Notices
Old 08-02-2008, 01:00 AM   #1
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
Default Does the JDM WRX MY2006+ have an immobilizer
So I am looking to do a swap into my BD Legacy, and I was looking at the EJ255, but it looks like the immobilizer, at least on the USDM ones, makes that swap a pain in the ass. Do the JDM WRX's have it as well?
RallyLegacy is offline   Reply With Quote
Old 08-02-2008, 11:53 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hard to say
jdm motors had imobilizers as early as 97
the only jdm 255 i have seen have been the fxt/sti fxt .. the jdm wrx is still 2.0 (tax reasons)
Old 08-02-2008, 04:08 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The swap isnt a pain in the ass if you get at least one key with the immobilizer ECU combo. Only the key and antenna need to be near each other... no one said the key that starts the car needs a chip in it!
Besides you could always rewire it to use a 2004 STI ecu.
Old 08-03-2008, 06:38 PM   #4
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
Originally Posted by Jaxx View Post
hard to say
jdm motors had immobilizer as early as 97
Ok I thought I saw something that said all MY2006+ WRX's were EJ255, but I guess that must have been wrong. I will probably go JDM because so far that is where I have found the best deals, so I guess it is probably easiest just to get an EJ205 and not have to worry about the immobilizer and still have more power than the USDM EJ205 because of the AVCS.
Any other opinions on the mater?
Thanks
edit: do any of the JDM WRX GD EJ205 have immobilizers?
Old 09-04-2008, 01:22 AM   #5
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
bump for any info. what newer wrx ej205's don't have the immobilizer?
Old 09-04-2008, 12:52 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
as a factory option only
Old 09-05-2008, 12:31 AM   #7
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
so then all the cars with the factory option immobilizer would have an ecu that would require the immobilizer unit and the key? If so does anyone know how to tell the difference between the two so I could make sure to get a non immobilizer ecu for my swap?
Old 09-05-2008, 11:21 AM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
as far as i can tell the jdm 20k/207/205 immobilizer is different than the 255/257 its a single pin on the ecu and some slightly different wireing which you should be able to get around .. i have never seen one but its in the diagrams
basically i wouldn't worry about it if your after a 205 usdm or jdm
Old 09-05-2008, 08:50 PM   #9
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
cool, thanks for the info. One more question, did the jdm wrx's go drive by wire in 2006 like the usdm ones, or where they before/after?
Old 09-06-2008, 03:16 PM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
not that i know of ...
but i am unsure
how well does the stock WRX RE92's from an 06 (215/45/17) fit on the JDM ver 7 rims? Nettalp Tire & Wheel 4 12-18-2006 08:35 PM
how well does the stock WRX RE92's from an 06 (215/45/17) fit on the JDM ver 7 rims? Nettalp Tire & Wheel 0 12-18-2006 03:28 PM
Does the stock CD player have an AUX input? SilverE2 Newbies & FAQs 5 01-24-2006 04:38 PM
Does the JDM WRX (Non STI) neuspeed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 06-22-2004 11:02 AM
Does the GC8 sedan wing have an LED? edkwon Interior & Exterior Modification 3 05-06-2002 10:26 AM
