Old 07-30-2008, 05:28 AM   #1
adofly
Member#: 107693
2006 impreza Race
car 700hp
Default Motor oil suggestions-AXIS STAGE 5
I need some suggestions as to which oil to use. Brand and weight but full synthetic.
I currently use Valvoline VR-1 5w-50 full sunthetic. However during a 3 minute run the oil pressure starts at 82 psi but it decreases during the run and ends up at 63 psi.
The engine is a stage 5 long block done by Axis. Current boost pressure is as low as 1 bar, rev limit at 8300 rpm. Oil pump is JUN.
adofly is offline   Reply With Quote
Old 07-30-2008, 09:50 AM   #2
silver-duck
Member#: 130710
Amsoil series 2000,20W-50, sever service racing oil. I have used it for 25+ years, semi's and race cars.
silver-duck is offline   Reply With Quote
Old 07-30-2008, 10:09 AM   #3
MS WRX
Member#: 117780
2004 WRX
here is an idea....ask your engine builder. He should be most qualified to answer this question
MS WRX is offline   Reply With Quote
Old 07-30-2008, 10:23 AM   #4
adofly
Member#: 107693
2006 impreza Race
car 700hp
He suggests SHELL ROTTELA 10W-40, but I'm not sure if this a full synthetic oil.
We don't have Amsoil here.
Old 07-30-2008, 11:56 AM   #5
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
wht do you mean by "3 minute run"? Do you mean that you perform power pulls on the dyno for 3 minutes at a time??
jigga is offline   Reply With Quote
Old 07-30-2008, 04:03 PM   #6
Turbo_Mike
Member#: 130276
2004 STi 40R RWD
Rootbeer
Correct, shell rotella is regular dino oil, it is not snythetic.
I've tried it, doesnt seem to hold up that well at very high oil temps, but I didnt build your engine.
Turbo_Mike is offline   Reply With Quote
Old 07-30-2008, 05:38 PM   #7
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
You have 3 options as this isn't an oil problem, it's your crankshaft causing this.
1. continue to drive the car the same way and it will eventually spin a rod bearing due to low oil pressure at high rpm
2. lower your rev limit down to around 7400 so you don't have as big of a drop in pressure
3. remove the modified crankshaft and put a stock one back in, bam oil pressure problem gone
dan avoN7 is offline   Reply With Quote
Old 07-30-2008, 06:02 PM   #8
prometheum
Member#: 92003
04 bicycle!
the only synthetic version of shell is rotella t and it only comes in 2 viscosities 5w40 and 15w40
prometheum is offline   Reply With Quote
Old 07-30-2008, 11:49 PM   #9
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Perhaps the builder suggested rotella (dyno) oil because your engine is being run in?
DO NOT put synthetic oil in your engine if it has not been properly run in and the rings are bedded correctly.
wrxsti.l is offline   Reply With Quote
Old 11-14-2008, 06:29 PM   #10
korhan
Member#: 103202
09 sti09&00gc8
black&grey
we are using castrol edge 10-60 RS with all race engines including axis stage5 and it is always give better pressure than others.
for example we compare it with mobil1 motorsport 15-50 and it gives app. 14 psi more pressure at high revs(8000-8500). i know that this oil cant find in US merket but some supra guys import them from Europe to US.
korhan is offline   Reply With Quote
FS: Axis Stage 5 Shortblock, Axis Race heads and MUCH MORE!!! mxturboracer86 Engine/Power/Exhaust 36 03-27-2009 07:12 PM
FS- Axis Stage 5 block, Axis Built heads! FULL MOTOR! nick32 Engine/Power/Exhaust 35 01-08-2009 04:53 PM
Axis Stage 5 Race Motor 1000hp capable colbs19 Engine/Power/Exhaust 0 02-05-2008 09:26 PM
Axis Stage 5 Race Motor 1000hp capable colbs19 Engine/Power/Exhaust 0 02-05-2008 07:47 PM
AXIS stage 5 motor on ebay. greasemonkey Private 'For Sale' Classifieds 1 04-24-2005 11:16 PM
