Closed Thread
Old 07-26-2008, 02:27 PM   #1
DS1
Vendor
Member#: 111780
Default Which shifter do you run and does your shift selector seal leak?
Doing a little research to back up a theory of mine.
What I need from you guys is..
Year / Model of car
Shifter brand
Stock linkage or SPT
Seal leaking?
When I talk about the shift selector seal I'm talking about where the shift rod goes inside the transmission.
Thanks guys!
Dylan @ DS1
DS1 is offline
Old 07-29-2008, 03:51 PM   #2
DS1
Vendor
Member#: 111780
Come on guys I'm looking to get some solid info on this.
DS1 is offline
Old 07-29-2008, 04:27 PM   #3
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
I have a 00 RS with 200k miles on it. I have had the kartboy shifter ever since 15k miles. I have never had that seal leak. I have broken shift forks, transfer gears and worn out bearings, but never have broken a gearset. I have had this car to countless autocrosses, trips to the dragstrip and rallycrosses. That seal has never been replaced, but the trans was dissasembled 4 times.
jake
KONKILR is offline
Old 07-29-2008, 04:33 PM   #4
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
We have seen more seals leak with stock shifters than with short shifters.
Phil
AndrewtechAutomotive is offline
Old 07-29-2008, 04:43 PM   #5
DS1
Vendor
Member#: 111780
^^ we see alot of the oppisite
DS1 is offline
Old 07-29-2008, 05:29 PM   #6
Rickyh
Member#: 40453
02 wrx. Kartboy shifter for 4.5 years. Stock linkage. All is well.
Rickyh is online now
Old 07-30-2008, 08:44 AM   #7
saint_foo
Member#: 64364
about 74k miles on my 04 WRX wagon with a short shifter, no issues whatsoever.
The car has seen autoxing and hard driving, a blown 2.0 liter (now running 313whp on a 2.5), and other issues. No tranny-related problems.
saint_foo is offline
Old 07-30-2008, 11:20 AM   #8
DS1
Vendor
Member#: 111780
Thanks guys, this is the kind of info I'm after, I'm looking to see if it's a mechanical thing or a driver thing
DS1 is offline
Old 07-30-2008, 11:28 AM   #9
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
Well Dylan - you've got my car (Bugeye WRX) in the shop. You know that I run a Kartboy short shifter. It had the SPT short throw (gold anodized) from the factory, so it's got the SPT linkage, but it has the stiffer bushings from Kartboy. I've had it in for about 550-750 miles. Put it in just before you rebuild my trans with the RA gears. Does the shift selector seal leak on my car?
(Also - I DO NOT SLAM GEARS. I drive my car very lightly as it hasn't even seen track time with any of the new trans/short shifter setup.)
I also want to make it clear that the reason my trans blew was due to someone else (a local tuner in Chicago) driving my car while it was on the dyno... gear slamming on the dyno will still cause gears to fail evidently.
Also - I am on the Cusco trans mount (only been on for the same amount of time as the trans rebuild.)
Last edited by axelthrasher; 07-30-2008 at 02:21 PM. Reason: On the Cusco trans mount...???
axelthrasher is offline
Old 07-30-2008, 11:29 AM   #10
novacivic
Member#: 117980
2005 sti
wr blue
05 sti. kartboy shifter with upgraded front and rear shift bushings. been on for 20k+ with no issues
novacivic is offline
Old 07-30-2008, 11:35 AM   #11
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
06 wrx kartboy shifter spt linkage 15,000 miles worry free!
06HAWKMAN is offline
Old 07-30-2008, 11:38 AM   #12
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Not sure what shifter part your talking about. I am running the stock shifter with 160k. The shifter shaft going into the trans has oil on it but not exactly leaking. Yet the thread about the center diff I posted on recently. My shifter looks about the same. Until recently I have been a bit scared going with a short shifter because I shift way to hard. After getting bullet shifters for my ppg gears I am not so scared
hybrid gti 2 is offline
Old 07-30-2008, 11:46 AM   #13
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Dylan - I have yet to see this on any of the ones we have or have done here.
Turn in Concepts is offline
Old 07-30-2008, 12:04 PM   #14
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Factory short shifter.
126k miles. Modified heavily for 80k miles, 2nd clutch, not babied in the slightest but well maintained.
All work done by Dan at Andrewtech.
No leaks groans or other problems, ever.
The Phenx is offline
Old 07-30-2008, 01:02 PM   #15
DS1
Vendor
Member#: 111780
Axlethrasher- yours was leaking.
Hmm I'm wondering... could you guys also add what trans mount you are using?
-Dylan
DS1 is offline
Old 07-30-2008, 02:24 PM   #16
axelthrasher
Member#: 144779
-Dylan
The plot thickens... How much lower does the Cusco trans mount make the trans sit than that stock trans mount?
Old 07-30-2008, 03:07 PM   #17
WC LATHE WERKS
Member#: 175549
Buy my SHIFTKNOBS
www.LatheWerks.com
2004 WRX 5MT: SPT gold shifter linkage, stock lever, all TiC/Kartboy shifter bushings, 65,000 miles with some autoX and one HPDE. no seal issues.
2004 STi 6MT (swapped in): Stock linkage, KB lever, all TiC/KB shifter bushings, only a couple hundred miles on it so far. no seal issues.
WC LATHE WERKS is offline
Old 07-30-2008, 03:16 PM   #18
Member#: 99694
2002 dogbox,'11 wrx
If you don't use the washers, the Cusco mount is stock 6-speed mount height. If you use the washers, it's stock 5-speed mount height.
Old 07-30-2008, 03:53 PM   #19
DS1
Vendor
Member#: 111780
Cusco used to make a 5mt specific mount for the GC8. As I understand (as Phil said) the new one is the shorter height with optional washers.
-Dylan @ DS1
DS1 is offline
Old 07-30-2008, 04:12 PM   #20
nxttruck2002
Member#: 90879
I have Cusco engine and tranny mounts sitting in my room. I have an '07 sti that they will be going on. So to have the stock 6-speed high just like from the factory I should not use the spacers, correct?
nxttruck2002 is offline
Old 07-30-2008, 04:18 PM   #21
Member#: 99694
2002 dogbox,'11 wrx
Correct. Not using the washer makes the Cusco mount match the 6-speed mount. You use the washer if you are using the mount with a 5-speed.
Old 07-30-2008, 07:46 PM   #22
KONKILR
Member#: 3190
2004 Impreza TS and
My RS daily driver also has group N mounts.
My race car has a six speed swap with a stock 5 speed tranny mount and stock lever and linkage. No leaks on it either. This vehicle gets the beat down constantly, including many clutchless shifts on a stock six speed. It leaves almost every stop at 6k rpm side stepping the clutch.
jake
KONKILR is offline
Old 07-31-2008, 02:11 AM   #23
DS1
Vendor
Member#: 111780
^^ ouch poor trans
DS1 is offline
Closed Thread
Which DP do you run /w your HKS Carbon Ti? Sube-Doo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 10-24-2009 06:49 PM
Which Oil do you run in your Subie?? timemasheen General Community 2 06-22-2008 11:00 AM
Which kit are you running and your thoughts? jetfan8178 Water/Methanol Injection, Nitrous & Intercooler Cooling 6 09-03-2006 01:27 PM
Which vendor do you refuse to give your business to? Jake Steed Vendor Reviews 97 05-15-2003 06:29 PM
