Old 08-03-2008, 04:38 AM   #1
Jimmy168
Member#: 173614
2007 STI
Default Sleeve vs Bore the ej257 which one is better?
I am wondering i should bore or sleeve my short block for my 07 sti? cuz right now my cylinder was little bit scratch due to one of the piston cracked. If in case of bore my cylinder, do i really need to have a oversize piston if my engine only have 9000 miles on it? cuz i bought a set of standard size piston. is it possible to keep using standard size piston after bore
Jimmy168 is offline   Reply With Quote
Old 08-03-2008, 12:26 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
How bad a scratch? Thats the question. And it has too be REALLY bad not to be able to bore out. Sleeving is out of the question, totally not needed.
Often you can hone a scratch out and still use stock size pistons. You really need to just take it to a machine shop and have them inspect it.
Old 08-03-2008, 06:50 PM   #3
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Just buy 100mm pistons send it in to the machinist to properly bore the block to the correct p/w clearances. Make sure they check for the deck straightness and ra surface of 20 or better.
methaddict is offline   Reply With Quote
Turbo manifold, Tomei vs HKS which one is better? Jimmy168 Newbies & FAQs 6 05-04-2008 02:13 AM
Short ram intake VS PDM/GANZ flow intake & K&N filter, which one is better? anonymous_wolf Normally Aspirated Powertrain 4 03-21-2005 07:13 PM
vf 23 vs vf 24 which one is better teamslow wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-15-2003 12:57 AM
Apex'i N1 or 5zigen Fireball exhaust, which one is better? PhilWanted Normally Aspirated Powertrain 5 04-09-2001 05:17 PM
Which one is better? Miracle Worker Mid Atlantic Impreza Club -- MAIC 9 12-08-2000 01:31 PM
