Old 07-27-2008, 09:31 AM   #1
03wrxtreme
Member#: 119041
2004 Subaru STi
Default #4 piston smoked? 100mm or 99.5mm
Well did a compression test and like so many others my #4 is smoked. Im assuming that the ringlands are cracked like everyone elses. My first question is for everyone with this problem, did you cylinder walls get jacked up. Im not sure if i should go ahead and order 100mm or 99.5s. Is there any cons with going with 100mms. Here is a list of what im getting. Do i need anything else.
CP pistons w rings
Eagle rods
cosworth main and rod bearings
ARP headstuds
Subaru gasket kit
03wrxtreme is offline   Reply With Quote
Old 07-27-2008, 01:13 PM   #2
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
To get the p/w clearances as accurate as possible go with 100mm and have the cylinders bored and honed to the recommended p/w clearance recommended by CP for your application.
methaddict is offline   Reply With Quote
Old 07-27-2008, 02:30 PM   #3
03wrxtreme
Member#: 119041
2004 Subaru STi
Thats what i was thinking too
Old 07-27-2008, 11:53 PM   #4
jaimejrivera
Member#: 112943
I broke #4 ring lands as well. I rebuilt my engine with the exact setup your planning. I did the 99.5 CP pistons. My cylinder walls were ok and I didnt want to mess with my block. I was a bit concern about the machine shop getting it correctly bored.
Any way, the engine is running great and holding tight after 1 year. I doing 380 whp on a conservative tune.
Honestly, if your cylinder walls are ok... go with the stock size. By the way, your knock sensor will be hearing piston slack. I installed a Utec in order to turn down sensibility of the sensor and correct the timing curve. Stock ECU was pulling to much time at 5000 RPM.
Good Luck
jaimejrivera is offline   Reply With Quote
Old 07-28-2008, 12:17 PM   #5
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
100mm would cover all bases as you can always make the bore bigger but if there is significant bore damage the only way to know would be to tear it down, inspect, and measure to see if you can still fit 99.5mm pistons. So to the short answer if you get the 100mm pistons they will work, 99.5mm might work for you. Shorter answer, Ask your builder.
Old 08-04-2008, 08:29 PM   #6
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
With CPs you'd have to go 100mm to get the proper clearance after you hone it so we'd get the block bored/honed for 100mm. We'd be happy to rebuild this for you. Your parts list is our stage 2+ rebuild. PM/Call/E-mail if interested.
-Mike
Innovative Tuning is offline   Reply With Quote
FS: CP Piston & Ring Bore 99.5mm for Subaru EJ255 & 257 2.5L T3H D0C Engine/Power/Exhaust 5 07-12-2010 10:08 AM
WTB: 99.5mm forged pistons.... 74KILLER Private 'Wanted' Classifieds 3 03-09-2007 09:58 PM
WTB: 99.5mm forged pistons.... 74KILLER Private 'Wanted' Classifieds 0 01-22-2007 07:50 AM
99.5mm JE pistons, Coated, Total Seal Ring conversion ImprezaRS dot com Rocky Mountains Impreza Club Forum -- RMIC 17 11-25-2003 02:43 AM
FS: spare new set of coated JE 99.5mm 8.5:1 pistons with Total Seal rings ImprezaRS dot com Private 'For Sale' Classifieds 4 11-02-2003 03:35 PM
