Old 07-25-2008, 04:57 PM   #1
Su||y
Member#: 169794
2007 WRX Wagon
Stage Catless
Default So my turbo was on fire last night
Late last night I made a run up decker canyon from PCH. I was going pretty hard until I hit the part with houses. I slowed down and it smelled like something was burning. I kept going for a few more corners to let the brakes cool down and pulled over. Popped the hood and the hotside of my turbo was glowing red. Got back in right away and drove for about 10 minutes to cool it off. I'm thinking maybe it's time to get a better intercooler. Anyways I'm running an SPT intake, Catless Tanabe TBE, and a Cobb AP V2 on Stage II. Also it is untuned and I still have the stock uppipe. I've already made plans to get it tuned but I think I am going to take it easy and wait until I get a different intercooler and a better upipe. But my question is would an sti intercooler be enough to keep things cool under the hood? Is there something else that I am missing? Input would be much appreciated. Thanks.
Su||y is offline   Reply With Quote
Old 07-25-2008, 05:06 PM   #2
ammo0000
Member#: 175401
2007 VF39'd OBP WRX
2008 Blue Kawi ZX-10R
Turbos can glow if driven hard enough. It doesn't necessarily mean something is wrong. My buddy's turbo in his eclipse gst would glow all the time when we took it to the track. He had that thing forever too. One thing to note though, if you're going to push your car to the point of it glowing, you might either want to consider leaving it running for a couple minutes after you park, or get a turbo timer. Also get that tune asap.
ammo0000 is offline   Reply With Quote
Old 07-25-2008, 05:11 PM   #3
Badler
Member#: 133597
You're fine.
Badler is offline   Reply With Quote
Old 07-25-2008, 05:11 PM   #4
drfrink24
Member#: 36369
2004 WRX STi
Java Black
Turbos can and will glow quite a bit. My 1.8T GTI would have a nice orange glow after I got done with some spirited driving.
I think you'll be hard pressed to find anything that would prevent the turbo from glowing red, except for a nice blanket (which just insulates more, less chance for burning, it's still red under there). Pretty sure this is 100% normal.
drfrink24 is offline   Reply With Quote
Old 07-25-2008, 05:13 PM   #5
drfrink24
Member#: 36369
2004 WRX STi
Java Black
Originally Posted by ammo0000 View Post
ff you're going to push your car to the point of it glowing, you might either want to consider leaving it running for a couple minutes after you park, or get a turbo timer.
While it certainly cannot hurt to keep it running, natural convection will draw coolant and let the turbo cool down safely, unlike oil-only turbos.
Old 07-25-2008, 05:39 PM   #6
ammo0000
Member#: 175401
2007 VF39'd OBP WRX
Didn't know that. Good to know.
Old 07-25-2008, 07:15 PM   #7
Spootypuff
NASIOC SUPER Supporter
n00b jesus
Member#: 200000
2012 Wrangler
You're car is fine don't worry. There'es not much difference going to the STi intercooler. If you're going to get it tuned anyway, you might as well get a new tmic.
Spootypuff is offline   Reply With Quote
Old 07-25-2008, 09:59 PM   #8
07HaWkEyE
Member#: 139080
2006 Trailblazer SS
Summit White 6.0L V8
haha you should see the pipes on my motorcycle at night they are "on fire" what you just explained is normal and your turbo was not on fire.
07HaWkEyE is offline   Reply With Quote
Old 07-26-2008, 12:52 AM   #9
asrautox
Member#: 98460
2006 WRX vf43
You could always get an EGT gauge if you want. Mine blinks at me if I hit 1600 degrees. But yeah, glowing red is fine..
asrautox is offline   Reply With Quote
Old 07-26-2008, 02:15 AM   #10
08EJ25
Member#: 174022
2008 WRX
Lightning Red
Perfectly normal.
