problems with the engine while driving?
My guess is valve lash needs adjustment.
Tim Sanderson is offline   Reply With Quote
Old 07-21-2013, 09:57 PM   #3
AlaskanSubieFan
Member#: 352358
same problem, 1.8l n/a engine, in my 94. 154k miles on it, please help me figure out what it might be, it's predominant on the passenger side.
i'm currently running on 10w30 penzoil, and since it's ticking like that, i added 2 qts of lucas + 20 oz of 80w95 gear lube,
thought it would raise oil preasure and possibly stop the ticking - however that doesn't help in my case. i changed the sparkplugs. Timingbelt, oil pump were changed recently by professional ASE techs.
plz help, thank you!
AlaskanSubieFan is offline   Reply With Quote
Old 07-24-2013, 02:12 PM   #4
pronghornamerica
Member#: 231666
Oil pump changed, eh? Try getting your car up to around 65mph, stopping, and see if you still hear the sound, or try one of those scrubbing pre-oil change oil additives, some sea foam, and run the car for a few miles with it in there while warm. You might have some stuck lifters caused by deposit buildup.
pronghornamerica is offline   Reply With Quote
Old 07-30-2013, 04:05 PM   #5
gbahr
Member#: 363831
2010 Impreza
Default knocking
I have some knocking sound on both sides and it seemed to start right after an oil change. To me it appears that the oil was actually overfilled could this also cause the same knocking problems as mentioned in this post?
gbahr is offline   Reply With Quote
Old 07-30-2013, 08:02 PM   #6
jedz123
Member#: 67083
1993 Impreza L HB
EJ25D swap, 5-speed FWD
Or just drive more and worry less. My old Legacy's lifters would tick occasionly. 240k miles and the motor never had a valve train error. If the oil pressure light isn't on then I'd just drive it. To the member with the 94 impreza, its a 19 year old car its allowed to be noisy. My Miata will have a lifter tick every now and then on a cold morning. I just drive more worry less... Its free and usually effective.
My 2 cents.
jedz123 is offline   Reply With Quote
Old 08-17-2013, 12:06 AM   #7
I'mFineW/Slow
Member#: 260395
2004 Impreza 2.5 RS
My apologies for bumping an old thread but didn't wanna start a new one.
If someone could listen to the video and let me know if my car sounds normal it would be very appreciated.
Loud ticking/tapping noise is more obvious than normal.
Thanks in advance.
http://i1202.photobucket.com/albums/...ps433a8f8d.mp4
I'mFineW/Slow is offline   Reply With Quote
Old 08-17-2013, 12:37 AM   #8
JohnM10
Member#: 244231
2006 Impreza 2.5i 5M
Crystal Grey Metallic
Link doesn't work.
The fuel injectors make noise, but if you have very high mileage, a valve adjustment would help.
JohnM10 is offline   Reply With Quote
Old 08-17-2013, 01:10 AM   #9
I'mFineW/Slow
Member#: 260395
2004 Impreza 2.5 RS
Hmm gotta figure out the link...
That's probably it though. Thank u for the response
Old 08-18-2013, 04:14 PM   #10
Drewbaru2002
Member#: 332254
2002 Impreza 2.5RS
Platinum Silver Metallic
Just a thought, but check the Exhaust Manifold gaskets. I had a 1997 Legacy GT and it was ticking like a tractor during acceleration from 1500-1800 RPMS.
Drewbaru2002 is offline   Reply With Quote
Clicking Noise from engine bay SoobieNoobie89 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 07-31-2010 10:47 PM
HELP, loud clicking noise from front drivers side. ict-wrx Transmission (AT/MT) & Driveline 7 06-22-2009 12:20 AM
Loud Tapping or Clicking Noise From Engine! Ekeenan86 Service & Maintenance 12 11-12-2008 01:20 AM
Loud clicking noise from rear when turning BooniesSTIDriver General Community 34 02-21-2006 12:51 AM
can you help me figure out what i just blew? very loud clicking noise from the diff sideways slut Transmission (AT/MT) & Driveline 3 09-22-2003 12:58 PM
