Old 08-05-2008, 08:18 PM   #1
ahendrickson
Member#: 164625
2007 WRX Wagon 20g
External Wastegate
Default Quick Help! Fuel pump
I am installing my 255 fuel pump on my 2007 wrx. I got the assembely out and everything, but there is a big black thing that looks like a fuel pressure regulator or something in the way. I can take the old pump out, but when I try to put the Walbro in, it does not fit. I checked all the install guides, but none of them deal with a 2007.
ahendrickson is offline   Reply With Quote
Old 08-05-2008, 08:32 PM   #2
ahendrickson
Member#: 164625
2007 WRX Wagon 20g
External Wastegate
need help
Old 08-05-2008, 08:50 PM   #3
jma_1000
Member#: 151694
i recall having to fight that pump back onto the assembly. but now i cannot recall what the issue was. are you aligning that little rubber keeper correctly?
jma_1000 is offline   Reply With Quote
Old 08-06-2008, 01:28 AM   #4
k mier
Member#: 98000
05 sti [email protected]
Float for the fuel level gauge?
k mier is offline   Reply With Quote
Old 08-06-2008, 02:41 AM   #5
WRXislander
Member#: 50064
'02 WRX
MBP
use vice grips and bend the bracket.
WRXislander is offline   Reply With Quote
Old 08-06-2008, 02:49 AM   #6
Nuke209
Member#: 108089
2003 WRX
NF Performance
2005+ have the fuel filter inside the fuel assembly
So you would have to cut off the end of the fuel filter nipple (that connects to the fuel pump) so the walboro will fit in (also use fuel hose clamps)
My friends and I have done this to our cars.
BTW, don't cut off too much, measure it first so u can tell
Nuke209 is offline   Reply With Quote
Old 08-06-2008, 11:08 AM   #7
GeoffM
Member#: 30252
2005 996GT3,'16 3500
04 Ducati 749R #249
PS don't let the small hex bolts lay anywhere you can kick or knock in the tank..........
IBWENTFISHINGFORHEXBOLTSINAFULLTANKOFFUELPASTMYELB OW
GeoffM is offline   Reply With Quote
Old 08-06-2008, 12:23 PM   #8
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
the only thing you have to cut here is the tube connecting the pump and the filter. cut it down so it will fit between them, put both bases in the assembly so that where they connect is angled up, and push them down until they are back in place. no wierd modification is needed to fit that pump on the 06-07 bracket.
The Satch is offline   Reply With Quote
Old 08-06-2008, 05:09 PM   #9
WRXislander
Member#: 50064
'02 WRX
MBP
Old 08-06-2008, 06:33 PM   #10
bigpinoy4ya2001
Member#: 147320
2007 wrx tr
black
+1.....i installed my pump yesterday with my 07 wrx and thats the problem that took me long is the fitting of the pump...i did the exact same way as you said no special modding needed..cut the tube to the size that fits push it in and your good to go...took me an hour to figure this out
bigpinoy4ya2001 is offline   Reply With Quote
Old 08-06-2008, 07:04 PM   #11
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
v8eaterWRX is offline   Reply With Quote
Old 08-06-2008, 09:15 PM   #12
Miercoles Cansado
Member#: 166820
my ignore list
I just went through this a couple weeks ago. You'll have to cut down the tube that connects the pump to the other part and actually butt the two ends together. Mount the the pump first and then pull back on the barcket until the two ends meet. Got mine done and it works fine.
Miercoles Cansado is offline   Reply With Quote
Please help...fuel pump not working SnowWhiteWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 02-04-2007 05:38 PM
Help, fuel pump install problem Mildmanneredman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 09-29-2004 08:26 PM
quick question. Fuel pump ass. stuck joehack98 Subaru Conversions 2 01-25-2004 09:00 PM
Need help, fuel pump gave up Farabomb Tri-State Area Forum 6 12-09-2003 08:09 PM
quick fuel pump help. not much time STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-06-2002 12:46 PM
