Old 08-04-2008, 06:48 AM   #1
groff
Member#: 110073
2006 STI swapped WRX
Default OS Speed Density in LGT
is there anybody on here that is capable of doing the Freon map conversion or has done it and it is willing to do it to my LGT map. I don't quite have the confidence, but would like to be able to run speed density. For quite some time I've been restricted by the MAF voltage for my GT3082, and I'm tired of continuing to change my IC piping/MAF housing size to accommodate more boost. My tuner is comfortable with SD, I just don't have the money right now to go Hydra after putting a 6sp swap in. Thanks in advance!
Matt
groff is offline   Reply With Quote
Old 08-04-2008, 09:04 AM   #2
Tea cups
Member#: 103136
That is not the type of work that some Joe Blow with a hex editor is going to be able to do. You would have to have intimate knowledge of the Subaru ECUs and dissassembly. Which means that rules out 99.9999% of the members on Nasioc. I can think of maybe 2 other people, other than obviously Freon, that would know enough to potentially be able to do it.
Personally, I wouldn't want to mess with someone else's work. They put all the work into it, it just doesn't seem right to borrow it and adapt it to something else. Even if they didn't mind, it still becomes a slippery slope as then everyone wants the same thing done for their particular ECU - you still have to modify and adapt it for each separate rom revision and create separate ecu definitions. And this is a much more involved hack that say, launch control. I don't blame Freon for sticking to a few model years.
Tea cups is offline   Reply With Quote
Old 08-04-2008, 04:10 PM   #3
groff
Member#: 110073
i don't disagree with what you say above, i've asked the one other person and they didn't want to because they didn't want to accept money to do the patch, but didn't have the time to do it for free (semi-ironic ) but anyway, I understand it is involved, which is the reason that I'm not willing to go out on the limb and do it myself yet.
Freon never responded to me on any of the sites I've PM'd him from about the modification though, thats why I was seeking alternate help.
Old 08-04-2008, 11:32 PM   #4
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Are there any aftermarket devices that will emulate a MAF signal based on RPM, MAP, and a VE table? Seems like a fairly straightforward project for someone who is good with microcontrollers.
Old 08-05-2008, 07:33 AM   #5
Tea cups
Member#: 103136
why not go UTEC? UTEC plus a factory reflash is powerful combination.
Old 08-06-2008, 12:30 PM   #6
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
the greddy emanage ultimate can convert maf cars to MAP but ive heard it has driveability issues..atleast on n/a cars that are turbo'd.
mxpunk is offline   Reply With Quote
Old 08-06-2008, 10:03 PM   #7
groff
Member#: 110073
map switching and because my tuner has uninstalled just as many if not more UTECs than he's tuned, which isn't a problem, I've seen how power the OS stuff is, I've been running it for over a year at over 400whp, just looking for that extra something now i guess, aren't we all
Old 08-06-2008, 11:28 PM   #8
NSFW
Member#: 140444
05 Stage Free LGT
I've heard that turbo-converted NA cars have driveability issues...
Thanks for the tip though.
Old 08-07-2008, 10:25 AM   #9
groff
Member#: 110073
so does anyone talk with Freon on a regular basis? is there a good way to get a hold of him?
Old 08-07-2008, 07:54 PM   #10
Freon
Member#: 88322
2009 BMW 135i
I'm right here. If you have a question about SD post it on the FAQ thread on RomRaider.
Freon is offline   Reply With Quote
Old 08-07-2008, 08:27 PM   #11
groff
Member#: 110073
i pm'd you over on romraider back in june but didn't hear anything (on here too )
my question is whether you'd be willing to convert it to another hex version for the LGT...for compensation
Speed Density - OS 16bit Rom - Discuss Here JSarv Engine Management & Tuning 884 07-24-2013 01:39 AM
Speed Density in Utah! 907Bum Rocky Mountains Impreza Club Forum -- RMIC 14 04-18-2010 12:42 PM
Running utec all the time in speed density? sorrowfulkiller UTEC 5 08-05-2008 11:34 AM
please ASAP is the STI speed density or mass air bobturismo Off-Topic 12 04-25-2004 02:45 PM
speed-density thng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-10-2003 01:06 AM