08EJ25 is offline   Reply With Quote
Old 07-26-2008, 03:39 AM   #11
emo_tactical9
Member#: 135814
95 240sx SE
95 200sx SE-R - 84 200sx
A different intercooler isn't going to keep the turbo from glowing.
emo_tactical9 is offline   Reply With Quote
Old 07-26-2008, 04:20 AM   #12
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
+1, intercoolers only lower intake temps, not exhaust temps, which is causing your turbo to glow. Thats why they make turbo hot sides out of cast steel, they can handle it.
bcWRX-02 is offline   Reply With Quote
Old 07-26-2008, 11:39 AM   #13
Psipwrd
Member#: 102746
1992 Celica GT-4 CS
My talon did it all the time.
Psipwrd is offline   Reply With Quote
Old 07-26-2008, 12:22 PM   #14
SubaruDriver502
Member#: 114182
2003 toyota corolla
RIP wrx, damn u bambi!
my wrx does it all the time in the winter when having fun
SubaruDriver502 is offline   Reply With Quote
Old 07-26-2008, 12:31 PM   #15
caracer22
Member#: 171076
2011 Wrx DGM
STG 2
my buddies manifold and turbo used to glow on his 92 eclipse , it reminded me of ET's heart!
caracer22 is offline   Reply With Quote
Old 07-26-2008, 01:18 PM   #16
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
What where you EGTs?
I'd most likely say you're fine but you're untuned part in your OP threw me. Does that mean you're just running an OTS map or you're running mods without a "tune" at all. I could see that latter leading to elevated EGTs and lean running.
Old 07-27-2008, 05:47 AM   #17
wacerx
Member#: 96075
07 Schwinn
Candy green
not unusual for turbo cars but like said before you dont need a turbo timer. since our cars run coolant through the turbo and the upper coolant tank you are fine (natural convection was mentioned).
and just for kicks: http://www.youtube.com/watch?v=p1qQU...eature=related
wacerx is offline   Reply With Quote
Old 07-27-2008, 07:43 AM   #18
NightHawk
Member#: 175181
not to hijack the thread, but SS autochrome has really cheap intercoolers same size as turboxs tmic.
NightHawk is offline   Reply With Quote
Old 07-27-2008, 07:53 AM   #19
05-rsx
Member#: 101188
MY07 WRX Wagon
05-rsx is offline   Reply With Quote
Old 09-29-2008, 05:50 PM   #20
Derty_sooby
Member#: 172465
2002 wrx
blk/slvr
same thing happened to me last night, took a nice run through my small town, and stopped to pop hood cause i smelt a wierd smell, and my whole turbo and uppipe were glowing bright red,i was like . too bad i left my marshmellows at home. but if ya'll say its normal, than im not going to trip on it, but i should get a egt gauge....
Derty_sooby is offline   Reply With Quote
Old 09-29-2008, 08:36 PM   #21
freezer16801
Member#: 190271
2010 FXT
spark silver metallic
gotta love a nice aircooled V-twin. I have a ducati hypermotard that can reach 250 degrees oil temp. and I've heard over 300! I never made the pipes glow though. Not even on my trackbike.
freezer16801 is offline   Reply With Quote
Old 09-30-2008, 05:37 AM   #22
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
09 triumph daytona 675
Originally Posted by 05-rsx View Post
here is the video of this pic... its pretty sweet..
mannyOlicious is offline   Reply With Quote
Old 09-30-2008, 05:40 AM   #23
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
btw... intercoolers wont help with glowing much because its on the compressor side, not exhaust... also, heat is very good for turbos so not to say that glowing red is awesome but it does help spin that wheel!!!
Old 09-30-2008, 02:48 PM   #24
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Isn't that road fun! I like Latigo Canyon as well, not as well traveled.
slowmike is offline   Reply With Quote
lol so one of my brakes froze on me last night.. Moof General Community 32 12-11-2008 02:41 PM
My baby was broken into last night MKUltra8466 Mid Atlantic Impreza Club -- MAIC 21 07-31-2008 05:28 PM
So, when I was out landscaping last night, I had a strange experience. snvin Off-Topic 18 12-04-2006 02:29 PM
My store was broken into last night..............$10,000 worth of cell phones stolen! L Bo Off-Topic 35 11-27-2005 11:42 PM
My house was on fire last night... Murray Tri-State Area Forum 13 08-23-2003 03:51 AM
