Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 08-03-2008, 01:49 PM   #1
Sparky280
Member#: 69896
98 WRX Swapped "L"
VF39 294HP/277TQ @19psi
Default swap issue
hey all i just finished up my swap (03 ej20 in 98L) and i have been attemping to start it for the past hour or so and it won't stay running. It fires for second and then stops. The fuel pump primes and main relay clicks, my OBD scanner only pulls like 4 codes that are TGV related (i have them deleted) so there's nothing much there. I am waiting for a friend to come over with a fresh mind and a fuel pressure guage. I am running out of ideas on what could be the cause. I resued my camshaft sensor from my 2.2l engine is that an issue? Anyone have any ideas on other things i should check?
Sparky280 is offline   Reply With Quote
Old 08-03-2008, 02:27 PM   #2
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
I would start by using the right cam shaft sensors, was the motor already assembled? Did you check timing marks make sure they all line up correctly? any other parts reused from the 2.2? Do you have the correct crankshaft sprocket ? Any other codes besides the tgv's ?
sense of nature is offline   Reply With Quote
Old 08-03-2008, 02:55 PM   #3
Sparky280
Member#: 69896
98 WRX Swapped "L"
well the engine was assembled but I dissassembled it and put new gaskets/seals along with a new timing belt and i lined up all the timing marks and all the sprokets were lined up perfectly. the only thing i used from the 2.2 was the A/C pump, misc nuts and bolts and the camshaft sensor. Only codes i got were TGV related P1086, P1088, P1094, P1096.
Old 08-04-2008, 12:58 AM   #4
Sparky280
Member#: 69896
98 WRX Swapped "L"
OK she runs now! Not sure what it was exactly, but i think it just had alot of air in the fuel system or it could have been the MAF since i pulled it out and cleaned it and after that she started right up. I only have a downpipe on now so it's loud! exhaust should arrive this week and will get this baby on the road!
Old 08-04-2008, 01:07 AM   #5
parkes
Member#: 166898
1994 T leg SS
ABM
Nice man, i was reading along ( I too reused my Camshaft sensor) and got a lil scared, Show us some pics! and Videos?
parkes is offline   Reply With Quote
Old 08-04-2008, 01:31 AM   #6
Sparky280
Member#: 69896
98 WRX Swapped "L"
will get a vid soon but here's the latest pic with my new hood dampeners
Old 08-04-2008, 02:13 AM   #7
parkes
Member#: 166898
1994 T leg SS
ABM
Awesome, more pics!
Old 08-05-2008, 10:10 PM   #8
Sparky280
Member#: 69896
98 WRX Swapped "L"
start up video HERE
Still no exhaust and after the video i started having some funky idle issue i'm getting a vac leak somehwhere near the throttle body will figure that out tomorrow..
Couple swap issues, JDM EJ205 moss Subaru Conversions 35 05-06-2006 03:41 AM
WRX swap issues. sidewayz Subaru Conversions 23 02-27-2006 11:11 PM
Frankenstein swap issue...TGV's RS_to_WRX_swap Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-02-2005 03:50 PM
EJ22T swap issues Volksabu Subaru Conversions 7 05-15-2005 11:40 PM
HELLLPPP!!!! engine swap issues shipjumper Legacy Forum 6 12-09-2002 03:27 PM
