#1 |
Member#: 7482
Vehicle:2011 G37xS White |
I need some quick help from anyone who has installed a greddy ext gauge or equivalent.
Where do you put the 12volt source and ignition wire? please help!
#2 |
Member#: 10216
Vehicle:2002 WRX - WR Blue |
I have the defi pod, so i wired them to the clock harness.
Red wire -> Blue/ red wire Black wire -> Black white -> Orange -> I dont remember those two its been a while but knowing which wire goes to the blue/red should make everything else self expalnitory. Post back if you cant figure it out ill got pop the pod out and look. Chris |
#3 |
Member#: 9008
Vehicle:2002 slvr wrx sedan 07 CBR 600RR |
Behind the radio is a plug that is not plugged into anything. It has a purple wire and an orange wire with white stripe. If you connect your positive to the purple, and your negative to the orange. You will have a guage that lights up when you turn your lights on. Plus it will dim with the rest of your dash.
#4 |
Member#: 7879
Um, I used the illumination wire from that plug to power my Apex boost gauge. It lights up all the way when the parking lights are on. It does not dim at all. I hope this helps someone.
#5 |
Member#: 13726
Vehicle:2002 WRX - 264 AWHP ION-Turbo&LINK 12.83@106 |
EGT Question..
I posted on another thread but I figured I'd pull this one back outta the closet... I have a Greddy EGT guage that I got from Ebay and installed last night. I finally got my car out today to test it and it don't work! I though the 5 wires should be hooked up like this: Red - power constant White - power dimmer Black - Ground Yellow - Probe wire Orange - Probe wire Please correct me if I'm wrong on this! When I turn the car on should the needle jump or anything to tell me it's on? There is a light in the middle that says check under it, and it's lit up orange... what does this mean? |
#6 |
Member#: 346
#7 |
Member#: 9026
From the Greddy instruction manual, here you go:
Red - 12V power line (+) Orange - Ignition line (+) White - Parking light source (+) Black - Ground (-) There's no yellow wire in my gauge or mentioned in their manual. ![]() Edit: My gauge is 52mm, yours may be a 60mm with peak/hold, which might explain the extra wire. ![]() |
#8 |
Member#: 13726
Yep.. these are not the correct directions for my guage. My guage is 60mm.
I have 5 wires, and I'm sure the Orange and Yellow are for the probe, because it had plugs on the end that matched up to the plugs on the probe itself. |
#9 |
Member#: 10730
Vehicle:02 WRX Sportwagon 91 300ZX Twinturbo,StgXII |
From Greddy's website...
| Thread Tools | |
| Display Modes | |
| EGT Gauge wiring question | EJ205rulezall | Electrical & Lighting | 5 | 01-13-2004 12:36 PM |
| Omori EGT gauge wiring | wrxpa | Electrical & Lighting | 3 | 10-09-2003 11:20 PM |
| Greddy EGT Gauge wiring assistance needed | jamz | Factory 2.0L Turbo Powertrain | 5 | 05-06-2002 12:08 AM |
| Need Help with EGT Gauge Wiring | CommandoRabbit | Factory 2.0L Turbo Powertrain | 0 | 07-19-2001 08:45 PM |
