Old 03-09-2002, 09:02 PM   #1
RichinAZ
Member#: 8376
2002 WRX Sedan
Sedona Red Pearl
Default Do these EGT's sound right- Compare
Thought it would be good to compare some relative EGTs to see if what are normal:
Probe Placement: manifold 5 inches from Cyl. 3
800-900F - nomal idle
1300-1400F - highway cruise at 75mph, 3000rpm
1500F - WOT
Mods: Cobb RT spec and Perrin up-pipe.
RichinAZ is offline   Reply With Quote
Old 03-09-2002, 09:08 PM   #2
WizardBlackWRX
Member#: 14979
I think that sounds pretty normal and safe. I cannot say exactly with your particular setup, but you seem to be pretty good. I am converting from Farenheit to Celcius so I can actually think about the numbers.
WizardBlackWRX is offline   Reply With Quote
Old 03-09-2002, 09:22 PM   #3
TurboRex
Member#: 8635
04 STI, 07 FXT
I have a vdo gauge and the probe is on the driver's side 5 inches out. I get about 750F idle, 1300-1350 cruise, and 1350 wot. My numbers are lower than most I think. Maybe due to the uppipe and 3" exhaust and injen intake, not sure. Maybe my gauge just reads lower.
Greg
TurboRex is offline   Reply With Quote
Old 03-10-2002, 01:16 AM   #4
RichinAZ
Member#: 8376
2002 WRX Sedan
Sedona Red Pearl
anyone else, what are your readings???
Old 03-10-2002, 01:19 AM   #5
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Not to hijack your thread but I don;t recall you ever posting in the Southwest forum. You should come on over and say hi to us fellow Phoenix folks if you haven;t
Eric
Eric SS is offline   Reply With Quote
Old 03-10-2002, 01:28 AM   #6
RichinAZ
Member#: 8376
2002 WRX Sedan
Sedona Red Pearl
Eric,
I was over at Vivid today and will be at Firebird tomorrow. Hope to see you there.
Old 03-10-2002, 01:34 AM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Eric,
Gottcha. Sorry. I forgot about the Vivid meet accidently.
Eric
Old 03-10-2002, 08:48 AM   #8
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
"vdo gauge and the probe" -> I think this is the setup that my brother used in his turbo RS for a while, and the thing always read funny/low (if you are using the vdo probe also). It never seemed right, and don't you know when the probe died he switched to a Westach probe and Autometer gauge, and his readings are much more as to be expected.
Have read of DSM guys with inaccurate readings with the vdo egt stuff (I think it's mainly the probe that vdo uses). Whenever the probe dies, try using a Westach (they are inexpensive anyway) and see if your readings are the same.
Kev
Force[FED] is offline   Reply With Quote
Old 03-10-2002, 09:51 AM   #9
TurboRex
Member#: 8635
04 STI, 07 FXT
Thanks for the tip Kev. It seems very consistent at cruise but idle can vary widely. WOT hardly goes up but either the probe is slow to respond or I am just very rich. I think it is a little of both.
Greg
Old 03-10-2002, 02:33 PM   #10
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
No problem. I do rememer Steve saying how slow is EGT was to respond (especially noticeable once he switched to the new Westach probe).
I just installed my Greddy EGT probe yesterday. Placed it about 3 inches from cylinder #3 exhaust port. Didn't romp on it with the wife in the car (the mkiii is a little much for her), but was seeing ~750C(1392F) at 60mph cruise. Never saw it break 800C(1472F) even when accelerating briskly.
For those playing along at home, conversion is F = (C*1.8)+32 pretty easy to remember.
Kevin
www.forcefed4.com
PS The Greddy probes are fantastic, very quick to respond, and last pretty long. Of course, they are not the cheapest either.
Old 03-10-2002, 04:25 PM   #11
RichinAZ
Member#: 8376
2002 WRX Sedan
Sedona Red Pearl
Default What about at idle
ForceFed,
Numbers sound pretty similar to mine. What are you reading at a normal idle? I just freakin on this since I am getting a code P171 System Lean CEL.
I think could just be the cold air intake, but ??
Do these symptoms sound right? generalee69 Motorsports 49 08-21-2009 01:24 PM
How do these numbers sound? scooby24 Proven Power Bragging 2 02-09-2005 11:22 PM
How do these mods sound? ScoobyEnthused Newbies & FAQs 12 05-30-2002 09:05 PM
Do these prices sound right? Aaron Silidker Transmission (AT/MT) & Driveline 6 12-06-2001 01:02 PM
