Welcome to the North American Subaru Impreza Owners Club Wednesday September 24, 2014
Old 08-03-2008, 04:31 PM   #1
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
Default WTH happened to my subie?
I think my transmission died, I had the torque bind issue with my car since I got it.
But a few days ago, I experienced a weak reverse..the car would rumble/hop while going backwards in reverse.
now today, it does the same in D/3/2/1. I was driving at 20mph out of a parking lot and the transmission stopped engaging, and the RPM would almost redline and not engage so the car pretty much idles to a stop, till I have to restart it, put it in D and see if it'd move forward by pressing the gas, thent hat'd work for a few meters then it'd die out again until I restart. Sometimes it took multiple restarted to go a few more feet.
Transmission is shot, isn't it?
kirbykirb is offline   Reply With Quote
Old 08-03-2008, 05:03 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
5MT/6MT swap time!
fibuz is offline   Reply With Quote
Old 08-03-2008, 05:11 PM   #3
airgne
Member#: 178235
01 Legacy Gt Ltd.
Titanium Pearl
Originally Posted by fibuz View Post
5MT/6MT swap time!
hell yeah!!!!!!!!!
airgne is offline   Reply With Quote
Old 08-03-2008, 05:14 PM   #4
kirbykirb
Member#: 183596
2005 WRX/9-2x
Originally Posted by airgne View Post
hell yeah!!!!!!!!!
NO!
NO disco, no happy banana! no Swap!
That is unless you're volunteering to pay for it
Old 08-03-2008, 05:18 PM   #5
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
rofl, awww come on, cheer up!
Have you tried the FWD fuse trick thing to see if that makes any difference?
Old 08-03-2008, 05:21 PM   #6
airgne
Member#: 178235
01 Legacy Gt Ltd.
Titanium Pearl
Originally Posted by kirbykirb View Post
NO!
awww. dont be a poor sport. i know your car is right now, but hey just think how fun it would be with a sti tranny.
Old 08-03-2008, 06:40 PM   #7
kirbykirb
Member#: 183596
2005 WRX/9-2x
Well yeah, of course it'd be fun. But 3K+ for that setup = more then my car cost.
So, FTL.
I think I'm just going to grab another transmission and slap it in. And keep this one out and have it rebuilt or something.
Old 08-04-2008, 07:00 AM   #8
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
it MIGHT just be the torque converter that let go... then again it might be some more expensive 'bits'. Have you checked your ATF fluid ??? What does it look like ?
Jonathan is offline   Reply With Quote
Old 08-04-2008, 07:33 AM   #9
kirbykirb
Member#: 183596
2005 WRX/9-2x
When I checked ATF Fluid a few mins after I turned the car off it's in the HOT section so I assume thats normal for the fluid..
the weird part is when I just checked it, and the car has been off for 12+hours its in the same location a bit over hot.
Old 08-04-2008, 10:22 AM   #10
that one legacy
Member#: 103665
have you messed with the engine at all lately? replaced an air filter? taken out the snorkus? last time i had the problem you're describing it ended up being a loose vaccum line on the intake arm.
that one legacy is offline   Reply With Quote
Old 08-04-2008, 01:31 PM   #11
kirbykirb
Member#: 183596
2005 WRX/9-2x
No, it just died on me in the parking lot. Stop doing anything, and its as if the car is in N in any position.
Sometimes it may engage. Alot of times it dosen't.
Old 08-04-2008, 03:41 PM   #12
kirbykirb
Member#: 183596
2005 WRX/9-2x
was driving down the highway going about 55mph, and was going up a hill and when the engine went to downshift to get up the hill, it shifted out of gear and the engine just reved up. I pulled off the highway and tried just about everything to get it going, no luck. It wouldn't go into Reverse, Drive, 1st or 2nd gear... basically nothing. When you take it out of Park and move the needle to a gear, you can't feel or hear any change like you normally do when you shift into gear.
suddenly my RPM was
at 5000. The car shifted out of gear on its own. I stopped and
attempted to put it into gear, but it wont go, any any gear, reverse
doesn't work. The fluid was changed about 1000 miles ago, and the
transmission drove excellent before, no slips or delays at all. I use
the shifter a lot to down shift frequently, could it be the electrical
piece the shifter linkage connects to. The fluid is not low or over
filled and is not burnt. Vacuum line is connected as well. Any ideas?
Again it drove fine before, had no signs of eminent failure. The
reverse lights come on when in gear also.
this is pretty much what I'm feeling.
Old 08-04-2008, 05:53 PM   #13
Chi_San
Member#: 53558
2002 WRX Wagon
Sad this happened to such a rare car.
Take it to a shop and have them tear down the gearbox, but in the end, you will probably spend as much as a 5MT swap would cost to get it fixed.
Chi_San is offline   Reply With Quote
Old 08-04-2008, 06:35 PM   #14
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
I wish my AT would blow up so I could get a manual swap.
monovich is offline   Reply With Quote
Old 08-04-2008, 06:56 PM   #15
kirbykirb
Member#: 183596
2005 WRX/9-2x
So Tranny is shot?
only way to fix it, is to slap another transmission in there right?
Old 08-04-2008, 08:40 PM   #16
Chi_San
Member#: 53558
2002 WRX Wagon
Well, it probably can be fixed, but in the end, combining parts, labor, and down time, it might be cheaper to get a manual transmission and swap it, or do another 4EAT. But, remember, your car is 12 years old, things are gonna break on it. I'd recommend doing a 5MT swap, since the 5MT has fewer parts to break than a 4EAT. Aside from the gears, you've got valves and other associated hydraulic components in a 4EAT, and if one of them goes bad, it could theoretically wreck the entire gearbox in a 4EAT. IMO, 5MT, even from a 1997-1999 LGT or Outback would be the way to go.
Old 08-05-2008, 02:52 PM   #17
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
Just to keep your options open though, if you do choose to stay with the AT, a rebuilt or one from a junkyard is cheaper than messing with your broken one.
Much less labor to just swap one out rather than trouble shoot and diagnose.
runninstrong is offline   Reply With Quote
Old 08-06-2008, 04:32 PM   #18
kirbykirb
Member#: 183596
2005 WRX/9-2x
So,
Found out it was Duty Solenoid C, the same thing which causes Torque Bind.
Transmission is Toast, but it's okay. It's win win win situation, I'd put in a new transmission which would act like new, fix Torque Bind and Get my car running again in less then a day or two.
\Now I need to find a mechanic to do the work.
WTH happened to my threads??? QuikWgn North West Impreza Club Forum -- NWIC 2 11-25-2006 04:01 PM
WTH happened to my radio station? pink-i Off-Topic 69 10-31-2006 05:59 PM
WTH happened to Clubwrx.net WRXturboAWD Rocky Mountains Impreza Club Forum -- RMIC 23 08-30-2004 01:15 PM
WTH happened to the "Detailing?" thread? kenzo New England Impreza Club Forum -- NESIC 1 05-25-2004 10:27 AM
WTH happened to Structure? 4x4GGG Off-Topic 64 12-17-2002 02:48 PM
