Old 07-25-2008, 12:58 PM   #1
Steel06STI
Member#: 129711
1999 2.5 RS
Default possible turbo oil seal leak?
alright so i am eating a tad bit more oil than i should be ( a quart every+) 500 miles.
Motor: 2000 miles on Cobb pistons eagle rods cosworth bearings, cobb suggested clearance. I did not build this so i cannot verify exact specs.
turbo FP 20g with around 15,000 miles. minor shaft play. (possible oil seals)
There is Normal OIL in PCV's minor exhaust gas in oil fill,
when i floor it, once it hits boost and 5k+rpm there is visible smoke out the tailpipe, its not like a GI Joe cloud, but i can see it, honestly it looks more like fuel (black) then oil (Blue)
Have not done leakdown or compression numbers yet:
i am hoping this is the turbo oil seals as i really dont want to have another motor swap.
Thoughts?
Steel06STI is offline   Reply With Quote
Old 07-26-2008, 09:53 AM   #2
Thursday1999
Member#: 139287
2007 STi
black, Built By HB Speed
bump, anyone?
Thursday1999 is offline   Reply With Quote
Old 07-28-2008, 12:00 AM   #3
jaimejrivera
Member#: 112943
Verify for oil on the turbo compressor output. If there is excessive oil accumulation your turbo seals might be gone. Perform a compression test anyway to double check there is nothing else wrong.
jaimejrivera is offline   Reply With Quote
Old 07-28-2008, 12:14 AM   #4
555ideways
Member#: 36652
I'd go straight to compression test... those symptoms sound like combustion chamber problem. Start at cyl 4.
GL
-Paddy
555ideways is offline   Reply With Quote
my friend had a blown turbo oil seal what will happen ryanpietro General Community 17 04-28-2012 11:33 AM
New axle oil seal leak... *HELP* mtcs Transmission (AT/MT) & Driveline 1 11-02-2009 03:00 PM
turbo oil seal lovemyrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-01-2007 07:37 PM
AFRs dorky after turbo oil seal failure. bcblues Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 10-16-2006 12:23 AM
I think I blew my turbo oil seal... scoobyimprza Normally Aspirated with bolt-on Forced Induction Powertrain 16 11-26-2003 09:19 PM
