#1 |
Member#: 52313
SWIC
Vehicle:2005 STiOmgWtfBbq20G 2007 MS3 Black |
Over the weekend I installed B-Line Motorsport's top-mount oil cooler kit. It came with a Setrab core, mounting brackets, Earl's fittings, heat shielded lines, aluminum sandwich adapter, necessary hardware, clips to hold the hoses, and some zip ties for good measure. The owner of B-Line provided excellent pre-sales service and was refreshingly proactive, friendly, and candid. Here's some pics...
![]() ![]() I'm definitely happy with the kit, but there are a few things I'll be changing. Mind you, I do not feel these are short-coming to the original kit esp. for it's price. They're just things I want to do for the sake of fun and to put my personal mark on it. I'm redesigning the static mounts to allow control of the height, pitch, and position forward and aft. I want to create a scoop that bolts to the core and fits under the hood's scoop. I might also increase the diameter of the lines, and change their length to allow different routing options.
#2 |
Member#: 3782
South East
Vehicle:02 WRX WFC#040 Clean on 19's |
where can you get this?
#3 |
Member#: 52313
SWIC
I got mine directly from B-Line. http://www.blinemotorsports.com
#4 |
Member#: 22987
SCIC
Vehicle:2010 PB EVO X GSR... .. It's All Stock Officer |
very nice kit. I had one of the first bline front mounted oil coolers and was very happy with it. Congrats on the purchase man, looks great.
BTW, If you have some time, you should take a second to post this in the members car gallery so more people can see it. |
#5 |
Member#: 128484
International
Vehicle:2006 EDM WRX STI WRB |
could someone please enlighten me:
Iīve read that itīs not good to place the cooler in the highest position of the entire oil system...true or false? |
#6 |
Member#: 97194
SWIC
Vehicle:2005 WRX STi Crystal Grey Metallic |
I think because it's a loop, once it is primed, and the oil is pumped up there it almost acts like a siphon on return. It will add more stress to the oil pump, but how much, I'm not sure.
+1 for nice kit! |
#7 |
Member#: 17332
NESIC
Vehicle:2004 Black STI Not stock anymore |
It's ok - if the pipes entered from the bottom there would be a chance for trapped air to greatly reduce the effectiveness, but they did it right.
#8 |
Member#: 23507
SCIC
Vehicle:2007 UGM 07 sti lmtd 06 volvo v70r 10 mini jcw |
i just got off the phone with John at bline ill be getting the same kit in next couple of days,he seened verry helpfull ,ive been looking for an oil cooler that works with aps front mount for a wile and this works will keep everyone updated
#9 |
Member#: 23507
SCIC
just got my kit in today : ) will post up pics soon
#10 |
Member#: 9960
Vehicle:2002 Impreza WRX WRBlue Perl |
Seems like a popular piece around here! I was looking at getting one of these a few weeks back, but was concerned about pumping losses associated with having the oil cooler at that position. I also did not know whether the oil cooler would end up heating the oil up more with it sitting on top of the engine. Add to this that nobody around here seemed to be running one, and I started looking at other options.
The problem we face with these cars is that when you reach a certain stage of modification, there is just very little real estate available to mount anything ![]() What size core is included with the B-line setup? |
#11 |
Member#: 17332
NESIC
looks like a 25 row setrab.
#12 |
Top Scoob 019
Member#: 43630
Vehicle:2004 GT40R-built 2.5 604 whp @1.8 BAR on VP109 |
Does this kit come with a thermostat???
#13 |
Member#: 85437
BAIC
Vehicle:2002 Wrx Land of the dead |
holy crap that is hella nice~!!!
#14 |
Member#: 88467
NESIC
Vehicle:2005 WRX All black everything. |
#15 |
Member#: 17332
NESIC
does any oil cooler kit come with a thermostat? I've never seen one with one. Mine doesn't have one. I believe most coolers are full flow, so you can't simply block flow like a coolant thermostat, you'd have to bypass it with no real reduction in flow.
#16 |
n00b Moderator
Moderator Member#: 99397
RMIC
Vehicle:'13 BRZ, '13 STi SRs13 '83 Skyline '93 GTR |
allot of the oil cooler kids i have seen come with a thermostat. i am running a setrab core with mocal lines and a thermostat adapter plate.
#17 |
Modest Mouse
Moderator Member#: 27323
AKIC
Vehicle:2000 RSTi |
#18 |
Member#: 86741
Vehicle:05 STi.. Built twinscroll35r Love/Hate |
mmmmm me like
#19 |
n00b Moderator
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
thermostat would be nice..
that way the oil cooler does not get "exploded" due to low temp / high pressures.. |
#20 |
Member#: 41632
Vehicle:2004 Spec C WRC blue |
3 observations:
(1) that oil cooler is huge. Also this would require about 12 feet or so of oil lines. I hope that the filter valve prevents all this oil from draining to the oil pan between startups? (2) does this kit come with ducting from the scoop to the oil cooler? If not, then airflow through the core is going to be pretty ****ty. (3) It is mainly useful for higher speed venues, not so much for very tight tracks/autocross/gymkanna where speeds are lower because it does not have a fan. In my experience, I see highest oil temperatures on uphill twisty canyon roads where speeds are relatively low and load on the engine is very high. The only way I have been able to keep oil temperatures down is by kicking in my radiator fans at a lower temperature (my oil cooler is front mounted, pass side... so I just kick in the pass side fan much earlier, the added flow though the oil cooler dramatically cuts the oil temp, not much an effect on coolant temp). Rafi Last edited by RR-racing; 01-14-2009 at 12:19 PM. |
#21 | |
Member#: 115602
BAIC
Vehicle:2008 Black STi B Street Prepared (BSP) |
#22 |
Member#: 199879
Vehicle:2009 Forester FXT |
any heatsoak issues with this kind of oil cooler ?
#23 |
Member#: 115602
BAIC
#24 |
Member#: 11211
Vehicle:2004 STi Rally Blue |
They are a little expensive with no Thermostat built in.
| Thread Tools | |
| Display Modes | |
| top mount oil cooler setup | shwoop_soobie | Engine/Power/Exhaust | 24 | 04-14-2009 11:10 AM |
| Top mount Oil cooler/tran cooler | ColesSTi | Factory 2.0L Turbo Powertrain | 5 | 08-31-2006 08:10 AM |
| Top mount oil cooler? | midnightsti | Factory 2.5L Turbo Powertrain | 15 | 08-14-2006 01:48 AM |
| Top Mounted Oil cooler | stevo2234 | Factory 2.0L Turbo Powertrain | 16 | 12-16-2005 06:35 AM |
| Top-Mount Oil Cooler? | dl337j00 | Factory 2.5L Turbo Powertrain | 7 | 01-27-2005 09:31 PM |
