Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 08-05-2008, 06:59 PM   #1
frayz
Member#: 106909
2002 V7 STi Prodrive
Edition... Black!
Default Help frayz with his build please. (Few questions for the pro's)
Hey guys.
A few questions
As some of you may know, im building a new motor for my bugeye. Im swapping out my 2ltr for a forged 2.5 that im building myself.
I'll be using my 2ltr heads, but before i fit them i will be having the combustion chambers modified to fit the 2.5's 99.5mm bore.
What i want to know is, what will i gain more from? Head porting or cams?
How much extra power will porting add to stock heads if nothing else is changed?
If i decide on cams will the Brian Crower BC0621 kit work in my 2ltr heads and will my AVCS still opperate correctly?
What sort of power can i expect from this setup and what other mods will net me the most gains?
As some of you know. Im from the UK and parts here are ridiculously expensive, so anyone that can help me out by shipping me some parts would also be greatly appreciated.
I will be using the following parts.
New EJ257 block
New EJ257 sti crank
Wiseco pistons
Piston rings
Carrillo rods
ACL big end bearings
ACL main bearings
OEM head gaskets
ARP 11mm head stud kit
RCM oil pump
New oem water pump
PE kevlar timing belt
NGK racing 8s
Phenolic spacers
Machined 2ltr STI heads with AVCS
JDM Spec C inlet manifold
Ceramic coated GTSpec Gen 2 headers
800cc injectors
Hyperflow top mounted Oil cooler
Turbocharger exhaust housing (8cm for my FP green)
Exedy hyper Compe-R twin plate clutch, billet lightened f/wheel
Breather/Oil separator
Converted an fuel rails
Parallel fuel system, hose fittings etc
Fuelab fuel filter
Cheers for reading, i hope you can answer my questions
frayz is offline   Reply With Quote
Old 08-06-2008, 11:59 AM   #2
frayz
Member#: 106909
Edition... Black!
Nobody?
Old 08-06-2008, 02:28 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
which version STi version heads do you have (big port v7 spec C or just the normal version 7)?
what parts do you already have and what do you need shipped?
Old 08-06-2008, 04:08 PM   #4
frayz
Member#: 106909
Edition... Black!
Normal small port V7 heads mate.
I have everything that i have currently listed.
However im wanting cams and springs/retainers. Valves too at a good price but i think at my level the stock valves will cope okay.
What are your thoughts buddy?
Old 08-06-2008, 05:13 PM   #5
Homemade WRX
Member#: 33782
96 bastard child
I know the JDM heads use different sensors to pick up the cam position and can't recall off hand if they'll work (I still haven't played with JDM heads). Just to let you know, those cams are sold out as well.
I'd get cams and valves (address the seat throat too) before cams and port work...
I wouldn't open up the combustion chamber. Maybe do some deshrouding but I wouldn't bowl it out.
What kind of power are you trying to make? what turbo will you be running? You don't need port work unless you want some seriously big power, at which point I'd hope to see sleeves in the build
Old 08-06-2008, 05:17 PM   #6
frayz
Member#: 106909
Edition... Black!
I know the JDM heads use different sensors to pick up the cam position and can't recall off hand if they'll work. Just to let you know, those cams are sold out as well.
Gonna be on an 8cm 3" FP green minimum.
Maximum of GT30 mate.
I meant de-shroud, not bowl out. Sorry.
Whats wrong with the seat throat as they are dude?
Old 08-06-2008, 05:17 PM   #7
frayz
Member#: 106909
Edition... Black!
Looking for a solid 450/450 at least
Old 08-06-2008, 05:22 PM   #8
Homemade WRX
Member#: 33782
96 bastard child
that'll be PLENTY of head work for a 450/450...30R it though. The 2.5 will spool the green to fast to be happy supplying air for 450...unless its a high reading dyno
Old 08-06-2008, 05:50 PM   #9
frayz
Member#: 106909
Edition... Black!
Id do a GT30 in an instant mate however i have a problem
They only guys that make the rotated up/downpipes for RHD are RCM. They charge $1700 for them without a turbo or wastgate.
If i could get some from the states to fit id be okay but as yet, i cant afford to do it
Old 08-07-2008, 11:53 AM   #10
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Why not do a stock mount GT30?
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
That turbo is a GT30R with a custom turbine housing that is modelled after the garret housing. I'm suprised you don't want to buy from the states as the the US dollar is worthless over there...
bluescoobywagon is offline   Reply With Quote
Old 08-07-2008, 12:06 PM   #11
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
RCM is some of the best stuff on the market, 850 - 1000 is what they run over here for just the pipes. The company that did you Exhaust could make you some, they seem very capable!
Token-Negro is offline   Reply With Quote
Old 08-07-2008, 01:23 PM   #12
frayz
Member#: 106909
Edition... Black!
