Old 07-24-2008, 10:36 PM   #1
rollingindiana
Member#: 179102
02 wrxOpensource'd
Default Re used head bolts?
Has anyone ever had a problem re using head bolts on their ej20? I found this thread and Novacivic stated this.
fyi I work at a subaru dealer and in the past 4 years I have done probably at least 50 headgasket replacements and have never once replaced the bolts. you only need to follow the manufacturers procedures for new bolts to do the initial stretch. When reusing them I just torque them to 74 ft/lbs starting with the center bolts and going outwards in a circular pattern. To this day not one has returned with any issues.
If I follow that method should I have a problem? Thanks
rollingindiana is offline   Reply With Quote
Old 07-25-2008, 07:56 AM   #2
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Are you just replacing head gaskets, or building a motor? Either way about $100 for a set of ARP's isn't that much. Especially if building a motor.
DP
DonkeyPunch is offline   Reply With Quote
Old 07-25-2008, 10:07 AM   #3
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Use the factory sequence every time you replace HG's. I think that a bolt that it meant to stretch, doesnt stretch JUST the first time, it will keep stretching until it becomes useless.
If you are truely worried about it, buy a set of oem bolts. If you think you are going to be upping your power level to something reasonably high, get the ARP studs.
~Josh~
Old 07-25-2008, 11:44 AM   #4
Turbo_Mike
Member#: 130276
2004 STi
Rootbeer
I've re-used head bolts 3 and 4 times on different motors, no problems, just followed the factory sequence every time...
Turbo_Mike is offline   Reply With Quote
Old 07-25-2008, 01:16 PM   #5
rollingindiana
Member#: 179102
02 wrxOpensource'd
Alright thanks for all the info.
Old 08-21-2008, 12:25 AM   #6
darbley17
Member#: 187367
05 wrx
white
I've never reused them on a subaru but never had any problems reusing them on american motors
darbley17 is offline   Reply With Quote
Old 08-23-2008, 11:56 PM   #7
charliew
Member#: 125304
Hot rod Subys are not like any other motor when it comes to reliable head gasket sealing that I know of.
charliew is offline   Reply With Quote
Old 08-26-2008, 02:19 PM   #8
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
DP
$100 for ARP headstuds??? I paid like $250 for mine. If you know where to get them for $100 please let us know where
hustleshark206 is online now   Reply With Quote
Old 08-26-2008, 03:20 PM   #9
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
Yes please I found a place I can get them for like $190 I believe...
I Found cheaper:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33617&viewitem=&it em=320280966503&_trksid=p3907.m29
icslowmo is offline   Reply With Quote
Old 08-26-2008, 10:42 PM   #10
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
I Found cheaper:
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29
Alright, alright. Sorry about the price misquote. I wasn't being literal. I was trying to say that when building a motor, my opinion is not to cut corners and re-use head studs. If building, and throwing a few thousand dollars or even more, why re-use factory head studs, and spend maybe a couple hundred dollars on some ARP's, Cobbs, or Cosworth studs. Mine were cheaper as I bought the motor, gaskets, studs, timing belt, etc at the same place, and had the motor swap done there also. I would have to pull up the reciept to get the exact price. I guess to each their own. You can use whatever you want. I am just expressing an opinion about what I would have used.
-Thanks
OEM used head bolts Imaudi Engine/Power/Exhaust 0 09-01-2009 06:23 PM
Re used head bolts... caused head gasket to blow again? brian3676 Normally Aspirated Powertrain 14 05-01-2008 07:00 AM
head bolts on 2.2, re-use or new schrott Normally Aspirated Powertrain 8 02-28-2008 12:48 PM
Re-torquing head bolts RS Paul General Community 2 06-30-2005 02:24 PM
OK to re-use flywheel -> crank bolts? Diz Subaru Conversions 7 12-15-2004 03:09 PM
