Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 07-27-2008, 02:26 PM   #1
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
Default AFR gauge with Hydra 2.6
I currently have an LC-1 wideband with a prosport wideband AFR gauge.
I have the Hydra 2.6 with the wideband 02 sensor, ready to be installed, but I was wondering if there is a way to still use the AFR gauge with the Hydra wideband sensor?
leonbmx is offline   Reply With Quote
Old 07-28-2008, 06:42 PM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Not many aftermarket gauges are calibrated to report the NTK (NGK) WB sensors unfortunately. Currently the Hydra is AIM Sports Dash compatible so if you wanted a complete system that's optimal as it will report anything that the Hydra. For about $1k it's a really good deal if you are considering 3-4 Defi gauges.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 07-29-2008, 01:05 PM   #3
leonbmx
Member#: 82864
Thanks Phil !
When you say "Not many aftermarket gauges are calibrated to report the NTK (NGK) WB sensors" are you saying that there are some available?
I don't really need a fancy dash like the AIM one, although it looks awesome.
I was just hoping to be able to tap into the right set of wires to get a signal that my prosport gauge can work with.
Old 07-29-2008, 01:58 PM   #4
Element Tuning
Member#: 54918
673 WHP Element
I know NGK makes a WB gauge kit and so does Motec but both are on the pricey side.
Your Prosport gauge is likely calibrated to a Bosch sensor which does not have the same voltage calibration as the NTK sensor. Even within the NTK line the output voltages vary so it can be difficult to use an gauge not specifically designed for a given 02 sensor.
Thanks,
Phil
Old 08-04-2008, 02:56 AM   #5
ddd555
Member#: 183405
Which model of the AIM dash? I tried to google it but its all different.
ddd555 is offline   Reply With Quote
Old 08-04-2008, 05:15 PM   #6
Element Tuning
Member#: 54918
673 WHP Element
The MXL is $1099 and the most affordable option but still packs tons of features and really it just lacks as much on board data logging memory and a few other items that would benefit a professional race team.
Thanks,
Phil
Old 08-25-2008, 06:47 PM   #7
Dom'sGurl
Member#: 150837
2006 Legacy GT
maybe you could set up some sort of input follower or something.
calibrate a 2d map based on voltage/AFR to output a signal that could be equivalent of a 0-5v signal....
maybe?
Dom'sGurl is offline   Reply With Quote
Old 08-25-2008, 07:11 PM   #8
leonbmx
Member#: 82864
I sold the AFR gauge anyways, so the question has lost it's value for me, but for science sake, it is still interresting.
WTB: Hydra 2.6 for 2006 WRX with auto tune blackdub06 Private 'Wanted' Classifieds 0 11-07-2009 01:15 PM
Hydra 2.6 Nemesis Brand new with wideband sensor and launch control harness PLATNiUMSTi Engine/Power/Exhaust 11 04-24-2009 06:26 PM
'05 STI Hydra 2.6 with wideband and acc harness alfriedesq Engine/Power/Exhaust 8 12-12-2008 03:20 AM
Hydra 2.6 with wideband option - 05 STI alfriedesq Engine/Power/Exhaust 3 10-23-2008 01:53 PM
Two Thumbs UP for Hydra 2.6 and Hydra USA! Dyno Flash Other Engine Management 28 06-15-2008 05:03 AM
