Old 08-05-2008, 04:26 PM   #1
auslyle
Member#: 129737
04 Sweet Impreza
Default is 230 whp NA to much to ask for??
so I've been doing a lot or research and have came to the conclusion that if VW's can do it why cant we??
TechWorks Engineering (Calgary, Alberta, Canada) clames that there normally aspirated Subaru 2.5L Flat-4 makes a wapping 300 HP (235 WHP at 6450 RPM and 209 WTQ at 4600 RPM)...we typically see 233 WHP for a WRX STi, which is rated at 300 HP. if so I could have a NA that is a stock sti killer and also would be incredible in the auto-x
using 11.2:1 CR forged pistons, Stage II SOHC Street cams and headwork, complete built bottom end
whats everyones opinions?
auslyle is offline   Reply With Quote
Old 08-05-2008, 04:56 PM   #2
Chocoholic005
Member#: 179736
2005 Legacy GT
RBP
Its doable.
Chocoholic005 is offline   Reply With Quote
Old 08-05-2008, 05:20 PM   #3
auslyle
Member#: 129737
04 Sweet Impreza
I need it!
Old 08-05-2008, 05:21 PM   #4
Chocoholic005
Member#: 179736
2005 Legacy GT
RBP
Is it really a need? Or just a want?
Old 08-05-2008, 05:24 PM   #5
auslyle
Member#: 129737
04 Sweet Impreza
it's a need! no one believes it can be done around here
Old 08-05-2008, 05:55 PM   #6
Chocoholic005
Member#: 179736
2005 Legacy GT
RBP
I believe it can be done, its been done before.
Old 08-06-2008, 02:52 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
There are plenty of us that believe it can be done, but very few of us who have the money to blow on a race motor. (Which is exactly what you would end up with.)
Patrick Olsen is online now   Reply With Quote
Old 08-06-2008, 01:19 PM   #8
atech_rallyrs
Member#: 116638
00 impreza naSTi
el typico silver
Be real careful that if you decide to do this, you go to a reputable engine builder.
atech_rallyrs is offline   Reply With Quote
Old 08-06-2008, 04:43 PM   #9
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
it can be done..stand alone, built heads to rev high and maybe race gas
if u want high NA hp go honda and take off everything on your car until it weighs nothing, lols
mxpunk is offline   Reply With Quote
Old 08-06-2008, 05:47 PM   #10
aaron04
Member#: 146569
2009 A4
you can save a lot of money and just buy a turbo lol
aaron04 is offline   Reply With Quote
Old 08-06-2008, 06:03 PM   #11
Chi_San
Member#: 53558
2002 WRX Wagon
You'll need a 2.8 liter stroked motor, with good heads, good intake, and good exhaust to make that much power NA. You're talking a race built motor, it'll probably end up costing about $12k. Then, you have to realize, you're just hitting STi stock territory... Then you will have to worry about your transmission, axles, brakes, etc. You could blow another $10k on transmission upgrades, and that puts you into used 2004 STi territory.
Do it if you really want to, but you'll probably need more than the following list of parts:
17" wheels
STi hubs, axles, brakes
STi transmission, rear diff, hydraulics, shifter, linkage, mounts
STi suspension
STi Shortblock overbored and sleeved
Stroker crank
Forged pistons (11:1 or higher) and connecting rods
TWE 2.5" exhaust, block to muffler tip
Fancy DOHC heads
Race cams
upgraded valvetrain, including valves, springs, bucket under shim conversion, etc.
Fancy intake
Fuel injectors, rails, and pump
Then you'll have to think about tuning. There are many options, but with a 2.5" exhaust, stage III cams, and a higher CR, you're going to need at least to shift your power band up, probably having a rev limit at 8,500 rpm. You'll need EM flexible enough to allow you to custom tune your entire setup.
That's a huge list just to get you reliably to 300 CHP. Good luck.
Alternatively, you could spend $1200 on a used STi shortblock, $2000-$3000 on heads, $100 on an XMember, $100 on a FSB, and however much an UP, turbo, and DP costs, $1500 on EM, and have a 300 CHP turbo subie. The powerband isn't INSANE like a 300 CHP NA beast, but it's better than 165 CHP.
Chi_San is offline   Reply With Quote
Old 08-06-2008, 06:16 PM   #12
Chocoholic005
Member#: 179736
2005 Legacy GT
RBP
You guys should stop always trying to talk someone out of it with money, maybe he doesnt care, maybe he wants to be unique. If he's ever gonna actually do this, he'll do research, and find out how much it costs.
Old 08-06-2008, 07:14 PM   #13
simple monkey
Member#: 81067
1989 RX, FX16
both white
Originally Posted by mxpunk View Post
if u want high NA hp go honda.
+12345
why not stick with what subaru is good at; turbo motors.
simple monkey is offline   Reply With Quote
Old 08-06-2008, 09:52 PM   #14
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
A 300chp turbo has a way better powerband than a 300chp small displacement NA
Splinter is offline   Reply With Quote
Old 08-07-2008, 10:39 AM   #15
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
To make high horsepower on a N/A motor, you only need 3 things.
