Old 08-04-2008, 10:36 PM   #1
GentlemenStylez
Member#: 146626
2001 Impreza GC8
Panda on rails!
Default Anti-Lift Kit (ALK): How to install
Well, I finally decided to upload my install pictures so that it may help others. This is how I did it. You can do it whatever way you feel is better for you. But if you do it my way, you are merely using it as a guide and nothing else. I am in no way responsible for any damage or injury as a result of poor practice or accidents.
Let's begin (Note: I'm doing both sides simultaneously)...
Firstly, you need to get yourself a set! Comes with 2 ALKs, grease, 2 new nuts, and 2 new washers.
Secondly, get your tools ready and mount the car up properly with jack stands to prevent the car falling down on you. Get as much clearance as you sanely can as you'll need a lot of room to work with.
Most importantly, you'll require a breaker bar; this is mine.
First go at it... I destroyed my adapter. Didn't think the bolts were this tough to break free.
So DO NOT use a 3/8 in. drive to break or torque.
Break loose the bolts first, and then the nut. Don't remove any fasteners until all of them are loosened. I broke loose the nut with 2 wrenches coupled together for extra leverage. After fasteners have been removed, you can pull (or pry) the control arm downward to remove the original mount. If you pry, never pry on a mating surface!
The two mounts side by side for comparison. The sticker says exactly what it means (in reference to their installation positions).
Lube the bushing. And THOROUGHLY clean the area to which it will be installed on your car. You don't want parts to wear prematurely!
The next part will be frustrating; but there IS a way. You have to get the new mount into place without damaging things too much (including yourself) and get it past the tranny crossmember.
Last edited by GentlemenStylez; 04-28-2010 at 06:16 AM. Reason: Fixed new URL to photos.
GentlemenStylez is offline   Reply With Quote
Old 08-04-2008, 10:36 PM   #2
GentlemenStylez
Member#: 146626
2001 Impreza GC8
Panda on rails!
I pulled down the control arm to initially get the mount on the rod end. At this point I haven't been able to clear the tranny crossmember, so I left it sitting against the tranny crossmember as gently as I could (put a rag between the two to prevent damage). Next, I threaded the old nut onto the control arm. I pulled the control arm downward and placed a socket + breaker bar + breaker bar extension onto the nut. This next picture is for reference as to what position it needs to be in. Use the car chassis as a fulcrum. Get out from under and move to the side of the car; pry the control arm downward as far as you can until you can get the ALK mount to clear the tranny crossmember and position it properly. Once everything is in place (both ALKs), begin threading in the new nut+washer and old bolts until they become snug, but do not torque at this point. Note: FLAT SIDE OF WASHER MUST FACE NUT. If you want, you can lightly lubricate the bolts with anti-seize.
Bring the car back down to ride height (full weight on wheels), like so. Bounce the car a few times and begin torquing the fasteners starting with the nuts first and then the bolts. Use a dead blow mallet and whack the ALKs a few times to make sure things are seated as well as possible, then recheck your torque. Your socket will most likely not fit on the nut with a torque wrench attached. So use a bear claw for best results. A crows foot might work, but I highly discourage using an open ended tool as it can round out the nut. Remember to keep any adapters/extensions at 90 degree angles relative to your torque wrench during the torque process or you'll deviate the leverage and thus ruin your torque value.
Bolts to 184 ft-lbs
Nuts to 140 ft-lbs
Lastly, clean up. Drive around a bit and make sure nothing feels wrong. Drive carefully as you accustom yourself to the new handling behavior. You will immediately notice the car accelerates better out of corners.
Make sure to drive not too aggressively. Re-torque the fasteners after about 50 miles of driving. This is a requirement! Your ALK will have set in and your fasteners will lose their hold. So RE-TORQUE!
Edit: Oh, and don't forget to check wheel alignment. :P
Last edited by GentlemenStylez; 04-28-2010 at 06:40 AM. Reason: added info in red, and fixed photo urls.
