Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 08-02-2008, 11:23 PM   #1
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Talking rear CEL fix works..so far
So I kept getting a CEL for my rear o2 sensor saying it was below threshold bllabha, and it would also trigger a coolant temp sensor code too. apparently from what i understand, the two can set each other off. i called up the auto parts store today and asked for a coolant temp sensor, it was $40 but i decided to hold off and try using the anti-foulers first as i got the set for like $6 lol.
im using an hks catless downpipe
my car is a 96 impreza brighton 1.8L coupe...home made turbo kit using erz up pipe, td04, hks d/p, fmic, etc..
Usually the code would kick in after 50 miles but so far ive driven close to 70 today and no CEL's with the fix.
I tried the old spark plug anti-fouler trick, using 2 "HELP!" brand spark plug anti-foulers, i drilled one of them out gradually using a small bit then finally working my way up to a 1/2 inch drill bit, this enabled the bulb part of the o2 sensor to fit in it
Fortunetly for me my car is a 96 brighton, and yes it is OBD-II however all 96 subarus are I/M Readiness test exempt so this thing passed nj inspection totally catless..alls it had to do was go through without a CEL..however i did fail for bald tires the first time, lol
I know this place is pretty dead these days but I am wondering if anyone here is obdII and using this trick and is catless..and getting the i/m readiness status to complete and pass all the tests. (ie 97 and newer subarus)
here are the pics. i had to take the splash guard cover off and drill a hole in it so i could fit the o2 sensor through it so it would thread in. i had to drill it out then take a pair of tin snips and peel the rest of it off like a can opener
mxpunk is offline   Reply With Quote
Old 08-02-2008, 11:47 PM   #2
front runner
Member#: 121603
2001 legacy BH
blue
I've had this fix for almost a year. Passed obd2 emissions with no problem. I was completely catless with backfires and all. Washington doesn't care as long as the computer says you're good to go.
front runner is offline   Reply With Quote
Old 08-03-2008, 12:25 AM   #3
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
does WA require i/m readiness to be complete? i know some states let you pass if you have a CEL but only 2 codes have to be shown or something. im just curious about im readiness really..
Old 08-03-2008, 12:34 AM   #4
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
What the heck is an anti-fouler? I understand that your trying to get the CEL to not come on, but I don't understand what the spark plugs have to do with it. Please explain with pics or something.
I tried making a threaded spacer that the rear O2 sensor screws into. I welded that on my mid pipe, and this allowed the sensor to be pulled out of the exhaust stream a little. I was copying a CEL fix I saw on a vendors site. It works most of the time but still throws the code every once in a while. I haven't worried too much though because I don't have emissions, but just wanted no CEL's on my car.
morrocco88 is offline   Reply With Quote
Old 08-03-2008, 10:26 AM   #5
Fail Wagon
Member#: 133584
That is what an anti fouler is. You can buy spacers for spark plugs that thread onto our rear o2 sensors. Any auto parts store should carry them, worked for me too. Surprisingly the only code I have thrown is for my egr and its because I just plugged the hole that goes down to the stock head. Garris did you do something to the ecu to trick it into thinking the egr is there? mines still on because I didn't want to make a plate but I'll throw the code every once in a while
Fail Wagon is offline   Reply With Quote
Old 08-03-2008, 10:46 AM   #6
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
I just made a plate to block it off and I think I left the wiring plugged in. I do not get any CEL's from any EGR stuff.
Old 08-03-2008, 10:53 AM   #7
Fail Wagon
Member#: 133584
hmm. maybe i should just pull mine off
Old 08-03-2008, 11:48 AM   #8
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
its some ghetto band-aid fix if your car has a blown ring and is burning lots of oil and is fouling plugs bad..its just a threaded spacer. apparently spark plugs and o2 sensors share the same threads, thats why they're used lol.
it just pulls the sensor out of the stream alittle bit and tricks it into acting like a CAT i suppose.
