#1 |
NASIOC Manufacturer
Member#: 171509
Quoted from Jim Cooper:
"Hi guys, Just picked up my car today from the guys at Automaster AMR. You can read all the info on my Journal thread Numbers Dyno: Dyno Dynamics Tuner: Auto Master AMR Wheel HP: 402whp Wheel TQ: 371wtq Car Info: Year: 2006 Engine Management: Cobb 1.0 Turbo: AMR T-60R bolt-on Turbocharger Intercooler: AMR Top-Mount Intercooler Kit Injectors: 850cc Injectors Intake/Inlet: AMR Custom 3" Cold Air Intake System, Hard-pipe turbo inlet hose Headers: AMR & up pipe Exhaust: AMR Custom 3" system (2) Resonators & Muffler Other Power Mods: - Walbro 255 fuel pump - AMR Custom AUX Methanol Fuel System w/ Pump (into TMIC) - TGV deletes and porting DYNO SHEET: ![]() ENGINE BAY: ![]() Tuning Note: - BOOST: 22psi - TIMING: Conservative - FUEL: 93 Octane / Methanol injection I was looking for a car with a split personality, and this combination really delivers. It is drivable off stop in second gear, and runs like an impressive Impreza without boost. I hope Rob from Automaster will append details that I didn't cover. Coop __________________ Jim Cooper - 2006 STI " Customer Satisfaction Report: Auto Master AMR = A+ Delivery & Satisfaction Quote Above taking from: 2006 STi - 402whp / 371wtq Customer's Journal: •• SharpByCoop's •• 2006 STI - From mild to.... AMR Notes: ![]() The T60R is one beast of a bolt-on. Sitting in factory location. This turbocharger doubled the factory horsepower limit at only 22psi! This vehicle was equipped with our custom AMR Modified Meth injection kit using a small "mist" jet to keep intercooler temp's down due to this vehicle running our TMIC. Timing was untouched from the pump gas tune along with AFR's at 11.0-11.2. This turbocharger has only begun to make power. 200+whp with a TMIC! -Rob
#2 |
Member#: 68647
Vehicle:07 STI Rotated 35R Jorge Tuned |
I cannot see the chart at work...but why a 7cm^2 exhaust housing? Seems a bit small for a turbo this size?
edit: just checked it out the dyno plot on my cell phone. That actually looks like a pretty good torque curve! Nice job ![]() Last edited by Steve.804; 08-04-2008 at 11:19 AM. |
#3 |
Trust me, I'm a scientist
Moderator Member#: 150794
SCIC
Vehicle:Qcab dakota 4x4 LT1 Formula Firebird |
OHHHHH that top-mount is teh sexxy!
![]() Looks like it holds the top-end very nicely. I'm jealous ![]() |
#4 |
Member#: 64908
Vehicle:10.8 XT+ Real stock turbo record holder 11.4 |
That is a very nice looking powerband..
How does this turbo compare to say a FP red? |
#5 | |
NASIOC Manufacturer
Member#: 171509
Junior, The T60R uses a 60lb compressor wheel. The compressor housing is fully ported. Machined Port on the inlet and outlet. The exhaust housing is also suited with the same care, "Fully ported". Both compressor and exhaust housings are then coated. The exhaust housing is coated with our high temp coating to ensure spool and keep engine bay heat down. The compressor housing is coated with our wrinkle red finish. It is a really nice turbocharger for the street/strip. Hard pulling straight to redline with little effort. It does need a FMIC unless some sort of injection is done to keep tempatures down. -Rob |
#6 |
Member#: 56297
Vehicle:2004 STi HTA Green 28psi, MSPT Tuned |
why don't you use an 8cm housing?
#7 |
Member#: 62280
Vehicle:2011 WRX Sedan DGM |
Nice job Rob. This thing will probably tear some **** up @ higher psi too.
