Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 08-05-2008, 09:39 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default VF48/VF46 Turbos in Stock-Greddy TI-C Open Box $499-Gruppe-S Manifold Free Up-Pipe
VF48 Turbosin stock! Dont miss out on these guys. Perfect upgrade for the 04-07 STi. With gains of up to 320+hp. Limited number of turbos available in stock. Also now available the VF46 Legacy Spec.b Turbo! Perfect upgrade for 08+ WRX. Open box Greddy TI-C for sale only 1 left so dont miss out!
2008 STi IHI VF48 Turbo
320+ whp
The IHI VF48 comes stock on the 2008 STi. With Supporting Mods gains of 320 +whp can be easily acheived. With a larger compressor compared to the VF34 and more potential The VF48 is the new kid on the block.
***Will Not Fit on 2008+ WRX Models***
VF48 Turbo (fits 02-07 WRX/ 04-08 STi)
$925 Shipped
VF48 Turbo/ Helix 820 Injectors/ Walbro Fuel Pump (fits 02-07 WRX/ 07-08 STi)
$1475 Shipped
VF48 Turbo/ Helix 860 Injectors/ Walbro Fuel Pump (fits 04-06 STi)
$1475 Shipped
2007 Legacy Spec.B IHI VF46 Turbo
'08 WRX Turbo Upgrade
The VF46 is the world's first 5-arc scroll turbo. This new design has been adopted for the turbocharger compressor. By adjusting the flow of compressor air and improving compression efficiency, low and midrange torque has been increased/improved. Perfect upgrade for the 08+ WRX and Legacy GT
***Will Not Fit on 2002-2007 WRX/ STi Models***
VF46 Turbo (fits 08+ WRX/ 04-08 Legacy)
$925 Shipped
$1475 Shipped
ATP GT3076 Turbo
Stock Location 500+whp
The Garrett GT Ball Bearing GT3076R, the benchmark 500+ HP capable dual ball bearing turbo, is now available in a drop-in package for the Subaru WRX/STI! The easy to implement turbo assembly that takes no more than 1-2 hours to install in place of the stock journal bearing VFXX unit is made possible by a high flowing GT inspired ATP exhaust housing and a series of custom engineered components built to suit the installation.
Each GT drop-in turbo package consists of a Garrett factory assembled and high speed balanced dual ball bearing CHRA which is then assembled into a set of CNC machine ported housings that have been optimized in every aspect for maximum flow and efficiency.
All accompanying oil and coolant supply components included in each kit have been designed to properly and seamlessly bridge the Garrett GT turbo to the EJ engine so that the fit is as OE as possible.
Just bolt the turbo on, add fueling and a good tune and prepare for a blast of acceleration. Garrett GT turbos offer more then just "peak HP" numbers. These GT turbos off more torque area under the curve and more "accessible" power then any other turbos series out there.
We do recommend that you compliment your GT bolt-on turbo with a nice high flowing bellmouth downpipe and a high flowing inlet pipe to effortless channel air in and out of the turbo. Although every bolt-on GT turbo ships with a 3" inlet, we do provide a "stepdown" sleeve just in case you're forced to use the stock 2.25" inlet hose. However, as a rule of thumb, turbos, especially higher flowing units love as much inlet flow as possible. This promotes both quicker spoolup and better ultimate HP, with less boost pressure at the manifold. The 3" downpipe and bigger inlet is critical for reaching peak efficiency on the GT turbo. Please also be aware that some downpipes such as the stock catted downpipe, has a "no-flow" door at the wastegate flapper area. This type of downpipe may not allow the wider swinging wastegate valve to open all the way, thus causing the possibility of a "boost-creep" condition or uncontrollable rise in boost.
The GT3076R is a great match for the 2.5L that still has great spoolup, especially if you're looking for boost threshold that is just a little later than stock but still want enough airflow for 500+HP. The GT3076R makes boost about 300 to 400 rpms later than the GT3071R but keeps pumping where the GT3071R starts to run out after 450HP. A lot of the boost is available even at part to medium throttle. Dual ball bearings means boost recovery between gearshifts is awesome with full boost ready even before upshift is complete as the STI lurches forward with shear enthusiasm at the onse of each gear. The 2.0L driver should not rule out the use of the GT3076R if his HP target is in the same range. This competition grade turbo is still a big favorite for the HP range because it hits like a hammer while other 500HP turbos are still "spooling up".