I do want to buy from the US dude, but you have LHD, i need RHD pipes for a rotated mount.
Will that hybrid perform the same a a genuine GT30?
Old 08-07-2008, 01:24 PM   #13
frayz
Member#: 106909
Edition... Black!
$800-$1000 USD dude,
Im taking 800- 1000 GBP!!! thats like $2000!!!!!!!! just for the pipes!!
Old 08-07-2008, 01:46 PM   #14
Homemade WRX
Member#: 33782
96 bastard child
you beat me to it with the drop in 30R...
Frayz, it is completely bolt in and works with factory (or any other oem placed) uppipe and downpipe...as for the power limit because of the sizing, I'm not sure and have never run one.
Old 08-07-2008, 05:21 PM   #15
frayz
Member#: 106909
Edition... Black!
Is it actualy going to offer me much more than an 3"/8cm green?
Old 08-07-2008, 07:52 PM   #16
modaddict
Member#: 95840
sold to a good bud
awaiting next car
49lb/min vs. 52lb/min
i would take the garrett anyday. But it really depends if you want more later, powerband, etc.
both are a fun turbo. I vote go for more
modaddict is offline   Reply With Quote
Old 08-07-2008, 07:55 PM   #17
frayz
Member#: 106909
Edition... Black!
Okay so the turbo is now under question... but back to my original questions guys....
Cheers guys
Old 08-07-2008, 10:58 PM   #18
2006whitesti
Member#: 124311
2006 STi, 03WRX wago
10Tribeca,00 RS,99 Foz
Mark Remmick is making close to 9xx whp with stock heads. IE no porting. After talking with him, I think I am just going to go with cams for now, and maybe by a set of spare heads for later when I have the extra cash to have them worked. This way I can get a direct comparison.
Dustin
2006whitesti is offline   Reply With Quote
Old 08-08-2008, 04:10 AM   #19
bluescoobywagon
Member#: 14911
Not A Wagon!
With cams, you add flow by opening the valves more/longer. With porting, you add flow at the existing lift/duration. Cams will add more power than porting alone because the longer duration gives the cylinders more time to pump. They also shift the powerband much more than porting alone would.
I can't answer whether or not the BC 272 cams will fit the 207, but assuming they do and based on dyno graphs I've seen, they should shift the powerband to the right 500-800 rpm and add 40hp or so.
Old 08-08-2008, 06:05 AM   #20
frayz
Member#: 106909
Edition... Black!
Thanks man, great response
So if the cams may add 40hp, any idea what porting might add on a stock motor for example?
Old 08-08-2008, 09:28 AM   #21
bertune
Member#: 107290
I would say cams over porting, cosworth and kelford does cams for the jdm avcs. Call kelford, very knowledgeable person! Ever thought of using the red instead of the green, that should give you what you are looking for and more.
bertune is offline   Reply With Quote
Old 08-08-2008, 09:58 AM   #22
bluescoobywagon
Member#: 14911
Not A Wagon!
This is tough to answer. It'll depend on the level of porting and the motor combo. It'll also depend on the turbo and boost levels as larger turbos will respond to cams and porting much more than smaller turbos will. Cams that give 40 hp on a GT30R may give 70hp on a GT40R.
Since yours is a hybrid build, you would be porting in an effort to get the 2.0 heads to flow enough air for the 2.5 motor. The cams are the main limiting factor there as you end up with a 2.5 STI motor with smaller than stock cams. Extensive port work on a flow bench could get you close to 40 hp. If you threw in larger valves you could probably exceed that. If I had to choose one or the other based on budget and time, I'd go with the cams. The fact that I can do my own port work means that I went with both plus .5mm oversized valves in my build.
Old 08-09-2008, 05:55 AM   #23
frayz
Member#: 106909
Edition... Black!
Any other input on wether the Brian Crower 2.5 ltr AVCS cams will work in my 2ltr AVCS heads?
Old 08-09-2008, 08:21 AM   #24
bertune
Member#: 107290
The cam sensor pickups are in a different location. Why don't u call them and maybe speak to Brian himself.
Old 08-09-2008, 10:09 AM   #25
bluescoobywagon
Member#: 14911
Not A Wagon!
Would this fix that?
http://www.horsepowerfreaks.com/part...e_Sensor/12196
A few questions for the IT folk out there... RyantheWalker Off-Topic 10 04-13-2005 07:29 PM
Picked up an impreza. few questions for the gurus. lyrikz Impreza Forum 2 09-01-2004 08:06 PM
A few questions for the people with fmic's dubba you are ex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-28-2004 05:27 PM
Few Questions for the WRX drivers AdmireWantWillLove Newbies & FAQs 26 04-24-2003 07:44 PM
Just got my Toyo T1-s...a few questions for the tire experts Edvig Brakes, Steering & Suspension 6 08-11-2002 02:57 PM
