Old 07-31-2008, 12:29 AM   #1
inyoface59
Member#: 95972
2012 Legacy
Default help me choose a turbo
im going to build a ej25 with 9:1 compression ratio pistons, more then likely stock rods and cranks
for the heads im going to either use my 2.0L heads ported a ton or grab some 2.5l heads and port them, then 272 cams and a lightweight valve train.
first.. should i use stock size valves or go +1mm?
also, what turbo should i use. right now i have a vf 30 but i want to go a little bigger. im looking to only push 15 psi with this motor. im looking for a faster spool and alot of TQ down low for daily driving.
lets hear your ideas...
this is going in a 02 psm bugeye
--Phil
inyoface59 is offline   Reply With Quote
Old 07-31-2008, 02:31 AM   #2
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
If you are rebuilding your engine then do it right and do it once
There really is not much difference in cost between stock conrods and pistons and a good set of aftermarket forged pistons.
Food for thought
wrxsti.l is offline   Reply With Quote
Old 07-31-2008, 11:54 AM   #3
inyoface59
Member#: 95972
2012 Legacy
ya, forged pistons are going in for sure, im still debating whether i want to put aftermarket rods in or not.
thanks for the input though
help me choose a turbo 970subaru Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-04-2006 12:10 PM
help me choose the turbo ILwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 12-11-2005 07:26 PM
Another help me choose a turbo post palaban Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-27-2003 08:25 PM
Help me choose a turbo neurotic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-02-2002 09:23 PM
