Old 10-01-2008, 12:43 PM   #1
dmpi
Member#: 49987
04 STI
BLUE/SILVER
Default Physics Question: Lightning
Conventional wisdom say’s that lightning always finds the pass of least (electrical) resistance. My question is: Just how does lightning do this? Suppose there are two towers. Both identical except one have a lightning rod on it. How does the lightning “choose” the one with the rod? Does it try out the other tower and figure out there’s no rod on it? Does it also go around and check out all the tall trees and buildings in the area? It would need to check every square inch of the earth surface. If you think about it really doesn’t make sense.
dmpi is offline   Reply With Quote
Old 10-01-2008, 12:45 PM   #2
Tilapia
Member#: 42454
It passes gas and then laughs.
Tilapia is offline   Reply With Quote
Old 10-01-2008, 12:46 PM   #3
r0bman
Member#: 87015
It consults this guy, right here:
r0bman is offline   Reply With Quote
Old 10-01-2008, 12:46 PM   #4
The Dayman
Member#: 84815
2015 water n badass.
badass n water.
Nissan programmed it to be able to go it's fastest upon approved routes only.
The Dayman is offline   Reply With Quote
Old 10-01-2008, 12:47 PM   #5
hikeeba
Member#: 89165
Poop Stuck Survivor
-=C=- & subari87 FOREVER!
Lightning are smart. And it was designed and sent to Earth by God. And it is only 6000 years old.
hikeeba is offline   Reply With Quote
Old 10-01-2008, 12:47 PM   #6
Mr.Sparkle
Member#: 83725
2015 WRX
Lightning is basically a connection between earth and sky. Ground objects send up positive feelers and lightning chooses the most convenient one. Once the positive and negative charges meet a bolt is created that goes down to the ground.
Mr.Sparkle is offline   Reply With Quote
Old 10-01-2008, 12:49 PM   #7
chkltcow
Member#: 10814
'13 ToyobaruFRZ-86
97 Miata M
A stepped leader of negative ions comes down from the cloud, forming the forks that you see with clouds. It can branch and take the different paths to the ground.
Meanwhile, a positive streamer comes up off any and everything it can from the ground up. This is why they say your hair stands on end before you get struck by lightning. In some photos of lightning, you can see visible positive streamers coming off of trees, houses, poles etc without actually being involved in the strike itself.
When the two meet, the actual flash is the charge moving from the ground to the cloud... the return stroke.
chkltcow is offline   Reply With Quote
Old 10-01-2008, 12:49 PM   #8
WRXVT
Member#: 17979
335i Blue
lightning doesn't strike so much as it forms. and it will form at the easiest/quickest path
WRXVT is offline   Reply With Quote
Old 10-01-2008, 12:49 PM   #9
The Dayman
Member#: 84815
badass n water.
Old 10-01-2008, 12:50 PM   #10
Asinine
Sufficient for Sharky
Member#: 55173
with paddles.
A) Lightning rods don't attract lightning. They bleed off electrical potential so that it's less likely that enough potential is generated to cause a strike.
B) The discharge occurs when the potential is greater than the resistance (air in an excellent insulator), and travels down the path of least resistance available to it. Just like conventional electricity travels down a copper wire rather than through a plastic barrier. It doesn't go all over the house looking for the thickest copper wire. If there is enough potential to transmit electricity from a negatively charged pole to a positively charged pole, it happens.
Asinine is offline   Reply With Quote
Old 10-01-2008, 12:51 PM   #11
Habu
Member#: 3052
That's the most accurate explanations I've read. I'd have said about the same thing. But yes, the actual, visible bolt you see is the positive charge going UP to the clouds, not down.
Habu is offline   Reply With Quote
Old 10-01-2008, 12:52 PM   #12
xlsupreme
Member#: 120789
2005 USDM STi
path of least resistance doesn't mean that other paths need to be tried to find that out, it means that the pathway in question has less resistivity based on material composition. and the such as.
xlsupreme is offline   Reply With Quote
Old 10-01-2008, 12:54 PM   #13
xlsupreme
Member#: 120789
2005 USDM STi
holy 7 answers in two minutes...
Old 10-01-2008, 12:54 PM   #14
Mr.Sparkle
Member#: 83725
2015 WRX
You can see a positive feeler going up from the tree in this picture.
Old 10-01-2008, 12:55 PM   #15
chkltcow
Member#: 10814
'13 ToyobaruFRZ-86
97 Miata M
After my little run-in with lightning while driving my Miata, I wanted to learn more about how it worked
Old 10-01-2008, 12:55 PM   #16
Tilapia
Member#: 42454
This guy controls it all.
Old 10-01-2008, 12:56 PM   #17
Kiel
Member#: 133439
2003 WRX
Sonic Yellow - Stage Taxi
Electricity takes EVERY path and then goes back and takes the best path once it decides which it is. Sort of like old people.
Kiel is offline   Reply With Quote
Old 10-01-2008, 01:16 PM   #18
Bryan T
Member#: 17948
I'd like to see a double-slit experiment with lightning.
Bryan T is offline   Reply With Quote
Old 10-01-2008, 01:19 PM   #19
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
DO NOT GIS "positive feeler" with the filter off!
Mr.Krinkle is offline   Reply With Quote
Old 10-01-2008, 01:21 PM   #20
FiveDoorSVT
Member#: 79933
'03 Mazda Protege5
Serious question: if lightning finds the shortest path, why isn't it straight? Photos of lightning are always filled with jagged twists and turns.
FiveDoorSVT is offline   Reply With Quote
Old 10-01-2008, 01:22 PM   #21
Kiel
Member#: 133439
2003 WRX
It's not the shortest path, it's the path of least resistance.
Old 10-01-2008, 01:22 PM   #22
The Dayman
Member#: 84815
badass n water.
Upset there was no porn in the search results?
Old 10-01-2008, 01:23 PM   #23
banman
Member#: 12408
2006 Legacy GT
Isn't this sort of like asking why water flows downhill?
banman is offline   Reply With Quote
Old 10-01-2008, 01:23 PM   #24
FiveDoorSVT
Member#: 79933
'03 Mazda Protege5
So what's in the air that makes it more or less resistant to lightning? In other words, what's in the air that causes those twists and turns?
Old 10-01-2008, 01:24 PM   #25
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
At work.
Physics question: Help me settle an argument at work dmpi Off-Topic 47 01-22-2009 10:29 AM
Meta Physics Question: Infinite sided dice dmpi Off-Topic 48 09-19-2008 11:04 PM
Lightning Bolt! Lightning Bolt! Lightning Bolt! Sephro Off-Topic 5 08-31-2005 09:09 AM
A sign of irritation from above? Lightning Bolt! Lightning Bolt! Lightning Bolt! Coati Off-Topic 8 10-24-2003 05:12 PM
Lightning Bolt! Lightning Bolt! Lightning Bolt! Andrew Bay Area Impreza Club Forum -- BAIC 18 08-22-2002 12:05 PM
