Old 08-05-2008, 05:13 PM   #1
toutanje
Member#: 153465
2004 Suzuki GSXR 600
WRX now FS!
Default oil through inlet into turbo?
I was pulling my motor and when i was taking everything off there was a lot of oil throughout the intake path from a cracked ring land I had.
Well my question is oil came into the turbo inlet and was being sucked through the turbo and was curious if this does any damage to it or not?
toutanje is offline   Reply With Quote
Old 08-05-2008, 05:34 PM   #2
s42k1
Member#: 95702
The cracked rind land is the reason that there is oil on the compressor side of your turbo. You were experiencing blow-by in the cylinder which was pressurizing your crankcase and then pressurizing the center housing of your turbo via the oil drain tube. The oil that escaped and traveled across the compressor wheel will not destroy your turbo. I wouldn't worry about it, just get your motor fixed and you should be alright.
s42k1 is offline   Reply With Quote
Seafoam into turbo inlet hose? 05wrx09 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 05-13-2009 03:22 PM
Perrin Rotated intake kit for 4" turbo inlet, GT turbo oil and water lines ovrated Engine/Power/Exhaust 7 12-19-2007 01:16 AM
Oil Catch Can with Turbo inlet Tube? Robstunner Built Motor Discussion 1 04-22-2007 11:15 PM
WTB: Perrin oil catch can and turbo inlet hose (red) mightbewrx Private 'Wanted' Classifieds 2 02-23-2004 02:49 PM
blowing oil through a turbo? milkman Normally Aspirated with bolt-on Forced Induction Powertrain 20 06-25-2002 06:29 PM
