Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 07-31-2008, 10:30 AM   #1
Chiketkd
Member#: 71634
In hibernation...
Subaru Banner How competitive will the '09+ WRX be in D-Stock/ESP?
I figured a new thread was in order given the major performance boost SOA will be giving the new car. This almost makes me want to talk my wife into getting one for her next car -- that way I can autocross either car on the wekeends!
Full SOA press release (link to SOA press release- Press Release):
SUBARU BOOSTS 2009 IMPREZA WRX TO 265 HORSEPOWER
Cherry Hill, NJ--Subaru is revving up performance and handling in its iconic All-Wheel Drive Impreza WRX sport compact for 2009, following the debut of the all-new model in 2008. Performance leaps to a higher level in the 2009 WRX thanks to a 265 horsepower turbocharged intercooled Boxer engine, retuned suspension and wider, lower-profile summer performance tires. WRX enthusiasts will quickly identify the 2009 models by the ST-type grille and standard Aero Package. The 2009 Impreza WRX comes with a 5-speed manual transmission.
New Impreza GT Model
Subaru is also introducing a new Impreza 2.5GT model for 2009, powered by a 224-horsepower turbocharged intercooled engine teamed to a standard 4-speed electronically controlled automatic transmission with SPORTSHIFT.
Both the more powerful WRX and the new 2.5GT are available as 4-Door and 5-Door models. As on all Subaru models, the Impreza WRX and 2.5GT models are equipped with Symmetrical All-Wheel Drive (two different versions – see page 2 for details.)
The goal of the 2009 WRX team was termed “Kyo-Ka” (translated from Japanese as “strengthening”). To achieve this goal Subaru engineers thoroughly revamped the performance character of the WRX for 2009. Gaining a larger turbocharger, along with a new larger-diameter exhaust and low-density catalyst for reduced backpressure, the WRX engine now produces 265 horsepower at 6,000 rpm and 244 lb.-ft. of peak torque at 4,000 rpm – significant increases from the 224 horsepower and 226 lb.-ft. in the 2008 version.
The Impreza WRX debuted an all-new platform for the 2008 model year, featuring a longer 103.1-inch wheelbase and an all-new double-wishbone rear suspension system. Revised suspension tuning for 2009 further bolsters WRX’s street performance credentials. The standard 17 x 7-inch aluminum alloy wheels now wear 225/45R17 summer performance tires, compared to 205/50R17 all-season tires used on the 2008 WRX. The Vehicle Dynamics Control (VDC) stability and traction control system, which is standard on all Impreza models for 2009, helps to enhance the WRX model’s road handling safety.
Standard Symmetrical All-Wheel Drive, which forms the common core technology on all Subaru models, gives the Impreza WRX a significant handling performance advantage over front-wheel drive competitors. Symmetrical All-Wheel Drive is a complete system comprised of the Boxer engine and the full-time power distribution system (varies by model and transmission). The aluminum Boxer engine and simple, symmetrical drivetrain layout help to lower the car’s center of gravity, which in turn contributes to its handling characteristics.
The 2009 Impreza WRX employs a viscous coupling locking center differential that distributes torque 50:50 front/rear. Should slippage occur, this system transfers more power to the wheels with the best traction. The 2009 Impreza 2.5GT, like other Subaru models equipped with automatic transmission, uses a different version of the Symmetrical All-Wheel Drive system. An electronically managed continuously variable transfer clutch actively manages power distribution based on acceleration, deceleration, and available traction. This active torque-split system automatically transfers more power to the wheels with the best grip should slippage occur.
Suspension Re-Tuned For Sharper Handling
Subaru significantly re-tuned the suspension on the 2009 WRX, resulting in sharper turn-in and more responsive handling overall. Front upper strut mounts are adopted from the STI. The front spring rate is increased from 26.5 N/mm to 38 N/mm, and the rear spring rate is increased from 24 N/mm to 34 N/mm. Diameter of the stabilizer bars is also increased, from 20 mm to 21 mm in front and from 15 mm to 16 mm in the rear. Suspension damping has also been re-tuned. Notably, the new, stiffer suspension tuning did not require any further reinforcement of the inherently strong Impreza body structure.
Because the wider tires used on the 2009 WRX give more kickback than those on the 2008 model, a new damper valve was added to the steering gearbox to ensure a smooth and high quality steering feeling.
The Impreza WRX chassis is designed for improved rigidity and ride comfort and employs high-tension steel at key structural points. In addition to providing a basis for more responsive handling, the double-wishbone rear suspension that debuted in the new-generation Impreza models enables a smooth ride quality as well as decreased road noise for a quieter cabin.
The new-generation design results in a lower overall weight for the body while the longer wheelbase allows for improved ride dynamics, more interior room and reduced levels of noise, vibration, and harshness (NVH). In addition, the new chassis improves crash-worthiness and provides a stiffer platform for crisper handling.
