Old 08-02-2008, 09:56 PM   #1
EastsideLegacy
Member#: 58806
1998 RIP Legacy2.5GT
2.2L legacy wagon
Default 95 2.2l to 98 2.5l legacy
Can i swap a 98 2.5L DOHC legacy motor into my 95 2.2L Legacy without any major wiring ?
Thanks for any response
EastsideLegacy is offline   Reply With Quote
Old 08-02-2008, 10:02 PM   #2
gtwagon941
Member#: 16874
2008 Audi RS 4
01 Subaru LGT Sedan
There won't be much wiring I don't believe. I swapped my 98 2.5L out for an EJ22 with only minor wiring issues (speedometer and temp gauge type things).
Definitely make sure that the EJ25 is "healthy" though.
JS
gtwagon941 is offline   Reply With Quote
Old 08-02-2008, 11:07 PM   #3
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Honestly the 2.2 while a tad down on power is generally more durable, and seems to produce a bit more low-end torque. You are better off sticking with the 2.2, IMHO.
Jonathan is offline   Reply With Quote
Old 08-03-2008, 12:24 PM   #4
EastsideLegacy
Member#: 58806
2.2L legacy wagon
Gtwagon so what your saying as long as everything plug and plays it will work ?>
Old 08-03-2008, 01:09 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
There is something you have to do for the cam/crank sensors. You need to have a certain type(# of triggers on it IIRC). Unfortunately, I dont know the details, just that you need to swap something on the DOHC motor, to put it into a SOHC car.
~Josh~
Old 08-03-2008, 01:49 PM   #6
EastsideLegacy
Member#: 58806
2.2L legacy wagon
It isn't the heads is it because i didn't really wanna mess with the timing from 2 separate motors because it doesn't seem like it would go well......
I have a ECU for the DOHC motor if that would help my situation..
Thank you for the responses.
Old 08-03-2008, 02:12 PM   #7
Kansei
Member#: 173080
1997 Legacy 2.0 GT
Forest Green Metallic
You will have alot of problems with the wiring due to the fact 95=OBDI and 98=OBDII. sorry. man.
Kansei is offline   Reply With Quote
Old 08-03-2008, 02:45 PM   #8
EastsideLegacy
Member#: 58806
2.2L legacy wagon
i do have the OBDII plug for my car though....... idk if it makes a difference.
Old 08-04-2008, 12:19 AM   #9
EvenSteven
Member#: 156542
Default .
95 Subaru's did come with OBD2.
EvenSteven is offline   Reply With Quote
Old 08-04-2008, 11:10 AM   #10
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Not all 95 Subarus, but 95 Legacy/Outbacks came with ODB2.
jey is offline   Reply With Quote
Old 08-13-2008, 06:17 PM   #11
EastsideLegacy
Member#: 58806
2.2L legacy wagon
So back to my original question just a few splices of wires and ill be good to put the 2.5 in ?... Im a experienced mechanic i just don't know exactly if i wanna throw the motor in and it not work so i have to take it all back out again.....
my 2.2L is on its way to death very soon so anybody that has done this or knows for sure please input me.. ha.. but yea
also I cant find the tread anymore but i remember on one forum they said that the 2.2L ECU and the 2.5L ECU are the same .... is this true?
Once again thank you for the responses
Old 08-14-2008, 10:49 AM   #12
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
The thread was concerning whether or not a 98 GT ECU would run a 96 GT engine. Both those engines are DOHC but the 96 GT is specced to run on higher grade fuel but puts out less hp/tq than the 98 GT.
Huffer is offline   Reply With Quote
Old 08-15-2008, 06:26 PM   #13
EastsideLegacy
Member#: 58806
2.2L legacy wagon
No i was referring to a thread that's not recent... one that i can not find... yea so thanks anyway.
no one knows..?
Old 08-15-2008, 11:30 PM   #14
gtwagon941
Member#: 16874
2008 Audi RS 4
01 Subaru LGT Sedan
Not sure if they are the same, but in my 98 LGT the 2.2 ran on the 2.5 ECU. I ended up using the 2.2 ECU since I had it, but the car ran on both of them...
JS
Old 08-16-2008, 08:05 AM   #15
pheonix991
Member#: 154173
2006 STI
Make sure before you put it in, change the headgaskets. I don't care if the new motor has 50k miles, change them! They will blow, just a matter of time. Might as well make sure it will happen later than sooner.
No clue if the motor will work in that car though.
pheonix991 is offline   Reply With Quote
Old 08-16-2008, 03:15 PM   #16
EastsideLegacy
Member#: 58806
2.2L legacy wagon
bump for anyone that has done the swap ... also the motor that im putting in appears that the head gaskets and heads were done before..
Old 08-17-2008, 02:34 AM   #17
gtwagon941
Member#: 16874
2008 Audi RS 4
01 Subaru LGT Sedan
did you post in the conversions thread? I guarantee there are people there that know this.
JS
95 2.2L Legacy to 98 2.5L DOHC EastsideLegacy Subaru Conversions 32 01-29-2009 06:57 PM
95 1.8 to 98 2.2 swap jahwarrior007 Subaru Conversions 2 10-24-2008 08:34 PM
Anyone Done A 1997 2.2l To 98 2.5rs??? TurboCharged97L Subaru Conversions 6 09-03-2006 09:41 PM
01' 2.2 engine in 98 2.5L Legacy? afterbangin Subaru Conversions 4 02-02-2006 01:10 PM
How much to mod 2.2L to =2.5L hp OSUBeaver Normally Aspirated Powertrain 27 03-26-2003 11:21 PM
Message Board Statistics All times are GMT -4. The time now is 05:49 AM.
