Old 07-30-2008, 05:14 PM   #1
drftwell
Member#: 182244
Default JDM STI EJ207 version 6 into USDM 02 wrx hELP!!!
well i bought a car that had a crappy motor , ran fine at first then started to overheat.... not good, short story , cracked block.... but neways i have found a version 6 ej207 for a good deal with the version 7 6 speed.... what would this require to be swapped into my 02??? yes i have searched but there isnt much info on swapping motors into bugeyes..... i need some help before i actually buy the motor.... thanks for reading everyone!
drftwell is offline   Reply With Quote
Old 07-30-2008, 06:46 PM   #2
wopdeeze
Member#: 148597
00 GDA Jet Black
04 GGA PSM 10 SH5 XT
the version 6 ej207 doesnt have coil on plug, so really to make it work with your ecu you would either rewire the car with a version 6 ecu or use your heads and intake manifold on the ej207 short block. if you decided to go to the version 7 motor, you would have to wire for avcs. but everything else should match up. i put a version 8 motor in mine after i fried a piston but since my wrx is japanese the stock motor already had avcs. another thing to note is the compression ratio is different on the 207 so be prepared to tune. hope this helps
wopdeeze is offline   Reply With Quote
Old 07-30-2008, 08:49 PM   #3
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
just a few thoughts you should be rolling around in your head.......
by swapping in an older OBD1 motor into an OBD2 car you are causing yourself a bunch of headaches. it won't pass emissions, and you're going to have to do all sorts of wiring to make it run properly.
you should look into just swapping in another USDM WRX motor or if you're set on JDM a v7/v8 but i believe the v8's are easier to get to pass emissions. not entirely sure though.
hail2theTheif is offline   Reply With Quote
Old 07-30-2008, 09:00 PM   #4
drftwell
Member#: 182244
Ah emissions aren't a problem, I live in tn. As for wiring, yeah I don't wanna do that... i can't find a v7!!! I don't wanna go back stock because I honestly think that the "world" ej20 is junk.... So either v7 , v8 , or I'm gonna start looking into a hybrid build....
Old 07-30-2008, 10:12 PM   #5
drftwell
Member#: 182244
what bout version 7 with version 7 ecu? i know the octane and whatnot is different... but what else would i have to change? im just really having a hard time finding a motor set
Old 07-31-2008, 12:38 AM   #6
legacy2003
Member#: 38338
2003 Outback Sdn H6
Ver. 6 is OBDI, so that will present some problems if/when you try to resell the car later on down the road. Ver. 7 or 8 JDM would be your best bet, as there is virtually no wiring involved, where as there would be on a Ver. 6, save for wiring the AVCS which IIRC is something like 10-12 additional wires and there are wiring kits that come with instructions (IA Performance has said kit). Passing OBDII would be easy; just swap in a reflashed USDM WRX ECU with the TGV and a few other codes flashed out.
Ver. 7/8 also has more tuning options state side and parts availability, as many of the parts from the EJ205/EJ257 are interchangeable with the EJ207 Ver. 7/8. Ver. 6 will take a bit more work.
Cliff notes: Don't buy a Ver. 6. Spend the little bit more money and get a Ver. 7/8 engine. Less headaches, greater resale value, and much much much more aftermarket availability stateside.
legacy2003 is offline   Reply With Quote
Old 07-31-2008, 01:10 AM   #7
parkes
Member#: 166898
1994 T leg SS
ABM
Move to Canada, all those worries should dissapear!
parkes is offline   Reply With Quote
JDM STI GC8 Version 6 suspension set! PICS Lam VIC Private Classifieds 5 06-18-2010 11:49 PM
argh! wiring 04 sti into a 02 wrx help! jobxiii Subaru Conversions 0 10-10-2007 03:30 PM
06 WRX box into a 02 WRX help gling Transmission (AT/MT) & Driveline 8 06-10-2007 02:12 AM
04 WRX tranny swap into a 02 WRX help ! Don Arm Transmission (AT/MT) & Driveline 1 08-18-2006 11:04 PM
$75 JDM sti Gc8 version 6 20mm sway bar supermoose Private 'For Sale' Classifieds 21 11-12-2005 12:53 AM
