Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 07-29-2008, 12:19 PM   #1
Turn in Concepts
Vendor Sales Rating: (159)
Member#: 93646
Many Track Records
Let us help you go fast!
Default No "pm Us For Pricing" Bs!!!!!
Cobb Accessport V2 in stock.
AP-SUB-002 - 04-07 2.5 Turbo in stock. $695 shipped for free in the US.
Click here to get it.
AP-SUB-003 - 2008 WRX and STi in stock. $695 shipped for free in the US.
To get one click here.
__________________
__________________
Turn in Concepts is offline
Old 07-29-2008, 12:19 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
P&L 44mm EWG kit
P&L's EWG setup starts off life as a high quality TurboXS up-pipe that has been setup and modified to run a high quality Tial 44MM v-band wastegate. The TurboXS down-pipe (arguably the most difficult to fit an EWG on) was used to finalize the production jig so there would be no fitment issues at all.
We listened to our customers who wanted a high quality unit compatible with the TurboXS downpipe (one of the more widely used units here in the midwest). We selected the TurboXS up-pipe as well due to its extreme high quality, quality control, and availability. Why re-invent the wheel if it's not necessary?
Included:
* Tial 44MM wastegate
* Modified TurboXS up-pipe
* 1 BAR spring
* V-band clamps
* Dump tube
$749 shipped for free in the US.
To get yours click here.
Pics (TXS bellmouth downpipe not included):
__________________
__________________
Old 07-29-2008, 12:19 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
P&L HighFLO intake
In an industry first the P&L HighFLO intake provides baseline calibration tuning data to help your tuner quickly, and most accurately set up your car. This is not to be taken lightly as it required many many hours of work to develop. It's details such as this which demonstrate how well thought out, and detail oriented the products from P&L are. Remember, this is not something you get from anyone else, and there's a reason. The other manufacturers did not take the time or bother with the expense to do this. Bottom line, they just don't know, and can't provide a starting point to get the best tune possible.
Additionally this elegant, 3" brushed aluminum intake is fully TIG welded to ensure the proper seal that is lacking from so many other intake designs.
Utilizing a full 3" cross section, the intake is designed to offer MAF resolution up to 450HP on a Subaru non drive-by wire ECU (limited to 4.74 MAF volts), and up to 500HP on a Subaru drive-by wire ECU which goes up to a full 5 MAF volts.
The intake design is actually swept back placing the filter in what we've found to be the "coolest" spot under the hood. Several other intakes were tested and this placement actually measured about 30F cooler under tuning conditions compared to a comparable high horsepower "Big MAF" sized intake.
Finally, the short design is setup to use a small profile coupler to attach to a factory inlet hose, or slide directly into most aftermarket silicone hoses (I.E. Samco), allowing us to utilize a HUGE K&N air filter to make sure there are zero questions about pressure drop and airflow to even the largest of standard location turbo chargers.
Current front mount testing shows zero compatibility issues with the following units:
TurboXS 1st generation and 2nd generation FMIC
Price is 230 shipped for free in the US, and you can get yours by clicking here.
__________________
__________________
Old 07-29-2008, 12:19 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Grimmspeed UnCoated Up Pipe
We here at TiC see a lot of parts. A LOT of parts. In fact, we've become kind of jaded in the type of stuff we see since there's a baseline of quality and performance in a part that's needed before we carry it. Every once in a while, not too often, but every so often we run across a part that so far exceeds what we expect out of a quality part that we just sit back and say "WHOA!"
The Grimmspeed up-pipe is one of the those parts. I have confess, I'm having a hard time writing this description because I just can't express in words how blown away I am with this part. Seriously, this blows away ANY other up-pipe we have seen. Period. Bar none. End of story.
Let me break down what we want in an ideal up-pipe and then fill you in on the details.
* A part that fits like it was meant to go there from the factory.
* Thick flanges - thick ones stay flatter longer
* A flex section - we have found that this is actually rather important
* The flex section down low on the pipe - this allows flow to smooth out a bit before entering the turbo. A flex section at the top is just dumb
* Smooth bends spread out over as long a distance as possible
* Consistent inside diameter to smooth flow
* A nice transition from flange to tube
Now, here's what's on the Grimmspeed unit
* Beautiful fit
* Nice flat flanges that are over 11mm thick (stock pipe has 10mm thick)
* A beautiful flex section that has a nice big ID to it doesn't constrict the tube size. Oh, and it's down really low.
* Bends that are so smooth and take up almost the entire upper section of the pipe
* Beautiful transition into the bends due to using a mandrel to shape the tube
* Transition from flange to tube. THIS part of the Grimmspeed pipe is... well, is just overwhelmingly awe inspiring. Here's what they did - they counterbored into the flange for the tube. That means no step from flange to tube. Incredible.
Oh, and there's one more thing. The welds. Artwork. I'm gonna hire their welder to just run some beads in random patterns on a plate of stainless steel so I can hang it on my wall as art. I'm serious. I'll send you pics once I have it made. These welds are in-flippin-credible.
*Grimmspeed up-pipe comes with 5 nice new studs to use with your, superior to everyone else, up-pipe.
Price is $180 shipped for free in the US, and you can get yours by clicking here.
__________________
__________________
Old 07-29-2008, 12:20 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Grimmspeed Coated Up Pipe
* Beautiful fit
* Please note this one is also ceramic coated.
Price is $200 shipped for free in the US, and you can get yours by clicking here.
__________________
__________________
Old 07-29-2008, 12:20 PM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Grimmspeed 06-07 WRX crosspipe
Whats one of the most overlooked anti-flowing subaru pieces you ask??...the stock exhaust manifold crossover. 50% of your exhaust gasses are passing through this tiny tiny pipe and that is not good. Well here comes the solution for this problem.
