Old 03-08-2002, 03:52 AM   #1
OMAHA2.5RS
Member#: 5712
2001 2.5RS 5mt sedan
BRP #22 STS
Default clutch pedal vibration
I have read about clutch shudder and clutch creak and have experienced both to varying degrees. I have only seen a couple of references to a vibration in the clutch pedal. While depressing the clutch i feel a vibration until it's all the way down. It also vibrates as I let it out. The level of vibration is not constant. Sometimes it is much worse than others. I've had clutch shudder when I take off without giving it enough gas. I have clutch creak almost constantly when the car is warm and it feels like it is binding up at the bottom of the pedal travel. I'm taking the car into the dealer Monday morning and I'd like some tips on what to tell them is happening. What do you think is going on?
Thanks in advance...................................Doug
OMAHA2.5RS is offline   Reply With Quote
2009 WRX Clutch Pedal Vibration and Rotational Squeaking Sound Subirex09 Transmission (AT/MT) & Driveline 120 06-03-2013 02:09 PM
Clutch pedal vibration Dave99 Transmission (AT/MT) & Driveline 18 12-10-2010 12:07 PM
Clutch pedal vibration Cinna696 Transmission (AT/MT) & Driveline 0 10-27-2008 11:54 PM
clutch pedal vibration HS WRB-rex Transmission (AT/MT) & Driveline 5 12-28-2002 04:49 AM
new oem clutch -> gas pedal vibrates, any ideas? alexey_s Transmission (AT/MT) & Driveline 2 07-26-2002 08:08 PM
Message Board Statistics All times are GMT -4. The time now is 01:22 AM.
