Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 07-27-2008, 01:27 PM   #1
hettchen
Member#: 155169
2006 sti fp red alky
awdtuning.com 11.6@119mph
Default crank position sensor cel. tuning in progress please help
just had an axis stage 3 block installed at my local subaru shop in ks. in dallas for tuning right now. the crankshaft position sensor cel is on and as u can imagine our logs are incredibly jumpy. ecu is new and sensor is good. timing marks were dead on at tdc. the subaru dealership spliced all my new wiring harnesses into the old ones. i just need to make this 1 sensor work so the car can be tuned and go bak to ks. And then ima have a lil chat with subaru!!
580 515 7093
robert
thanks
hettchen is offline   Reply With Quote
Old 07-27-2008, 06:15 PM   #2
JSarv
Member#: 163445
l33t *******
12.07@115.9mph-EJ205
Have you tested the feed at the ecu? I'd say there is a bad connection. Is the CPS a 2 or 3 wire sensor. Are the grounds good? CPS sensors are very sensitive to noise, if shielded wire was not used, especially when spliced, they will pick up noise and throw CEL's and do crazy crazy things.
JSarv is offline   Reply With Quote
Old 07-28-2008, 12:03 AM   #3
hettchen
Member#: 155169
ok ok. how about this? not all the wires are spliced but. I did have a perrin lightwieght crank pulley and a 11 pound flywheel installed. I just read Unabombers sticky on the flywheels and it was like textbook. I put my stock pulley back on and there was improvement in my logs. tomorow I will install my stock flywheel.
Old 07-28-2008, 06:14 PM   #4
hettchen
Member#: 155169
got the lightweight flywheel out and stock one back in. didnt fix nothing.
CEL P0123 Throttle Position Sensor/Switch A Circuit High Input help GLD247 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 04-19-2010 11:15 PM
WTB: Crank position sensor PLUG/CONNECTOR and MAF sensor connector IIdiceII Tri-State Area Private Classifieds 3 10-13-2009 06:27 PM
crankshaft position sensor cel. tuning in progress please help hettchen Newbies & FAQs 0 07-27-2008 02:36 PM
Crank Position Sensor Help Kriger Service & Maintenance 3 11-29-2004 11:02 PM
crank position sensor error biggreen96 Normally Aspirated Powertrain 0 06-04-2002 10:43 PM
