Old 07-25-2008, 04:49 AM   #1
MR.Snoopy
Member#: 176543
2000 legacy 2.5gt
rio red
Legacy brake upgrade?
hello
i have a 2000 legacy 2.5 gt limited with a 5spd and i was wondering what are some good brake upgrades? i have heard you can make wrx brakes fit but i haven't found anything that shows me how? will they work or are there better options.
currently my car has DBA cross drilled rotors with hawk brake pads.
thanks- jason
MR.Snoopy is offline   Reply With Quote
Old 07-26-2008, 02:21 AM   #2
Kraziken
Member#: 38629
1999 Legacy GT (STI)
Originally Posted by MR.Snoopy View Post
hello
thanks- jason
I believe your car already has brakes (at least in the rear) that are larger than the stock WRX.
You can put different Impreza brakes up front, but the bottom line is what are your goals? Are you looking for just some better feel in street applications? You didn't list it, but stainless steel lines help quiet a bit.
Larger brakes than what you have do offer better performance, but at a great detriment to your wallet.
Kraziken is offline   Reply With Quote
Old 07-26-2008, 03:42 AM   #3
jamal
Member#: 71875
98 Legacy GT
my wheels fit
this might help:
http://forums.nasioc.com/forums/show....php?t=1265631
some wrx front brackets and rotors would be a simple upgrade.
jamal is offline   Reply With Quote
Old 07-26-2008, 06:59 AM   #4
MR.Snoopy
Member#: 176543
2000 legacy 2.5gt
rio red
thanks for the imput. i don't have stainless steel brake lines yet. but they are on my "to do" list. my goal it to slowly imporve all the aspects of my car as money and time become available.
i figure you should work on the stopping. before you do anything to the motor.
Old 07-27-2008, 07:24 AM   #5
jamal
Member#: 71875
98 Legacy GT
my wheels fit
that mostly comes down to the tires. Then after that the pads, then fluid, then the brake calipers themselves, then the actual diameter of the rotors.
Old 07-27-2008, 04:47 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
When I went to wrx fronts and H-6 rears, along with stainless lines all around, it made a huge difference. IIRC, the legacys didnt get the h-6 rears until 2004, so you still might have the stock wrx sized rear rotors. Cant say for the fronts, but you might have wrx size rotors in front.
But tires make the difference, of course if you have sticky tires and crappy pads, you tend to get yourself into trouble.....when your pads overheat and fade.
~Josh~
Old 07-27-2008, 05:19 PM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
~Josh~
All 00-04 legacy's have the "h6" rear rotors. My 03 has it stock.
02+ GT's seem to have the WRX sized rotors in the front. L's got the smaller 10.7" rotor from 00-04 IIRC.
rougeben83 is offline   Reply With Quote
Old 07-28-2008, 12:14 AM   #8
MR.Snoopy
Member#: 176543
2000 legacy 2.5gt
rio red
guess im gonna have to pull off the wheel and find out what size front rotors i got before i buy the wrx brake stuff. thanks to everybody for there advice. any other sugestions on performance stuff that you have tried that works?
Old 07-28-2008, 12:50 AM   #9
that one legacy
Member#: 103665
you might not have to deal with this, but i had to bleed my brakes like 15 times before they finally started to work right. i've heard other subaru owners complain about the same thing, but it doesn't seem to be a completely universal problem.
also, i have stainless steel brake lines for '02-'07 WRX fitment, snapped on just fine. i don't recall seeing if there was one specifically for a BH legacy, but you should be able to use the WRX lines as well (all that matters is the length).
that one legacy is offline   Reply With Quote
Old 07-28-2008, 01:02 AM   #10
rougeben83
Member#: 115154
2005 Outback XT
White on grey
for the fronts only. The rears require 2 brake lines each.
You need to bleed them in a specific order because of the way the brake line is setup (I think its rf, lr, lf, rr or something like that).
Basically any brake upgrade aside from the pads and lines are similar to the impreza brake upgrades.
Old 07-28-2008, 03:15 AM   #11
that one legacy
Member#: 103665
really? maybe a set of lines for an STi would work then, cause i think they have 2 lines on each as well.
i think you got the order right though, that's definitely important to remember. i think the first 3 times i did it in the wrong order, so maybe that's one reason i had to do it so many times.
Old 07-28-2008, 12:43 PM   #12
iluvdrt
Member#: 46248
82 Brat
Tan
Could he use the WRX 4 pots/2pots. I am doing that (in process waiting on calipers in mail) to my 98? I think they bolt right on since the 4/2's use the same size rotor as the GT (98 WGN).
iluvdrt is offline   Reply With Quote
Old 07-29-2008, 07:04 PM   #13
Kraziken
Member#: 38629
He could, but I would only do it if you can get the 4 pot setup used. The change for the money involved is so minor, I don't think it is worth it. If you are going to buy the 4 pots new, you might as well as look at some Brembo's used from a STI.
Old 07-29-2008, 08:29 PM   #14
iluvdrt
Member#: 46248
82 Brat
Tan
Mine are free w/15k on them. I have heard they are mostly make the pedal feel better and add some bling.
Old 07-29-2008, 10:28 PM   #15
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Only the 4pots are straight bolt-on. I have them on my 03. The 2pots require a caliper adapter (around $200).
Old 07-29-2008, 11:41 PM   #16
jamal
Member#: 71875
98 Legacy GT
my wheels fit
rotors aren't the same.
a 98gt has 276x24mm fronts, 266x10 rears
the 4/2 pots are 294x24 front, 290x18 rear
Brake Supersticky: brake upgrade FAQ, tech in, Brembo info, and other upgrades: Butt Dyno Brakes, Steering & Suspension 28 11-29-2015 12:57 PM
The OFFICIAL Brake Upgrade / Big Brake Kit FAQ ! Butt Dyno Brakes, Steering & Suspension 55 06-10-2015 06:44 AM
FS - MD: - H6 / DBA rear brake upgrade & 04 WRX rear brakes MD04WRX Suspension/Brakes/Handling 10 03-20-2009 03:46 PM
Stainless steel brake lines to match car model or brake upgrade? giantturtle Brakes, Steering & Suspension 7 02-06-2008 10:24 PM
Brake Upgrade or Turbo Upgrade?? Boosted1456 General Community 39 09-10-2006 12:25 PM
