Old 08-03-2008, 10:44 PM   #1
Thunder STI
Scooby Scammer- Do Not Buy From User
Member#: 172656
Default Need Suggestions: Huge Power !!
Thunder STI is offline   Reply With Quote
Old 08-03-2008, 11:26 PM   #2
SniperSVD
Member#: 168633
you could stay with the t4 flange and get a 37r turbo. that way you won't have to get 1 off headders made, i think the 37r is good for 700hp+
SniperSVD is offline   Reply With Quote
Old 08-03-2008, 11:50 PM   #3
bertune
Member#: 107290
Consistent tens with 520whp on stock internals! ........I honestly do think you are the one that should be giving us some advice!
bertune is offline   Reply With Quote
Old 08-04-2008, 04:54 AM   #4
cubuff
Member#: 38345
2004 WRB WRX
Jumping to the t4 would be your best bet. Stay away from the "37r" it isnt a very good turbo and as geoff from fullrace told me there is nothing "r" about this turbo. Its old! Go with a 40r or something similar with a twinscroll setup and have slightly less spoolup time compared to your 35r but about 100 more whp possibly more? Or you could do what I am going to do and get a twinscroll borg warner s366 and gun for north of 700whp with that!
cubuff is offline   Reply With Quote
Old 08-04-2008, 10:11 AM   #5
Thunder STI
Member#: 172656
Thanks for the advice, I will read up more on that.
Also, any suggestions on how I should go build my own engine or go some type of short block ?????
Old 08-04-2008, 10:43 AM   #6
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
700hp all boost ull need to go with a GT42R imo....
a GT40R will just get u 600 hp atw...
Engine will need to be built i,e sleeves as a minimum and CD if ur keen... heads will need to be ported with atleast 1mm oversize valves and cams...
tino is offline   Reply With Quote
Old 08-04-2008, 11:04 AM   #7
bertune
Member#: 107290
To my understanding there is an older GT37, that is not the same 37R that most talk about now. I think the 37R was introduced by AMS and it is not an off the shelf turbo, what it actually is, it's a ball bearing version of a T67 turbo. Evos are known to make the kind of power you are looking for with the 37R, i personally made 638whp @ 28psi with a 37R and a T3 housing (subi), i was looking for 680+ out of it but i do think the T3 housing is holding me back as i can't past 28psi. I would not buy a 40R coming from a 37R, it is a new platform going twin scroll, twin wastegates etc. If i am going that way i would definately go 42R. Borg warner turbos are nice too and cheaper.
If you have a good engine builder it would definately be cheaper than buying a built shortblock, but if you are thinking of buying a block and cosi heads why not go cosi all the way?
What's the weight of your car?
Old 08-04-2008, 11:16 AM   #8
MS WRX
Member#: 117780
2004 WRX
gt40 is a t4 turbo.
MS WRX is offline   Reply With Quote
Old 08-04-2008, 11:24 AM   #9
Thunder STI
Member#: 172656
Old 08-04-2008, 12:04 PM   #10
bertune
Member#: 107290
Cossi long block is way too much money, I can probably built my engine and get the same or better results.
I guess you answered your own question.......
Old 08-04-2008, 01:00 PM   #11
Thunder STI
Member#: 172656
so, Do I need to get rid of my setup and start from scratch, In fuel system, also I want to reverse the manifold.
any suggestions in that area ?
Thanks
Old 08-04-2008, 03:57 PM   #12
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
Looking at Garrett's web site:
4088R=~700hp(whp~600-630 depending on tune and fuel)
4094R=~800hp(whp~700-730 " ")
4294R=~850hp
4202R=~1000hp
I would use a 42**R turbo for those numbers. Also I've talked to AR Fabrication and sounds like they build some strong motors..
icslowmo is offline   Reply With Quote
Old 08-05-2008, 05:50 PM   #13
700hp
Member#: 104164
'95 Impreza 800+hp
9.1 152mph
I made 678whp with the 35r 1.06 hot side at 28 psi. My 04 sti ran 139mph all boost with that set-up so maybe the 35r is enough. I had about every supporting mod you can think of though. Don't buy anything you don't need that how I feel.
700hp is offline   Reply With Quote
Old 08-05-2008, 06:09 PM   #14
MrH00nel2
Member#: 80474
2003 4088R
Twin Scroll
a 35r with 1.06 can do more than people think... and thats from personal experience
i have recently moved to the 4088r twin scroll. thats plenty
MrH00nel2 is offline   Reply With Quote
Old 08-06-2008, 10:07 PM   #15
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
I'll probably get killed for saying this but you might consider getting a closed deck 2.0L motor for this. If you want the motor to last, nothing beats a closed 2 liter.
Old 08-06-2008, 10:23 PM   #16
Splinter
Member#: 106510
98 Widebody 2.2
Smooth Safety Blue
Have you considered going to a twincharged setup?
Splinter is offline   Reply With Quote
Old 08-06-2008, 10:57 PM   #17
WRXINTX
Member#: 96712
or, doing a closed deck modded 2.5L
that might beat the old closed deck 2.2 or 2.0L....
WRXINTX is offline   Reply With Quote
Old 08-06-2008, 11:10 PM   #18
Splinter
Member#: 106510
98 Widebody 2.2
Smooth Safety Blue
The 2.0L closed deck has much, much thicker cylinder walls.
Need Suggestions: Subiegal Gauge Pod mounting jester696 Interior & Exterior Modification 0 10-24-2008 07:08 PM
Huge Power Sale! - Additional Savings for NASIOC Rallitek.com Engine/Power/Exhaust 5 09-25-2007 06:43 PM
Need suggestions: what sort of nice gestures can i make for a dying close friend? edkwon Off-Topic 30 04-17-2007 09:56 PM
Need Suggestions: External Hard Drives snvin Off-Topic 29 01-08-2006 06:42 PM
need suggestions: my rear end is going out Damon Service & Maintenance 13 08-05-2003 01:01 PM
Message Board Statistics All times are GMT -4. The time now is 02:09 AM.
