Old 07-27-2008, 04:52 PM   #1
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Question How bad is running two different Tire Brands (front & back)
I just picked up a set of wheels with some usable tread on them, but the front and back wheels have different tires on them.
They are the same "size" (e.g. 215/45/17), but they are different brands (e.g. Kuhmo & Dunlop), and when put next to each-other there's about 1/4", maybe 1/2", total height difference.
So, the front two are the same height, and the rear two are the same height, but the front two are shorter than the rear two.
Make sense?
Thanks.
Nick
BeBop86 is offline   Reply With Quote
Old 07-27-2008, 04:56 PM   #2
scapone
Member#: 183932
06 wrx
cgm
um from what i understand this is a bad thing. i wouldn't drive around like that if you like having a working car.
scapone is offline   Reply With Quote
Old 07-27-2008, 05:00 PM   #3
Lancer To WRX
Member#: 134266
05 STi
World Rally Blue
Use the same tires all around.
Lancer To WRX is offline   Reply With Quote
Old 07-27-2008, 05:02 PM   #4
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Obviously I'd use the same tires all around if I were the one to have bought the tires, but since that isn't the case...
I'm simply asking if 1/4" would make a significant difference.
Old 07-27-2008, 05:03 PM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Open and read your owner's manual...1/4" is the maximum you can run. If you are foolish enough to run that or great though, you will blow up your center diff.
Old 07-27-2008, 05:43 PM   #6
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
That's 1/4" difference in circumference you can run. 1/4" in diameter = just over 3/4" difference in circumference.
Granted, this is all when the tire in only supporting itself and the wheel, the effective diameter when it's on the car will be different.
Edit: I just checked my owner's manual, and it doesn't give any sort information on what kind of difference in diameter or circumference you can safely run.
Counterfit is online now   Reply With Quote
Old 07-27-2008, 05:57 PM   #7
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
So, even though it's only 1/4" taller, it really has 3/4" more tread "length" (if you were to cut it and lay it flat)?
Old 07-27-2008, 07:20 PM   #8
knockknockknock
Member#: 150915
2007 wrx tr
smurf blue
pi times the diameter, or differance in diameter in this case.
0.25 * 3.14 = 0.78 or a tick over 3/4"
knockknockknock is offline   Reply With Quote
Old 07-28-2008, 10:38 AM   #9
17lyrics
Member#: 185565
Wink
unless youre racing the car or something than just run the tires until you need to replace them and then get the same size. out here in the country, 'if it holds air then run em'
17lyrics is offline   Reply With Quote
Old 07-28-2008, 11:02 AM   #10
paktinat
Member#: 155025
2004 WRX
If you value your center diff you need to run tires that have no difference in circumference greater than 1/4"
like knockknockknock states, if your tires have 1/4" diffrence in diameter, you have over 3/4" difference in circumference
paktinat is offline   Reply With Quote
Old 07-28-2008, 12:16 PM   #11
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
wow, yore a ****ing idiot. read first, then post. work on that k?
The Satch is offline   Reply With Quote
Old 07-28-2008, 02:35 PM   #12
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
I think he was being sarcastic? I dunno...
Old 07-28-2008, 03:00 PM   #13
Domnf15
Member#: 185585
2005 Impreza RS
So is there a definitive answer to the question, any engineers or technicians on here? I'm a computer engineer so mechanics are not my strong point, but I thought the center diff worked in the following way:
If wheel slippage is detected at the front wheels, center diff will send power to rear wheels and vice versa...
If you are running 2 of a kind in the front, and a different 2 of a kind in the rear, how does that translate into wheel slippage and the center diff being affected? I'm not arguing one way or another but I'd really like to know how this works.
Thx.
Domnf15 is offline   Reply With Quote
Old 07-28-2008, 03:07 PM   #14
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
Thx.
Put your car up on a lift or jack stands. Spin one wheel. Notice the other three are spinning. Now think "the center diff is transferring power to the other end of the car!". Now think about if it took slightly longer for the rear wheels to rotate then the fronts. The front wheels would have one time for one full rotation of the center diff and the rears would have a different time. The front or rear wheels are going to win, the center diff is going to lose. Essentially it will assume the smaller rotation is slipping because it is taking less time to rotate when in fact it isn't.
Old 07-28-2008, 03:14 PM   #15
SeriousInquiry
Member#: 185189
It really depends on when you use the tires and how you use the tires. When i drive my Bmw around turns at 60 or so i can feel the back end kick out cause i have two different sets of tires as well. (I have racing tires in the front and regular all seasons in the back) There's so much grip in the front from the racing tires that the back end gets lose. So yes it can be unsafe, it all depends on how you drive at least thats how i see it.
