Old 07-30-2008, 11:52 AM   #1
efmd3
Member#: 120985
2002 Impreza WRX
Midnight Black Pearl
Default In the middle of a build
So I'm a little bit into my build now, and I'm looking for some advice.
I started off with a blank core EJ25 block (2005 USDM STi).
I bought OEM STi rods from a 2007 STi and a crankshaft NIB from Subaru.
I am using CP pistons and rings 100mm 8.2:1 CR.
Cosworth main and rod bearings
cometic head gasket (1.3mm, 100mm bore)
ARP head studs
If there's anything goody there, let me know so I don't start putting things together only to find out something doesn't work.
Now for the heads:
Starting off with stock 2002 WRX heads
I'm going to get them cleaned and ported and possibly a 3-angle valve job.
inside I'm using Brian Crower stage 2 cams, BC valve springs/retainers, and Brian Crower valves.
I'm not going to deck/mill because this is going to be a twice-a-week driver on top of a fun-only car.
Is there anything that I will need to finish this build, that I can't get off my old WRX 2.0? Any sensors, etc?
Any other recommendations for a first time builder? (I do have a professional doing most of the work, but I'm trying to learn)
efmd3 is offline   Reply With Quote
Old 07-30-2008, 04:26 PM   #2
Turbo_Mike
Member#: 130276
2004 STi 40R RWD
Rootbeer
Your compression will be slightly higher than 8.2 since 2.0 heads have a smaller combustion chamber than 2.5 heads. Thats not really the biggest deal, but just telling you so you know. And make sure you have the valve buckets properly clearanced with the new cams or your heads will be a world of trouble. Doing a valve job and replacing the valves usually wreaks havoc with the valve clearances....
Turbo_Mike is offline   Reply With Quote
Old 07-30-2008, 05:01 PM   #3
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
So when installing new cams, doing a valve job, and replacing the valves, can the valve stems be cut to get the proper lash without changing the buckets. Can I reuse buckets in my 04 sti head and just cut or grind the valve stems?
methaddict is offline   Reply With Quote
Old 07-30-2008, 05:02 PM   #4
efmd3
Member#: 120985
2002 Impreza WRX
isn't the stock head gasket 1.1mm? i was told the 1.3mm head gasket will make it closer to 8.2.
also, i'm having a shop machine the heads, and another shop assemble them. they should be able to make sure all clearances are correct, right?
Old 07-30-2008, 06:00 PM   #5
Turbo_Mike
Member#: 130276
2004 STi 40R RWD
Rootbeer
the issue is that the buckets are not all one standard size. they are all different.... so the valves can be cut to the correct length, but it requires a lot of assembly, measurement, and disassembly over and over to get it right... and if theres too much clearance you need to get a bucket with a thicker measurement for that valve to get it right........just trying to give you guys a heads up, make sure the shop knows what they are doing, subaru valve clearance is not a simple thing...
Old 07-30-2008, 06:53 PM   #6
efmd3
Member#: 120985
2002 Impreza WRX
so i guess my next question is, who has a good reputation for assembling heads correctly and has a decent price?
Old 07-30-2008, 07:33 PM   #7
jays05
Member#: 78165
05 STI 35r + e85
Yes. I had cosworth cams + supertech valvetrain + supertech +0.5mm SS valves installed. They cut the valve stems and we only had to replace one bucket. 05 sti heads.
jays05 is offline   Reply With Quote
Old 07-30-2008, 07:36 PM   #8
jays05
Member#: 78165
05 STI 35r + e85
Try Ron @ RAW Performance (Axis). His labor rates are very reasonable.
Baby in the middle of the road in the middle of the night WhiteH2O Off-Topic 32 05-20-2010 05:58 PM
In the middle of the niiiiiight.... (woken by the stench of feces) Sideshowbob Off-Topic 40 07-21-2009 02:48 PM
Who the hell gets the flu in the middle of May? live311 Off-Topic 28 05-18-2005 12:28 AM
why the hell is it raining in minnesota in the middle of winter? Protege Menace Off-Topic 12 12-30-2004 01:35 PM
Size of 2 bolts that hold the driveshaft in the middle of the car jefersun Transmission (AT/MT) & Driveline 5 03-25-2004 07:44 AM