Placing the engine slightly lower in the chassis than in the previous-generation Impreza models helped lower the center of gravity in the new Impreza platform, enhancing steering response. With the Subaru Dynamic Chassis Control Concept (DC3), Subaru optimized all elements of the Impreza’s chassis to deliver a better balance of handling response, ride quality, quietness and overall traction performance than offered by competitive vehicles. (See “Performance” section of this press kit for further details.)
New WRX Aero Body Styling
On both 2009 WRX Sedan and 5-Door models, a new STI-type grille carries the WRX badge. Both models get a sharpened new look from the standard Aero Package, which was formerly part of the optional WRX Premium Package. Both body styles also feature front and rear under-bumper spoilers and aerodynamic side ground effects. The sedan has a low-profile rear trunk spoiler, while the 5-Door adopts the WRX STI rear spoiler and a rear diffuser. The rear garnish panel between the light clusters is body color on the 5-Door and chrome on the sedan.
Other distinctions between the two models continue as before, including clear rear tail lamp lenses for the 5-Door and red lenses on the sedan. The 4-Door features dual tailpipe outlets, while the 5-Door uses a single, larger outlet (stainless steel on Premium Package.)
Rally-Inspired Interior
The WRX interior introduced new comfort and spaciousness for 2008, and for 2009 it gains new WRX-exclusive carbon black checkered upholstery accented by red stitching. The standard tilt and telescoping leather-wrapped steering wheel is accented by red stitching and standard aluminum-alloy pedal covers now include the driver’s footrest.
Performance-design front seats integrate the backrest and head restraint into a single structure. The sporty instrument panel features electroluminescent gauges, similar to the WRX STI. As in the WRX STI, the indicator needles sweep the gauge faces upon engine startup for a sporty effect. The WRX Premium Package gains a power moonroof; other contents carry over, including the 10-speaker audio upgrade with auxiliary input jack, projector-beam fog lights, dual-mode heated front seats, heated exterior mirrors and a windshield wiper de-icer.
The compact layout of the double-wishbone configuration helps to minimize intrusion into the cargo area, providing a wider and deeper luggage compartment. On the 5-Door WRX, the wide and flat load floor can accommodate two Tour-size golf bags with the rear seat backs in the upright position. In the WRX sedan, which is 4.5-inches longer than the previous-generation Impreza sedan and 6.5-inches longer than the new 5-Door models, the extra space provides for a larger, deeper trunk that can accommodate three Tour-size golf bags. In all WRX models, a 60/40-split folding rear seat further boosts cargo capacity and convenience.
Advanced Yet Easy-To-Use Technology
The available navigation and information center in Impreza WRX is the focal point of the center console. The navigation screen is located at the top of the dashboard for improved visibility and ease of use. With the navigation system, the center console provides an input for MP3 players as well as RCA-type video jacks that can accommodate portable gaming devices. These can be displayed on the navigation screen when the vehicle is parked.
Impreza models come pre-wired for XM® or SIRIUS® Satellite Radio. Both the standard and optional Impreza audio systems feature the Radio Broadcast Data System (RBDS) that can display a variety of information, including a song’s title and artist. The standard WRX audio system features an AM/FM stereo with single-disc CD player and four speakers.
The WRX Premium Package adds an AM/FM stereo with 6-disc in-dash CD changer featuring MP3/WMA file capability. Occupants enjoy powerful sound from 10 upgraded speakers (six in the front doors, four in the rear doors) and SRS® Circle Surround Sound. Also with this package, the steering wheel adds audio system switches. An auxiliary audio input jack enables connection of an iPod or MP3 player.
The optional Satellite Radio and Navigation package for the WRX integrates the Audyssey MultEQ audio enhancement. Used in high-end home theater systems, Audyssey MultEQ creates the optimal sound experience for passengers in each seat position by tuning equalization that corrects for time and frequency response. The navigation system itself presents major functions through an intuitive, easy-to-use touch screen interface. This option also includes Bluetooth® hands-free wireless capability (requires accessory kit.)
Safety Technology
The new-generation Impreza models are built upon the proven Subaru Ring-Shaped Reinforcement Frame body structure with front and rear crumple zones. All Impreza models for 2009 feature a 4-wheel disc Anti-lock Brake System (ABS) with Electronic Brake-force Distribution (EBD) and Brake Assist. (The WRX and 2.5GT models have larger front brakes than other Impreza models.) All seats provide 3-point seatbelts (height-adjustable for outboard positions), and the front seatbelts have electrically triggered pre-tensioners and force limiters.