Old 08-05-2008, 03:14 AM   #3
teiva-boy
Member#: 22825
One of the better write-ups as of late! Good show
teiva-boy is offline   Reply With Quote
Old 08-05-2008, 04:25 AM   #4
GentlemenStylez
Member#: 146626
2001 Impreza GC8
Panda on rails!
I should mention that your suspensions roll may increase due to 'softer' feeling springs. That is because the ALKs take up more of the energy during braking/accelerating instead of transmitting them to your suspensions' springs. This in turn will allow each wheel to independently contour to the pavement better, thus increasing traction significantly on four wheel drive vehicles. Your vehicle's corner exit speed will increase the overall speed in the straights; and as we all know, it's maximizing speeds in the straights that count toward decreased lap times the most. That's not to say it isn't important to do well in the corners, too.
Old 08-05-2008, 05:33 PM   #5
TreyV
Member#: 4027
2006 STI
SGM
Just a note, from what I've read and talked with other folks about ALK installs, YMMV a lot with how hard it will be to bust the nuts loose on the OE mount. I've heard anything from an utter deathmatch to a couple grunts with the right leverage. Older cars (where the bolts have had ages to seize up) will definitely put up more of a fight.
Heh, that breaker and cheater combo above treads the line between 'breaker bar' and 'bo staff.'
TreyV is offline   Reply With Quote
Old 08-05-2008, 06:38 PM   #6
ritky
Member#: 72285
2005 STi Wingless
FLA Turnpike > I-95
Nice write up. My ALK instructions were shredded when recieved...I think my washer is oriented the wrong way
ritky is offline   Reply With Quote
Old 08-06-2008, 12:17 PM   #7
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
+1 nice write up.
I love my whiteline ALK!
rexworx is offline   Reply With Quote
Old 08-06-2008, 12:24 PM   #8
gandapanda
Member#: 51476
05 FXT
06 S2000 - gone soon
Excellent writeup; subscribed for reference.
gandapanda is offline   Reply With Quote
Old 08-06-2008, 01:02 PM   #9
Back Road Runner
Member#: 60082
2004 Forester STI
Good write up.
...I did none of that with mine.
Old 08-06-2008, 02:37 PM   #10
Tony_Montana87
Member#: 157001
2004 Impreza WRX STI
what exactly dose this mod do? sorry noob question.
Tony_Montana87 is offline   Reply With Quote
Old 08-06-2008, 03:50 PM   #11
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
It increases caster and decreases the anti-lift geometry on the front end. That means a crisper turn-in and better front end grip when on the throttle in a turn.
Old 08-06-2008, 08:56 PM   #12
GentlemenStylez
Member#: 146626
2001 Impreza GC8
Panda on rails!
Thanks for the support! I'll be making more DIY threads in the future. =)
Old 10-03-2008, 12:15 PM   #13
Hah72215
Member#: 77815
2002 WRX WAGON
I just received the Sport Whiteline Anti Lift Kit that I ordered and it came with a bunch of extra bolts, spacers and square spacers/plates. This is for an '02 WRX Wagon. Are all these extra parts not necessary for the install? Anyone know what they're for?
Hah72215 is offline   Reply With Quote
Old 10-03-2008, 12:34 PM   #14
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
They are to space the front subframe down to make it fit. There should be instructions in the kit that show you where they go.
Old 10-03-2008, 01:39 PM   #15
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
What about noise and vibration?
Thanks
Ferraz is offline   Reply With Quote
Old 10-03-2008, 01:43 PM   #16
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Added this to the installation sticky:
http://forums.nasioc.com/forums/show....php?t=1430598
Old 10-04-2008, 02:16 AM   #17
GentlemenStylez
Member#: 146626
2001 Impreza GC8
Panda on rails!
