Old 07-31-2008, 01:57 PM   #1
S.G.D
Member#: 36448
Default rad hoses keep blowing...
can anyone tell me if there are any hoses out there that will work between a version 9 motor and a version 6 rad? i'm guessing a hose for a version 6 car should work?
i'm looking for something like samco, or anything like that.
Thanks.
S.G.D is offline   Reply With Quote
Old 08-02-2008, 08:22 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Is there something else wrong with the cooling system? It just seems strange to me to hear of someone blowing a radiator hose. I've haven't heard of anyone blowing a radiator hose in years - they're just made of higher quality, stronger stuff than they were 20 years ago. Is there some sort of restriction somewhere in the system that is causing pressure to build up in the hose? Were these new hoses that blew?
Pat Olsen
Old 08-02-2008, 10:24 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
also might drop to the cap to a .9bar .. or at least replace your 1.3
Old 08-04-2008, 10:17 AM   #4
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
I was having a problem with them when I swapped my 02 wrx motor in my 00 RS with a koyo. the top hose was slightly kinked, which under vibration, would weaken the hose since it didnt fit right.
im assuming this is similar to your problem. unfortunately i cant help since you have a different setup. All I did was went to autozone with an idea of what the hose would look like, found one that had a section that looked similar and trimmed it to the right size.
KAX is offline   Reply With Quote
Old 08-04-2008, 10:29 AM   #5
S.G.D
Member#: 36448
KAX, i think that might be my problem...also, the STI rad cap wasn't helping, so i took that out and replaced it with stock (just saw your comment jaxx)
the last little problem was a pinhole, the first was a huge split.
i spoke with ECS over pm and they recommended 2.5rs hoses to solve the problem...
Old 08-04-2008, 01:06 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
here ya go
http://cgi.ebay.com/ebaymotors/Silic...1.c0.m14.l1318
these guys are in hong kong but are reliable.. i have ordered a bunch of stuff from them
they ship air usually 4 days from order to delivery
Old 08-04-2008, 01:41 PM   #7
S.G.D
Member#: 36448
amazing, those should fit perfect.
have you used those autobahn hoses before?
edit: just bought them, lets hope they turn out good!
Old 08-04-2008, 03:36 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
currently using them
i had to trim them a bit .. but too long is better than too short and for the price ...
Old 08-04-2008, 04:04 PM   #9
S.G.D
Member#: 36448
yeah, trimming is fine with me. thanks for the heads up on those.
Old 08-04-2008, 06:09 PM   #10
John*G
Member#: 19562
95 coupe
red
The last subaru engine I worked on that kept blowing upper radiator hoses had had the thermostat put in backwards.
John
John*G is offline   Reply With Quote
Old 08-06-2008, 07:49 PM   #11
S.G.D
Member#: 36448
John
that's interesting. what was it acting like aside from blowing radiator hoses? mine is keeping a stable temp when the hoses are intact.
for the record, the two incidents were about 2 months apart.
Old 08-08-2008, 03:30 PM   #12
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
John
If you use an OEM thermo I didn't think that was possible since the outlet chamber is too small.
hoses keep blowing off platinumstar17 Built Motor Discussion 3 10-15-2009 07:16 PM
Intercooler hose keeps blowing off! DigitalPunk Newbies & FAQs 16 07-11-2007 03:34 PM
Dammed APS fmic hoses keep blowing off!! shgilman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 60 12-19-2006 05:43 PM
HELP - Intercooler Hose Keeps Blowing off!! 2.5GT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-10-2003 04:36 PM
IC hose keeps blowing off. Mancini Normally Aspirated with bolt-on Forced Induction Powertrain 12 09-28-2003 05:24 PM