SeriousInquiry is offline   Reply With Quote
Old 07-28-2008, 03:21 PM   #16
Chuck H
Member#: 20442
It will put a little extra wear and tear on the center differential. Chances are that you'll be fine, but Subaru is extremely conservative with rating the center diff on the WRX, and won't warranty anything if you take it in with a cooked diff, and the wheel circumference difference exceeds 1/4".
If you do some quick calculations, a 215/45-17 tire turns roughly 820 revolutions per mile. The 1/4 inch diameter difference that you're seeing would change that by approximately 10 revolutions per mile. That means that at 60 mph, the plates in your center diff are slipping past each other and stirring up the viscous fluid at approximately 10 revolutions per minute. Even though that's 3 times the recommended limit from Subaru, I have a hard time imagining it can generate enough heat to damage the diff. I think they just set an impossible standard to meet so that they'd always have an out if they didn't feel like covering a diff under warranty.
Chuck H is offline   Reply With Quote
Old 07-28-2008, 03:25 PM   #17
DrnknZag
Member#: 138473
2007 WRXstealthwagon
6spd kindaflush
You're not getting the point here dude, it has nothing to do with safety, more to do with simple mechanics.
If the diameter of the tires is significantly different, the wheels will spin at a different speed than the rest, which can overwork the center diff.
DrnknZag is offline   Reply With Quote
Old 07-28-2008, 03:25 PM   #18
Chuck H
Member#: 20442
Thx.
The center diff on a manual WRX isn't anywhere near that smart. It's simply a "limited slip differential" as the name implies. In a viscous-type differential, you have a series of parallel plates separated by a fluid that becomes more resistant to shear the more force you apply to it. In simple terms, it allows the plates to slip past each other slowly, but if they try to slip quickly, the fluid acts more like a solid and forces them to want to turn at the same speed. It works a lot like the torque converter in an automatic transmission.
It can't "send power to the wheels with traction" or anything like that. All it can do is try to keep the average speed of the front tires, and the average speed of the rear tires approximately equal.
Old 07-28-2008, 03:41 PM   #19
Aspen700
Member#: 109259
2004 WRX
the simple answer is that it can be very bad if it burns up the center diff. it is not worth risking it. just get a matching set of tires for all four corners.
Aspen700 is offline   Reply With Quote
Old 07-28-2008, 04:06 PM   #20
jasonallenross
Member#: 125978
2002 WRX Wagon
Is straight from Subaru good enough?
Originally Posted by SOA web site
WARNING: All four tires must be the same in terms of manufacturer, brand (tread pattern), construction, degree of wear, speed symbol, load index and size. Mixing tires of different types, sizes or degrees of wear can result in damage to the vehicle's power train.
http://www.subaru.com/owners/carcare...id=TIRED_TIRES
I've also seen the 1/4" circumference information on the Subaru site, as well. Might be in the owner's manual. Possibly even a FAQ here.
jasonallenross is offline   Reply With Quote
Old 07-28-2008, 04:08 PM   #21
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Hey Morgan, that's a damn good explanation. It's simple once you understand, but actually explaining it so simply isn't easy. Nice job homie
Audiosavvy is offline   Reply With Quote
Old 07-28-2008, 04:12 PM   #22
jasonallenross
Member#: 125978
2002 WRX Wagon
Most likely your BMW is a 2wd car, which can be run with differing tires on front and rear (although it's still not a fantastic idea in many cases, for many reasons). If you have a "x" model, it wouldn't surprise me to know that you have the same constraint regrading replacing all four wheels.
Also, BMW's with racing tires front and rear can break the rear end loose, too
Old 07-28-2008, 04:34 PM   #23
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Please try not to hit anyone when you spin off the road into a tree, kthx.
waktasz is online now   Reply With Quote
Is running two different treads ok? pwnx0rz Tire & Wheel 46 04-20-2011 07:30 PM
So how bad is it really to have 2 different types of tires on the front and rear? 0260B4U Tire & Wheel 4 10-01-2008 12:09 AM
How bad is it really, to have 2 different sets of tires on an AWD car? WhiteFox Tire & Wheel 12 03-19-2008 03:22 PM
How bad is NOS for the stock "03" Pistions & Rods skimobile Water/Methanol Injection, Nitrous & Intercooler Cooling 3 04-10-2006 01:13 PM
Is it bad to run 2 different tires on your car? SDaWG Tire & Wheel 7 08-19-2003 09:31 AM