Side-curtain airbags are standard on all 2009 Impreza models. The Subaru Advanced Frontal Airbag System (SRS) features front seat side impact airbags and a driver’s side front airbag that deploys according to the driver’s proximity to the steering wheel, as measured by a sensor on the seat track. In the passenger side front seat, a sensor module detects weight – first determining if it is occupied, and if so by a child or adult – to control airbag deployment. As part of the system, the dashboard features an “Airbag” indicator light.
About Subaru of America, Inc.
Subaru of America, Inc. is a wholly owned subsidiary of Fuji Heavy Industries Ltd. of Japan. Headquartered in Cherry Hill, N.J., the company markets and distributes Subaru Symmetrical All-Wheel Drive vehicles, parts and accessories through a network of nearly 600 dealers across the United States. Subaru makes the best-selling All-Wheel Drive car sold in America based on R.L. Polk & Co. new vehicle retail registration statistics calendar year-end 2007. For additional information visit www.subaru.com.
Subaru, Impreza, WRX and STI are registered trademarks of Subaru of America, inc.
Link to specs sheet: 2009 WRX Specs
The biggest draw-back is the continued use of the 17x7" wheels (was hoping for 17x7.5") which will limit the car to 245 r-comps (A6/V710/C7).
Using the posted gear ratios (from specs), the 3.9 final drive, the standard 225/45/17 tires and a redline of 6,500rpms, I'm showing that 1st will go to 39mph and 2nd will top out at 66mph.
Also, can someone convert the listed spring rates into lbs-in? Seems like a healthy increase though (43% increase front, 41.6% increase rear).
With a larger turbocharger (supposed to be the VF series turbo used on the Legacy GT), this car could be a heck of an ESP car if SOA strengthens the 5spd transmission some more.
Chiketkd is offline   Reply With Quote
Old 07-31-2008, 10:35 AM   #2
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
The front springs will be around 217 lb/in, if my calcs are correct. This would put the front frequency close to the GD STi... not bad at all. I think this would make it quite competitive in DS.
Rear springs will be around 195 lb/in , but I don't know what the motion ratio back there is so I can't really compare it to the pre-08's...
Mind is online now   Reply With Quote
Old 07-31-2008, 10:51 AM   #3
Chiketkd
Member#: 71634
In hibernation...
Cool. Thanks!
I still see no mention of a rear lsd, but after seeing the pro solo starts of the Strelnieks' 135i at Toledo, I don't think this short-coming will be an issue.
Old 07-31-2008, 11:15 AM   #4
KC
Member#: 442
13 Crosstrek XV
00 S2000
You assume it's going to be in DS.
--kC
KC is online now   Reply With Quote
Old 07-31-2008, 11:16 AM   #5
Mechie3
Member#: 120152
What I want to know is, can I use the up/back date rule to put the new turbo on my 06 and either change the IC (free in ESP) or clock the compressor housing and make an adapter to use my current IC. Guess it comes down to is clocking the housing ESP legal.
That would be cool!
Mechie3 is offline   Reply With Quote
Old 07-31-2008, 11:24 AM   #6
CPM
Member#: 58182
I guess this is Subaru's answer to all of the reviews saying that they had gone soft with the new model, more power is always welcome...
CPM is offline   Reply With Quote
Old 07-31-2008, 11:39 AM   #7
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
i dunno, the early WRX was way down on power and styling compared to the later modesl.
i look at it this way. the 08 and newer WRX is a reboot of the franchise.
the 08 WRX is the batman begins of the WRX line up. it was new and fresh and pretty different from what had come before.
the 09 WRX is the dark night of the WRX line up. it is everything the 08 was, and more.
greg donovan is offline   Reply With Quote
Old 07-31-2008, 11:40 AM   #8
Chiketkd
Member#: 71634
In hibernation...
--kC
True. But based on the GS/DS re-org proposal, DS is a safe bet as to where it'll end up. Heck, the 135i ended up in the current DS!
Old 07-31-2008, 11:43 AM   #9
Chiketkd
Member#: 71634
In hibernation...
That would be cool!
Per the rule book, the turbo charger is considered to be part of the engine. If you change the turbo you'll have to change engines as well. However, if the '09 WRX uses an identical engine to your '06 WRX, then you could just swap turbos.
Old 07-31-2008, 11:59 AM   #10
digitalseance
Member#: 104400
169k mile race car
Looks like I need to blow up my 2L motor sometime this year...
digitalseance is offline   Reply With Quote
Old 07-31-2008, 01:04 PM   #11
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
If all goes to plan I'll let you know if its competitive sometime next May
Anyone want to buy a soon to be outdated, and soon to be slower than KC's next RX-8, STX car? Didn't think so.
Scooby921 is offline   Reply With Quote
Old 07-31-2008, 01:05 PM   #12
Chiketkd
Member#: 71634
In hibernation...
Correct. Turn up da boost!!!!!
Nice!