1) high compression
2) big cams
3) high RPM
Obviously, you can't have a restrictive intake or exhaust. This is a case where I would go with a billet crank and titanium rods and spin it to 9,000+ rpm. I'd probably use adapters to fit ITB's as well.
As for needing $10,000 for drivetrain mods for a 300hp motor, that's just silly. MFactory gears would probably be a good match for the powerband, though.
bluescoobywagon is offline   Reply With Quote
Old 08-07-2008, 01:04 PM   #16
WRBEJ257
Member#: 185764
06 大集
青い
If power is all your looking for then yeah its do-able but Id also suggest wieght reduction to get a better track time and quarter mile
WRBEJ257 is offline   Reply With Quote
Old 08-07-2008, 01:43 PM   #17
auslyle
Member#: 129737
04 Sweet Impreza
Ok first off there is no price on labor since my buddy and i can manage that part, everyone thinks it's impossible to crack open a case and get building... second is im not worried on price, and its not a daily driver and its going into a fully striped GC8... my daily driver is my wagon that is getting a complete sti swap with a 18G on meth... but anyways I have cases laying around my house and why not play around with them? make some crazy numbers with a NA put it in a GC8 shell and tell people you just got smoked by an NA!!! that sounds like fun to me... turbos are fun but everyones got one and what determines your sti is faster than the others is how big you turbo is. so the build is starting soon, two swaps at once is going to be fun... and again my house is going to look like a chop shop...
Old 08-07-2008, 02:01 PM   #18
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'd beg to differ in a huge way.... NA will have a much flatter tq curve unless you progressively increase boost pressure.
Case and point Vern's (at All Aspects and awesome!!) NA project...
new sti 2.5 short block
all parts are thru twe
wiesco 12.1
stage 3 cams springs and such
4-2-1 twe race header
hydra management
also...
05 NA intake manifold, powersteering and AC delete but am not sure it that was for this graph...?
Needs a bigger cam, more headwork and rpm to make 230 though
It can be done and I'm not sure that a 2.8L ginormous engine would be the ticket as isn't going to breath all too well at 8500rpm nor be very happy with harmonics...
I'll take a 2.4L at 9500rpm over 2.8L at 7500rpm all day
I'd do a 2.55 or my long rod 2.4L with STi heads, custom cams and a well designed/sized intake manifold to make high rpm NA power.
A NA subie is something I've wanted to do for a while...but bigger power got me first
Maybe once I move onto my next shortblock I'll get some high CR pistons for my current block and give it a whirl.
I need more time and spending money
Old 08-07-2008, 02:26 PM   #19
bluescoobywagon
Member#: 14911
Not A Wagon!
Old 08-07-2008, 03:11 PM   #20
Chi_San
Member#: 53558
2002 WRX Wagon
I don't remember if it was TWE, COBB, or another company, but 300 chp on a 2.8 makes roughly 280 chp at 2,000 rpm, and just under 290 ctq at the same RPM. The two lines go up slightly, then start dropping around 8,000 rpm. A 300 chp turbo motor of the same displacement will make significantly less hp and torque at 2,000 rpm.
Old 08-07-2008, 03:23 PM   #21
Homemade WRX
Member#: 33782
96 bastard child
that's mathematically not possible (that whole crossing at 5252 rpm thing)...but I think you are thinking of zzyzx's auto-x car anyhow
Old 08-07-2008, 04:43 PM   #22
Badazzcr
Member#: 67693
4 Making them
faster then anyone else.
wait... turbo cars can have good tq curves and make power too.
Good luck with your NA project, its a really cool idea. But in the end I think you will have a ton of money invested in it and still not be happy.
Badazzcr is offline   Reply With Quote
Old 08-07-2008, 07:07 PM   #23
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
if you got the time and $$..why not go h6???
Old 08-07-2008, 07:45 PM   #24
Homemade WRX
Member#: 33782
96 bastard child
Yes doug, I know they can but about 99% of NA cars will have a better torque curve than turbo set ups and you know that
Old 08-08-2008, 12:07 AM   #25
Creighton
Member#: 185058
I hate to add on to a thread with something not completely relevant, but this is the the closest thread to what I was looking for i could find with the search. . .That being said, how much power/rpm do you think a stock EJ25 SOHC (EJ251) block crank and rods could handle with the 11.2:1 CR pistons? how about the STI stock block crank and rods? would the CR make a difference other than having to handle the increased power?
hopefully this is not too off topic
Creighton is offline   Reply With Quote
Is it really to much to ask? version2.0a Off-Topic 15 05-14-2006 10:42 PM
Is $670 to much to pay for the 4pot brake kit booSTIes! Private 'Wanted' Classifieds 5 04-23-2006 09:33 PM
Is $560 to much to pay? Reddstars Texas Impreza Club Forum -- TXIC 55 12-15-2004 11:13 PM
Is $27,000 to much to pay? CatchMyDrift General Community 71 05-20-2004 07:06 AM
Motor dilema, is this to much to spend for an STi? KKoepp31 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-28-2004 02:28 AM
