Old 09-11-2008, 08:32 AM   #26
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Originally Posted by SaabTuner View Post
Also, don't forget the gears in your transmission. Those are prime targets for DLC coatings, as are the bearings, if they can be removed. Gear friction is a major source of transmission losses, and gear/bearing wear is usually the long-term tranny killer, if outright power doesn't kill it first.
my only question with that would be thermal relationship. How hot would the gears then get?...would the coating keep them cooler (because of reduced friction) despite it shedding oil quicker?
I'm a fan of DLC and WPC treatments both...some for certain parts more than others.
and I think we all have a man crush on you, Adrian
Old 09-11-2008, 07:44 PM   #27
SaabTuner
Member#: 67608
ta-C DLC conducts heat extremely well, for one thing. Secondly, every time I've seen research done with dry-film lubricants in transmissions, even those which do not conduct heat particularly well (and also shed oil), like MoS2, the gear temperatures always went down.
Since ta-DLC conducts heat so well, and lubricates extraordinarily well, it should be ideal for the job and should cause a decrease in gearbox temp, and transmission losses, with an increase in gearbox life.
Your wallet ... on the other hand ... may become terminally damaged.
-Adrian
SaabTuner is offline   Reply With Quote
Clearance! Clearance! Everything Must Go! Fizz Autosports Wheels/Tires 52 01-24-2009 07:45 PM
Clearance! Clearance! Everything Must Go! Fizz Autosports MWSOC Vendor Classifieds 0 12-23-2008 05:03 PM
Kartboy Endlink Combo Clearance! Tein Super Clearance Sale! Cusco/Perrin Swaybars!!! Spun Autosports Suspension/Brakes/Handling 31 01-31-2007 11:24 PM
35 Cobb Access Ports in Sock! TurboXS Clearance Perrin Clearance Blitz Greddy Invida Spun Autosports Engine/Power/Exhaust 58 08-31-2006 07:26 AM