#8 | |
Member#: 64908
Pretty sick Junior |
#9 | |
NASIOC Manufacturer
Member#: 171509
This vehicle is a customers 2006 Subaru STi. Only intake AVCS available ('04-'07). The T60R will be going on our 2008 STi (Dual AVCS-INT/EXH)very shortly. I will post up the information on that once completed. Since we are on the topic, the exhaust cam should play a big roll in spool and maintain torque throughout the RPM band when dialed in correctly. Further information will be given once the turbocharger is seated in the vehicle. -Rob |
#10 |
Member#: 41754
Vehicle:03 wrx gt35r, 2.5L, meth |
Very cool turbo but.... you guys are claiming this is making 600hp? You serious? That's kind of a stretch
#11 |
Member#: 131261
NESIC
Vehicle:2007 AMR STi >500whp 2003 Corvette ZO6 |
#12 | |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
Put it on c16 and it will hit 470-500whp, which is 600 crank. Also because they are using a dyno dynamics and a stock STi will put down ~200-220whp on it....sooo 200*2=400whp, double the factory |
#13 |
Member#: 139385
nice results there Rob, looks like a strong turbo. are you using the upgraded wastegate on it?
#14 |
Member#: 168107
South East
Vehicle:2006 Wrx BPU++ Blue |
When are you going to start production on the front mount intercoolers for the 2006 wrx? Not sure if you have already.
#15 | |||
NASIOC Manufacturer
Member#: 171509
Bingo! -Rob Quote:
Thank you. This vehicle is runing the standard actuator that we include on the turbocharger. -Rob Quote:
Working on them as we speak. Smooth mandrel bends, .065 wall, 6061 aluminum and best of all. HIGH QUALITY U.S. MADE MATERIAL!!! -Rob |
#16 |
Member#: 180861
Vehicle:2005 wrx vf34 ppg's 93/E85 PhatBotti Tuned!!! |
On the dyno in my area, stock sti's put down about 215 on this type of dyno. So double the factory isn't too far off.
#17 |
Member#: 67182
Vehicle:2004 Subaru STi 11.0 @ 128mph - 93/Meth |
I saw this car in person!
Welcome to the 400whp club! |
#18 |
Member#: 183029
South East
Vehicle:2007 STI- 402whp/436 OBP- uncorr./SAE-Mustang |
sry to nag on this cause that tmic and turbo look SWEET but seems like it has all the lag of a 35r- where as im making 400, 420ish after retune hopefully on a mustang on the dom with meth and hit peak torque in 4th bet 4000-4200 rpm (full boost around 3700) compared to peak torque here around 4680 and im on a fmic(which should hurt those) and 23 psi
just babbling but maybe someone could correct me or tell me why this is that much better than mine or a 35r or is it just that in the middle- no arguments looking for just info exchanges here |
#19 |
Member#: 67958
Vehicle:MY96 Time Attack and 06 STI daily |
Keep in mind that where a car hits full boost and peak torque on a dyno varies widely. Loading dynos can be loaded in a manner that makes them spool up quickly or slowly and inertia dynos will cause different spoolup depending on the mass of the rollers.
Testing on the street is far more even, but only when gearing and vehicle weight are equal. Other factors play a roll, but I'm assuming flat ground etc. Vehicle weights for most WRXs and STis are relatively close, but gearing varies widely between some models. See if you can get several people with 04-06 STis to do 4th gear pulls on flat ground while logging rpm and boost on the turbos you're interested in. Have them all start at the same rpm and do 3 successive pulls. Sure it's a longshot, but that would be a much better comparison. Just remember that supporting mods play a big roll in spoolup and if any of them have a modded engine their numbers aren't a fair comparison to a stock engine. FWIW, on a relatively slow ramp rate (for the car) on a Dyno Dynamics my car spooled 800 rpm later than it does on the street the time I did some pulls to test my no intercooler setup. Both tests were in 4th gear. I like the paint on the TMIC too. Nice work guys. One of these days I'll check out the new shop when I'm in the area. -Mike Last edited by Innovative Tuning; 08-26-2008 at 09:15 AM. |
| Thread Tools | |
| Display Modes | |
| 2007 Subaru STi - AMR T60R / AMR TMIC / 93 Octane / More.... | AMR | Proven Power Bragging | 17 | 01-29-2009 11:19 AM |
| 2008 Subaru STi - AMR TMIC / AMR Dual Turbo Back / AMR BMI / AMR 3-Port Meth Kit | AMR | Proven Power Bragging | 45 | 01-17-2009 08:24 PM |
| 2008 Subaru STi - AMR Race FMIC / AMR T60R / AMR Direct Port Meth / 25psi @ 3800rpm | AMR | Proven Power Bragging | 16 | 11-11-2008 09:35 PM |
| 2006 Subaru STi - *NEW* AMR Font Mount Intercooler (FMIC), AMR BMI, Much More!!!!! | AMR | Proven Power Bragging | 25 | 10-30-2008 09:45 AM |
