Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 07-30-2008, 03:12 PM   #1
ilgdrummer
Member#: 28364
2004 Wagon STI
Java Black
Default V7 STI block with 04 WRX heads = Emsission friendly?
My question is if I use the the short block of a jdm v. 7 sti and place stock 04 wrx heads on top and use everything else that belongs to the us wrx harness, turbo, manifold, etc. could I pass smog?
Thanks,
Tony
ilgdrummer is offline   Reply With Quote
Old 07-30-2008, 07:48 PM   #2
legacy2003
Member#: 38338
2003 Outback Sdn H6
Yes, the only thing you're doing is putting in a stronger block with the same compression ratio as your WRX. This won't affect anything other than giving you a stronger block to build off of in your quest for more power.
This in no way will affect you passing smog or not.
legacy2003 is offline   Reply With Quote
Old 07-30-2008, 07:58 PM   #3
ilgdrummer
Member#: 28364
2004 Wagon STI
Java Black
thats what i figured i just wanted someone to verify this before i pull my v7 heads off.
thanks agian,
tony
how do i hook up AVCS 0n 02 wrx 08 sti block with 06 wrx heads sgiord86 Built Motor Discussion 8 10-05-2009 10:36 AM
wrx crank in EJ257 - With 04 wrx heads and sti cams morrocco88 Built Motor Discussion 64 09-05-2009 08:48 PM
jdm 2.0 wrx block with usdm wrx heads? YFZ450CHUCK Built Motor Discussion 6 03-01-2008 11:02 PM
V2 RA STi block vs. 2.5 USDM STi block with '05 wrx heads? saab-on-the-cobb Subaru Conversions 6 09-18-2006 08:03 PM
usdm sti block with usdm wrx heads. couple ?s redrr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-23-2006 12:26 AM
