#1 |
Member#: 158766
South East
Vehicle:2002 WRX 2001 GSXR 750 |
Today i wired in my aem serial gauge, i used the 12v wire from the stock clock pin connector and then grounded it to the the glove box support. Gauge works fine but after startup i noticed my radio doesnt turn on anymore, but the radio buttons light up just not the info display, I also noticed my cabin light not longer works, I checked the radio fuse in the car and it was fine.
Any ideas ? ![]() ![]() ![]()
#2 |
Member#: 53443
Vehicle:2001 LL Bean Outback Winestone |
It sounds like you tied into the dash lights control power not the normal power for the clock. You have also blown a fuse somewhere it appears. Check the panels under the hood and the dash.
#3 |
Member#: 158766
South East
i also noticed that my trip meter works when im driving the car but resets after i turn the car off.
#4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
Check the fuses in the box under the hood, you blew one.
#5 |
Member#: 186195
Vehicle:2004 STi Black |
#6 |
Member#: 53443
Check fuse #2 in the main panel under the hood. If that is ok then there may be a bad wire connection coming from it.
#7 |
Member#: 186195
#8 |
Member#: 158766
South East
i took them all out and they appeared to all be fine, however when i get my test light i found that one was broke even though it didnt look it replaced it and all is good
thanks |
#9 |
Member#: 157634
RMIC
Vehicle:2007 STi CGM |
Glad to hear you figured it out. I did the same thing in the middle of the winter and had to drive around without interior lights/key fob in the snow for about a month.
| Thread Tools | |
| Display Modes | |
| Gauge install now radio/keyless entry not working | MGAMAN | Electrical & Lighting | 6 | 06-10-2007 10:55 PM |
| Keyless entry not working... | cghe25i | Car Audio, Video & Security | 4 | 01-16-2007 05:13 PM |
| 00 rs keyless entry not working | mrchau | Car Audio, Video & Security | 4 | 11-23-2003 04:37 PM |
| keyless entry not working | WRXturboAWD | Electrical & Lighting | 2 | 10-27-2003 02:24 PM |
| OT: keyless entry won't work on wifes firebird | ChosenWon | Technical Forum Archive | 1 | 09-01-2000 04:48 PM |