Old 08-03-2008, 01:56 PM   #9
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Thanks for the pics! It looks like it just pulls it out of the stream a little like the others that some vendors sell. That is what I did, but I just wasn't sure how far to pull it out of the stream. I didn't bring it out as far as you did in those pics and maybe that is why i still throw the code sometimes. I have been meaning to try pulling it out a little bit more, but I don't have emissions so it's been a little low on the to do list. Great find though for a easy way to get a threaded spacer. How much do those cost from the parts store?
Old 08-03-2008, 02:25 PM   #10
Fail Wagon
Member#: 133584
hey man i think i may have an extra one, if i do i'll just mail it to you if you want. they come in packs of 2 but they are like $8-10
Old 08-03-2008, 02:48 PM   #11
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
it was like $7 after sales tax here in dirty new jersey..7% sales tax is gay.
any auto parts store should have them..i got mine @ pep boys.
Old 08-03-2008, 03:16 PM   #12
Fail Wagon
Member#: 133584
you think 7% is gay. try 8.047% in WA
Old 08-03-2008, 09:18 PM   #13
Spilner
Member#: 63977
2005 STi
see, I told you it would work! now buy some EM dammit!
Spilner is offline   Reply With Quote
Old 08-03-2008, 10:11 PM   #14
davedaman77
Member#: 177385
08 2.5i
SSM
9.25% in TN!!!!!!!
I'm f***ing moving to WA or NJ!
davedaman77 is online now   Reply With Quote
Old 08-04-2008, 03:15 AM   #15
Fail Wagon
Member#: 133584
damn. that sucks
Old 08-04-2008, 09:26 AM   #16
quickline23
Member#: 174513
04 wrx vf39 Ewg
STi Mikey Tuned!!
its 6% in pa
quickline23 is offline   Reply With Quote
Old 08-04-2008, 12:52 PM   #17
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
close to 100 mile and still CEL free. ill keep this updated. usually it would of came on in the morning and threw a coolant temp code. ill need to check the pending codes with my obd2 scanner.
Old 08-04-2008, 07:51 PM   #18
front runner
Member#: 121603
2001 legacy BH
blue
Yep, Wa does require the ecu readiness to pass. So you can't erase codes and go get tested. Also, they won't test you if the light is on.
Old 08-05-2008, 12:41 PM   #19
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
^ sweet
CEL came on this morning..coolant temp sensor though. no o2 cels yet
getting a sensor today or tomorrow hopefully
Old 08-05-2008, 02:18 PM   #20
bubba2533
Member#: 175483
13 WRX 5-Door
So any anti fouler will work?
I saw a few at autozone and they looked to be different so I didn't buy one.
I will be putting an exhaust on my car and just want to be ready for the cel
bubba2533 is offline   Reply With Quote
Old 08-05-2008, 03:03 PM   #21
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
They have different parts for different sizes. You want the 18mm one: the Help brand is part #42002
jey is offline   Reply With Quote
Old 08-11-2008, 12:52 PM   #22
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
got the new coolant temp sensor in and have done a considerable amount of driving, 100+ miles
no cels at all! and the driving has been anything from full throttle runs, twisty road runs and highway cruising for prolonged periods of time.
yey!
Old 09-24-2008, 12:33 AM   #23
mikeis300
Member#: 149526
2002 aps dr65 hybrid
9.1x1 built block/heads
0% sales tax in oregon
mikeis300 is offline   Reply With Quote
Old 09-24-2008, 10:09 PM   #24
j1168osh
Member#: 105609
2002 wrx
psm
bump to the top
j1168osh is offline   Reply With Quote
does the cel fix work? rhado307 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-27-2006 11:45 PM
Will the Helix electronic CEL fix work? EddieC168 Newbies & FAQs 9 01-16-2006 05:19 AM
Will the WRX CEL fix work for us? cvalle-sd Normally Aspirated Powertrain 5 06-23-2003 03:20 PM
Does Scooby Sport CEL fix work? PunksWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 02-17-2003 12:11 AM
Scooby Sport CEL fix works! PunksWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-17-2002 07:03 PM