Old 07-31-2008, 02:15 PM   #13
KC
Member#: 442
13 Crosstrek XV
00 S2000
And by identical... *everything down to the last bolt length and width*.
Good luck with that one.
--kC
Old 07-31-2008, 03:01 PM   #14
Chiketkd
Member#: 71634
In hibernation...
Another thing to add is that most current '08 WRX owners are getting about -1 degree of camber upfront. However, caster has improved greatly over the '03-'07 WRXs. The '08+ WRXs get about 6 degrees from the factory (caster improves dynamic camber i.e. car won't lose as much camber during turns). Stiffer spring rates should also help reduce camber loss during turns. On paper, this car is looking quite strong. Hope SOA offers a second wheel option. 17x7" wheels will really hold this car back...
Does anyone know if there are any strut/shock options yet for the '08 WRX or STI? I heard KAIBUTSU (Carris) mention in another thread that he was getting some for his '08 STI - but I'm not sure if they're one-off customs or simply off-the-shelf.
Old 07-31-2008, 09:39 PM   #15
BIGSKYWRX
Member#: 7958
09 GH B+
well I did go one full year w/o a car payment
Old 07-31-2008, 10:37 PM   #16
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Does it have blue wheels?
Old 07-31-2008, 10:39 PM   #17
Butt Dyno
Member#: 17301
is the "dark side"
Even if it does, will it be legal for DS?
I doubt they are off the shelf - probably someone rebuilding stock struts w/ new guts...
Old 08-01-2008, 11:00 PM   #18
Chiketkd
Member#: 71634
In hibernation...
Depends on how it's offered. I'm hoping for a from-the-factory model that comes with either 17x7.5" or 17x8" wheels. We'll see what SOA offers as this new WRX model develops through the years.
I'm staying rwd for the next couple of seasons -- after that I'll see what the future holds!
Old 08-01-2008, 11:47 PM   #19
recnelis
Member#: 92778
2000 Impreza 2.5RS
From what I understand, it will become (or now is?) an off the shelf offering. Assuming the engine stays in one piece, we'll see how they work out at the NE divisionals.
Speaking of engines, anyone know of reliability issues with the 08+ WRX engine?
recnelis is offline   Reply With Quote
Old 08-02-2008, 02:13 PM   #20
wrx wagone
Member#: 97301
2005 WRX Wag-Tow Rig
125 FM - QRE Invader
--kC
I'd think it owuld be in DS. The intent is to speed that class up.
wrx wagone is offline   Reply With Quote
Old 08-02-2008, 02:19 PM   #21
KC
Member#: 442
13 Crosstrek XV
00 S2000
But it now has more power, but AWD. With the track record of the SCCA, they tend to fear that combination.
--kC
Old 08-02-2008, 02:53 PM   #22
wrx wagone
Member#: 97301
--kC
Ah, so move it to BS and let in beat on the RX-8. Might be an even trade.
My money is still on DS.
Old 08-02-2008, 03:08 PM   #23
BIGSKYWRX
Member#: 7958
09 GH B+
my guess is DS as well
maybe Subaru should renew it's relationship w/ the SCCA again, seemed a lot more awd friendly back then
Old 08-02-2008, 04:12 PM   #24
Chiketkd
Member#: 71634
In hibernation...
The way I see it, absolutely DS. It fits the current DS mold -- especially with cars like the MS3 and the new Cobalt SS turbo both of which make 260hp or more. There's also the "white elephant" of the class the 135i that makes a whopping 300hp (which in a mildly prepped state, was 2nd at the DC Pro and won the Toledo Pro Solo in the hands of strong drivers). From the July Fastrack that proposed a GS/DS re-org, it seems like GS will be the FWD LSD class while the new DS will be for RWD/AWD cars.
With F&R open diffs and a front McStrut suspension (i.e. camber limited), this car is definitely not up to running with the RX-8/350Z/968/MR2 Turbo in B-stock.
Old 08-02-2008, 10:49 PM   #25
waktasz
Member#: 86356
2015 s1000r
wheelie monster
I haven't heard of any yet, just the STIs.
waktasz is online now   Reply With Quote
How bad will the Front Rake be ? (wanabe baja truck ? wagon ?) AbACUZ Brakes, Steering & Suspension 2 03-07-2008 10:08 PM
Help a noob. How close will my suspension setup be to a stock WRX wagon-GC (FWD) pittkid333 Brakes, Steering & Suspension 1 04-04-2004 09:05 PM
When will the 2003 WRX be available? Nordstone News & Rumors 42 03-18-2002 04:37 PM
How heavy will the new WRX STI-RA be? XJGPN WRX Forum Archive 2 02-03-2001 03:59 AM
How long will the current Impreza be available? Superu General Forum Archive 7 07-30-2000 04:19 PM
