Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 08-05-2008, 01:19 PM   #1
Fine Line Imports
Vendor Sales Rating: (11)
Member#: 81166
2008 Forester
Default MSI, DMS, COBB and KW suspension for your WRX/STI
Fine Line Imports is proud to bring your the latest suspension and brake parts from DMS, MSI, KW and COBB. These are some of the finest suspension and braking components currently available for you STI. All of these parts are made from the highest quality material and are Rally/Track/Auto X proven. If you have any questions about the parts you see here please do not hesitate to ask.
CNC from billet aluminum these front adjustable camber caster plates or the strongest most heavy duty plates we have come across. Using a top quality bearing that is virtually noise free these camber plates are built to withstand the abuse of Rally/Track/AutoX. Finished in a Electrolysis Nickel coating these are the last camber plates you will need to buy.
DMS front camber plates 2004-2007 STI $556.00
Just like the DMS front camber plates these rear adjustable camber plates are made CNC from billet aluminum and use the same high quality center bearing and Nickel coating that the DMS front camber plates do.
DMS rear adjustable camber plates 2004-2007 STI $489.00
Machined from billet aluminum these rear adjustable lateral links are a excellent addition to anyone looking to gain more adjust ability and control out of the rear of your car. These lateral links use a aluminum/steel construction that reduces the chance of binding over time like other steel/steel designs. Utilizing high quality polyurethane bushings from Power Flex these lateral links are designed for years of trouble free use.
MSI rear adjustable lateral links 2004-2007 STI $749.00
The MIS rear sub frame is a true work of art. The sub frame is crafted from chromolly stain less steel then is tig welded together. This sub frame features multiple lateral link mounting points for lowered vehicles. It also features spherical bearing mounting points for the rear diff. This MSI rear sub frame adds significant strength and rigidity to the rear of your STI
MSI rear sub frame 2004-2007 STI $2999.00
COBB front and rear sway bars are a hollow design intended to give you a better handling well balanced car with a reduction in weight over the solid factory sway bars. The rear sway bar is 3-way adjustable and both front and rear bars come with mounts and bushings.
COBB front sway bar 2004-2007 STI $165.00
COBB rear sway bar 2004-2007 STI $185.00
COBB F/R sway bar kit 2004-2007 STI $350.00
KW Variant 3 coilovers are at home both on the track or the street. These coilovers offer a lot of adjust ability and control for a reasonable price. The Varient 3's offer independent adjustment of both rebound , compression and ride height. The front dampeners utilizes a linear spring and helper spring while the rear uses a single progressive spring at each corner.
KW Variant 3 coilovers for 2004-2007 STI 1995.00
__________________
Ryan
Fine Line Imports
Become a fan of FLI on facebook at
Fine Line Imports is offline   Reply With Quote
Old 08-12-2008, 01:49 PM   #2
Fine Line Imports
Member#: 81166
2008 Forester
Tuesday bump
Ryan
__________________
Ryan
Fine Line Imports
Old 08-18-2008, 12:58 PM   #3
Fine Line Imports
Member#: 81166
2008 Forester
Monday bump
__________________
Ryan
Fine Line Imports
Old 09-02-2008, 01:05 PM   #4
Fine Line Imports
Member#: 81166
2008 Forester
Tuesday bump
__________________
Ryan
Fine Line Imports
DMS camber plates and MSI lateral links top quality suspension parts for your WRX/STI Fine Line Imports Suspension/Brakes/Handling 3 05-14-2009 02:21 PM
New and Used suspension parts for your WRX/STI Fine Line Imports Suspension/Brakes/Handling 2 03-01-2009 11:50 PM
WTT: My STi carpet and door cards for your WRX carpet and door cards! IrishSti Private 'Wanted' Classifieds 6 09-27-2006 06:37 PM
Center console and armrest for your WRX/STi. Removed from a 2004 WRX jcu1276 Private 'For Sale' Classifieds 51 06-19-2006 08:59 PM
FS and WTT my Seibon Cw style hood or stock rs hood for your WRX/STi hood rsracer2005 Private 'For Sale' Classifieds 7 06-18-2005 12:36 PM