Welcome to our Version 2 Subaru Exhaust Manifold HiFlow Crossover. As many of you may or may not know, we came out with our 1st Gen crossover the end of last summer and had sold out of them instantly every time we got a new batch in.
Well we've decided to step it up a notch with our first revision of the crossover. Meet HiFlow Crossover v2. Immaculate welds, smooth as butter 2" stainless steel, thick 12mm stainless flanges. you cant beat this piece.
Customers have seen up to 15 HP INCREASE when combined with our PnP Subaru Exhaust Manifold. This unit is built from 2" 304 Stainless Steel throughout, maximizing exhaust flow from cylinders 1 and 4 to the manifold collector for faster turbo response. This unit has a flex in the center to allow for easier installation, and flex due to expansion and contraction due to heat. Those other pipes without a flex section - yeah, good luck with those welds.
Applications:
06-07 Subaru WRX
04+ Forester XT
Price is 190 shipped for free in the US, and you can get yours by clicking here.
__________________
__________________
Old 07-29-2008, 12:20 PM   #7
Turn in Concepts
Member#: 93646
Many Track Records
Grimmspeed 02-05 crosspipe
Applications:
02-05 WRX
04-07 STi
04-07 LGT
04-07 Baja T
91-94 Legacy Turbo
04-07 Baja Turbo
Price is $190 shipped for free in the US. You can get yours by clicking here.
__________________
__________________
Old 07-29-2008, 02:23 PM   #8
48mpg
Member Sales Rating: (19)
Member#: 58405
2004 Element GT65'd
Hydra, Hydramist'd STi
bump for thread title,
finally a vendor that will actually advertise a price.
too bad i am not in the market for any of those products.
48mpg is offline
Old 07-31-2008, 08:40 AM   #9
Turn in Concepts
Member#: 93646
Many Track Records
There's just a few of us out there that don't feel like wasting your time...
__________________
__________________
Old 07-31-2008, 10:27 AM   #10
kevinh211
Member Sales Rating: (1)
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
+1
i might buy something just because
kevinh211 is offline
Old 07-31-2008, 12:58 PM   #11
sti robot
Member Sales Rating: (35)
Member#: 110932
2013 BRZ
AMEN to the thread title!
Will be buying some pads/fluid from you in about a month.
sti robot is offline
Old 08-01-2008, 07:16 PM   #12
Turn in Concepts
Member#: 93646
Many Track Records
Sounds good. Just shout when you're ready.
__________________
__________________
Old 08-01-2008, 07:19 PM   #13
Mechie3
Member Sales Rating: (51)
Member#: 120152
+1
but too bad (in a good way) I already bought all of those! (except the EWG).
Mechie3 is offline
Old 08-01-2008, 11:52 PM   #14
Turn in Concepts
Member#: 93646
Many Track Records
Originally Posted by Mechie3 View Post
+1
How about the spearco IC? did you grab one of those yet?
OH OH!!! or the P&L GT30/35 kit? We can get those too.
__________________
__________________
Old 08-04-2008, 08:36 AM   #15
Turn in Concepts
Member#: 93646
Many Track Records
cars go vroom!
__________________
__________________
Old 08-05-2008, 08:52 AM   #16
Turn in Concepts
Member#: 93646
Many Track Records
the wheels on the bus go round and round
__________________
__________________
Old 08-05-2008, 11:54 AM   #17
sebtarta
Member Sales Rating: (13)
Member#: 82883
2006 2.5i Wagon
'72 Nova Turns & Stops
row row the boat........
Crosspipe for 05 WRX...
have the full PNP header for the WRX?
sebtarta is offline
Old 08-05-2008, 11:37 PM   #18
Turn in Concepts
Member#: 93646
Many Track Records
Have the crosspipe. We don't do porting though.
__________________
__________________
Old 08-16-2008, 10:55 AM   #19
Turn in Concepts
Member#: 93646
Many Track Records
bump!
__________________
__________________
Old 08-17-2008, 03:56 PM   #20
Turn in Concepts
Member#: 93646
Many Track Records
Bump!
__________________
__________________
Old 08-17-2008, 04:04 PM   #21
Swine
Member Sales Rating: (42)
Member#: 16197
07 GX470 PearWhite
09 VMAX, 02 BMW R1150r
Free bump for the boys at tic.
Swine is offline
Old 08-17-2008, 04:22 PM   #22
B00st3dWRX
Member Sales Rating: (18)
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
bump for TIC
B00st3dWRX is offline
Old 08-18-2008, 02:18 PM   #23
Turn in Concepts
Member#: 93646
Many Track Records
TiC, Kartboy, Whiteline, P&L Motorsports, Motul, all to be found at http://turninconcepts.com
__________________
__________________
Old 08-18-2008, 04:24 PM   #24
Turn in Concepts
Member#: 93646
Many Track Records
Enjoy your car. Visit http://turninconcepts.com
__________________
__________________
Old 08-18-2008, 05:27 PM   #25
Turn in Concepts
Member#: 93646
Many Track Records
__________________
__________________
Closed Thread
FS: NoVA: Samco Radiator Hoses in Black and 4 No Tear Clamps for 02-07 WRX / STi. adjasont Engine/Power/Exhaust 5 11-27-2011 04:06 PM
No "PM us for pricing" BS!!!!!! Turn in Concepts Suspension/Brakes/Handling 24 07-31-2008 08:39 AM
No "PM us for pricing" BS!!!!!! Turn in Concepts Drivetrain 10 07-29-2008 03:09 PM
No Hakkas 2 for US market? Hyper Tire & Wheel 5 01-29-2005 07:17 PM
NEWSFLASH: US had no occupation plan for postwar Iraq according to Army strategist ANZAC_1915 Political Playground 34 01-04-2005 10:21 PM
