Old 08-04-2008, 02:22 AM   #1
MacNews
Member#: 186100
2006 B9 Tribeca
Default Lifespan of AWD on '92 Legacy?
Hi all,
I am looking at purchasing a 1992 Legacy, and am wondering how long the AWD-system lasts before it needs an overhaul/replacement.
The car has 175,000 KMs, standard transmission along with turbo and AWD. I believe it was the top-of-the-line Legacy for 1992. It has never been in any major accidents over $2000, and has been kept in good shape.
Any insight into the lifespan of the AWD would be much appreciated.
MacNews is offline   Reply With Quote
Old 08-04-2008, 07:15 AM   #2
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
The AWD with a standard transmission SHOULD out live the life of the car, as long as its been taken care of. Drive it with miss-matched tyres, or have it towed incorrectly and you can certainly kill the AWD mechanism rather quickly.
Clutches can wear out, and CV joints are notorious for failing with high mileage, and depending on WHERE you are located, I would also be concerned about the possibility of rust developing in various locations.
Properly taken care of, this car is good for 500,000 KMs.
On the other hand an automatic model might require a rebuild of the transmission ~ 350 KMs.
Jonathan is offline   Reply With Quote
Old 08-04-2008, 03:37 PM   #3
MacNews
Member#: 186100
2006 B9 Tribeca
Thanks Jonathan, that gives me a much better picture!
I am in Vancouver, BC, Canada. We have very mild winters here, so rust is not much of a problem.
However I did notice a small amount of rust at the bottom of the wheel-well on the rear wheel on the right side. It was a really small spot of rust, but I'm wondering about the potential of it spreading.
Edit: That is not the car I test-drove, but a random image I pulled off the 'Net.
Old 08-05-2008, 02:47 PM   #4
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
It will spread. Once it has corroded to the point to where you can see it through the finish, it's worse than it looks.
Don't get discouraged though, it is a simple fix for a body shop to cut the rust out and replace with a new panel. Or you could buy another fender, I'd recommend a new one, because generally any salvage fender is going to have some rust on it as well.
These cars ALWAYS rust in those areas. It was a horrible design flaw where sand/salt/debris can become trapped within the fender liners and eat the metal from the inside out.
runninstrong is offline   Reply With Quote
Old 08-16-2008, 11:40 PM   #5
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Agreed. I just a sold a '95 legacy with 170,000 miles on it. AWD works fine, original clutch, original CV joints, etc, etc. Just have a mechanic check out any car you are considering buying ...
Mike Wevrick is offline   Reply With Quote
Old 08-20-2008, 01:00 AM   #6
gunny11218
Member#: 186959
2012 WRX sedan
Limited WRB
is it a legacy SS? or just a normal legacy?
gunny11218 is offline   Reply With Quote
Old 08-20-2008, 08:22 AM   #7
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Based on Mac News' description its a Legacy Sport Sedan. Normal Legacys didn't normally come equipped with a Turbocharger. The Turbo in this car only generates fairly mild boost, is well lubricated and lasts pretty much forever, as long as you change the motor oil.
location of PCV on '04 Legacy?? bugeye829 Normally Aspirated Powertrain 2 08-27-2007 12:09 PM
tmic installation on '92 legacy turbo rockethound Pre-2002 Factory Turbo Powertrain 6 06-27-2007 04:57 PM
possiblity of teins on a legacy b4u Legacy Forum 16 12-06-2006 12:09 PM
can I put tire load of 85v on my Legacy? etam Tire & Wheel 0 09-12-2003 06:46 PM
Anyone have pics of 18's on a legacy? nitrohuffer Legacy Forum 6 07-05-2001 04:56 PM
