Old 08-01-2008, 01:19 AM   #1
Sean2.5Black
Member#: 150647
98 Impreza 2.5RS
Ej20G hybrid
Default Help!!! EJ20G/RS frankie
Hey guys, I'm here basically to make sure I don't forget anything while doing the swap....
I'm swapping an ej20g short block with my PnP DOHC RS heads into my '98RS with Delta mild cams.
This may be a stupid question/inquiry but I've never done it before, so I really have no idea where to start lol.
I'm drilling/tapping the heads for the oil lines for the turbo, and using my RS intake manifold for the EGR bypass, since I'm OBDII lol.
Here's my list so far:
RS Head gaskets
Exhaust gaskets
Cam cover gaskets
ACT clutch set
Stock UP
3'' Custom TBE
VF10
I feel like I'm missing a couple huge things.... So don't laugh too hard @ me
Sean2.5Black is offline   Reply With Quote
Old 08-02-2008, 03:51 AM   #2
DSM_Outback
Member#: 56345
93 Swapped L
Green
I was going to go that direction until I measured the cloverleaf shaped chamber bore on the EJ25D heads in comparison to the EJ20G bore...large potential for head gasket problems.
DSM_Outback is offline   Reply With Quote
Old 08-02-2008, 05:05 AM   #3
Sean2.5Black
Member#: 150647
98 Impreza 2.5RS
Ej20G hybrid
Which headgaskets would you be using? And what if I were to use thicker/thinner gaskets?
Old 08-02-2008, 03:58 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Hes not saying the headgasket is the problem, rather the DOHC head design.
You should plug your numbers into a compression ratio calculator. The DOHC heads have less volume than the original EJ20 heads so the compression ratio will be higher. "RS Headgaskets" is not specific, the DOHC gasket is nearly three times the thickness of the SOHC unit.
If it were me I'd be going the total opposite direction - EJ25 block with EJ20 heads.
Old 08-02-2008, 09:49 PM   #5
Sean2.5Black
Member#: 150647
98 Impreza 2.5RS
Ej20G hybrid
I meant to say the DOHC heads, forgot to mention that :-X.
I thought about that, and turbo'in my block, but I don't want to look into internals and definately don't want to worry about blowing up the open decked mofo. lol.
Old 08-04-2008, 12:58 AM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
Just for ****s and giggles I'll try to remember to bring a camera with me tomorrow and Ill take pictures of a phase 2 EJ25NA and a 2003 WRX EJ20. I dare you to figure out which is which! The idea that the NA blocks are so much weaker than the turbo blocks (crank/pistons/rods aside) is blown out of proportion on Nasioc.
Either way if you need any extra parts I may have them. I've got a complete DOHC engine and a few WRX engines with different types of damage but lots of good left over parts.
Boost Leak Help EJ20G clean 93 Pre-2002 Factory Turbo Powertrain 5 06-08-2010 08:48 AM
please help ej20g swap in 2000rs ecu not gettingpower GregBolby Subaru Conversions 3 07-23-2009 07:00 PM
Help - EJ20G Data log inside Zora Pre-2002 Factory Turbo Powertrain 23 04-27-2009 10:45 AM
HELP, EJ20G coolant line with RS Radiator? xlur8ed Pre-2002 Factory Turbo Powertrain 6 04-23-2008 03:17 PM
help! ej20g swap single turbo or twin? nmbwhitey Newbies & FAQs 2 03-11-2008 10:15 PM