Thanks
On my ride, I experienced no extra noise or vibration. But then again, my suspension has been modified a bit already, so any further upgrades to stiffen the chassis probably will not make any further noticeable differences in noise or vibration. I'm using the medium setting bushings in terms of stiffness.
-GS
Old 03-22-2010, 09:01 PM   #18
Subiracer06
Member#: 182487
04 STI
JBP
Default alk torquing
so how did you guys end up torquing the nut to 184 ft lbs? i cant get a socket up there!!! did you use a crows food on the torque rench?
Subiracer06 is offline   Reply With Quote
Old 03-22-2010, 09:18 PM   #19
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
Originally Posted by Subiracer06 View Post
so how did you guys end up torquing the nut to 184 ft lbs? i cant get a socket up there!!! did you use a crows food on the torque wrench?
Open end wrench and some leg force. As you are finding out, there is not much that will fit in that location and allow proper torque take-up. At 184 lbs-ft you are going to spread a regular crows foot even if it is a flange nut style.
Although, If you can find a torque extender in that metric size you might be able to use a torque wrench on there.
JarHarms is offline   Reply With Quote
Old 03-23-2010, 01:55 PM   #20
Subiracer06
Member#: 182487
04 STI
JBP
the nut is only supposed to be 140 ft lbs i going to go over to grainger and pick up a 24mm 6pt flange crowfoot. looks like the best bet. damn thing is 25 bucks tho
Old 03-23-2010, 07:05 PM   #21
Subiracer06
Member#: 182487
04 STI
JBP
this what i got to try. crossing my fingers
http://www.grainger.com/Grainger/items/1FX47?Pid=search
Old 03-24-2010, 01:02 PM   #22
JohnSellers
Member#: 182253
2002 Impreza OBS
You might break that 3/8-inch drive piece trying to torque to 140 ft-lbs.
JohnSellers is offline   Reply With Quote
Old 03-24-2010, 02:42 PM   #23
Badler
Member#: 133597
I doubt you can even get anywhere near 140ft-lbs with a crows foot. Buy an openended wrench and a piece of pipe like others have said. 140ft-lbs is no joke.
Badler is offline   Reply With Quote
Old 04-28-2010, 06:32 AM   #24
GentlemenStylez
Member#: 146626
2001 Impreza GC8
Panda on rails!
Hey guys, I apologize for the late response to this thread. I haven't been around to check the forums much.
Anyways, I fixed the URL to all the pictures.
For those wondering how to torque the nut, the best option is to use a bear claw. Most people weigh at least 160 lbs, so at 12+ inches of leverage (length of most torque wrenches), you should be able to manage 140 ft-lbs of torque. It's a lot easier to torque fasteners than to break them loose.
A crows foot will probably ruin your nut. But you might get lucky since not all tools are created equal. If you use a 3/8" drive, you run a high risk of breaking it. Use at least a 1/2" drive. Again, not all tools are created equal, so as the end user, you have to make your own judgment call.
I hope this info helped. Happy tuning! =D
-GS
Old 05-23-2010, 09:25 PM   #25
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I will be attempting to install G-N control arm bushing in the next couple of days...
Since my corded impact gun won't fit in there, I wonder if hammering with mallet will work to free up / tighten the nut? this method has worked amazingly well for me on many of installs I've done.
To Anti-Lift Kit..? Or, Not to Anti-Lift..? PSRS (+Video) krylon General Community 45 11-07-2009 10:10 PM
Perrin P.S.R.S Anti Lift Kit Brand New never installed simon021 Suspension/Brakes/Handling 21 07-08-2008 01:43 PM
How hard is it to install an anti-lift kit? slowme Brakes, Steering & Suspension 3 06-25-2002 07:36 PM
Has anyone bought/installed the Anti-Lift kit for WRX yet? GDA Brakes, Steering & Suspension 1 03-30-2001 07:49 AM
Anti-Lift kit install? yebokmj Newbies & FAQs 5 11-15-2000 04:03 PM