GT3076 Turbo (fits 02-07 WRX/ 04-08 STi)
$1799 Shipped
GT3076 Turbo/ Helix 820 Injectors/ Walbro Fuel Pump (fits 02-07 WRX/ 07-08 STi)
$2350 Shipped
GT3076 Turbo/ Helix 860 Injectors/ Walbro Fuel Pump (fits 04-06 STi)
$2350 Shipped
Greedy TI-C Catback
Display Model 1 at this Price
1 At This Price
$499 Shipped
Helix Downpipes
In Stock Ready To Ship
Non-Catted DP
$225 Shipped
Catted DP
$349 Shipped
***Coming Soon Helix Downpipes for 2008 WRX/ STi***
Helix Turbo Back Exhaust
Performance Exhaust
Helix Non-Catted DP/HKS Hi-Power
$725 Shipped
Helix Catted DP/HKS Hi-Power
$825 Shipped
Helix Non-Catted DP/HKS HKS Carbon-Ti
$775 Shipped
Helix Catted DP/Greddy Ti-C
$949 Shipped
Helix Non- Catted DP/GReddy TI-C
$725 Shipped
Helix Non-Catted DP/Blitz NUR Spec
$725 Shipped
Helix Catted DP/Blitz NUR Spec
$849 Shipped
Quiet Exhaust Under (93db)
Helix Non-Catted DP/A'Pexi World Sport
$675 Shipped
Helix Catted DP/A'Pexi World Sport
$799 Shipped
Helix Non-Catted DP/Apexi WS NOIR
$699 Shipped
Helix Catted DP/Apexi WS NOIR
$825 Shipped
Helix Non-Catted DP/GReddy SP2
$975 Shipped
Helix Catted DP/GReddy SP2
$849 Shipped
Helix Non-Catted Dp/Tanabe Medalion Touring
$725 Shipped
Helix Catted Dp/Tanabe Medalion Touring
$849 Shipped
Gruppe-S Exhaust Manifold
Free Helix Up-Pipe
The Gruppe-S manifold is a 4 to 1 unequal length manifold. It will retain your boxer rumble and features T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. The 4-1 collector is cast to ensure the smoothest possible low rates. This header is dyno proven to make power; it will not lose power or torque in 2.5L applications anywhere in the RPM range. 2.0L motors will lose some low-end and mid- range power to gain more high-end power and torque. The more modified your vehicle is, the more pronounced the gains from these headers will be. The outside coating eliminates heat loss from the exhaust gasses (as compared to stock headers). Because warmer air travels more quickly and expands more quickly, this helps to spool the turbo more quickly
Constructed from T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. Dyno proven to make up to 8hp and 12 ft-lbs of torque. The design of the Gruppe-S equal length manifold increses boost response. Spool up time is decreased incresing boost pressure at lower RPM's. Due to the exhaust pulses now being paired together the lumpy boxer sound is lost instead a smoother sound is produced.
****2.0L Engines Require 2.5L Oil Pan For Manifold Clearance****
Un-Equal Length
***Free Helix Up-Pipe***
$425 Shipped
Equal Length
$649 Shipped
BC Cams
Free Gruppe-S Lightweight Crank Pulley
After months of testing the BC camshafts are finally available.
Stage 2 (272)-Street/Strip Specification
Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM springs OK.
Stage 3 (280)- Race Specification
Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires spring kit.
WRX 272
WRX 280
STi 272
STi 280
PM For Best Price Anywhere. All competitors Prices Beat! Guaranteed! (price match must be from an authorized BC distributor)
Dont Forget to Add
BC Valvetrain Components
Brian Crower Spring/Retainer Kit
$225 Shipped
Brian Crower Intake/Exhaust Valves
$249 Shipped
Looking for a complete BC Drivetrain Combo?
__________________
Thanks,
Gruppe-S
Please Note:
- All Competitors Prices Beat
- All Items Are Shipped Via FEDEX
- All Orders Are Repackaged To Help Prevent Any Damage Which May Occur During Transit
- Any Order Cancellation Will Result In A 25% Processing Fee
- Local Pick-Ups Available
- No Cancellation on JDM Or Special Orders. No Exceptions!
Gruppe-S is offline
Old 08-05-2008, 09:41 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Spearco TMIC
Save $$$ Over Brand New
Brand New Display Units no Damage At All
WRX/ STi $725 Shipped
Gruppe-S Pulley Combo
Save 5.4 lbs. Of Rotating Mass
AEM Alternator Pulley
AEM Alternator Belt
$125 Shipped
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-05-2008, 11:07 PM   #3
Wild999
Member#: 120112
06' STi
Any luck with the moroso sump from the old thread??
Wild999 is offline
Old 08-06-2008, 03:05 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
I never got a PN from you
Thanks
Ben
Gruppe-S
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-07-2008, 02:11 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-08-2008, 07:29 AM   #6
gleinz
Member Sales Rating: (24)
Member#: 17541
2007 STi Ltd #320
Helix DP's have a wideband o2 bung? Also will it come with gaskets?
gleinz is offline
Old 08-08-2008, 01:46 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Yes they do have an 02 bung for wideband and they also come with gaskest.
Thanks
Ben
Gruppe-S
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-08-2008, 03:36 PM   #8
dye.sti
Member Sales Rating: (11)
Member#: 136297
2012 WRX
OBP w/ Red and Flat Black
Default Helix Catted DP
PMed you
dye.sti is offline
Old 08-10-2008, 07:51 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Originally Posted by dye.sti View Post
PMed you
PM replied
Thanks
Ben
Gruppe-S
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-10-2008, 10:05 PM   #10
JDMWREX
Member Sales Rating: (1)
Member#: 121445
1994 JDM RHD WRX
Default ti-c catback
Hi
do u still have the catback?
let me know
JDMWREX is offline
Old 08-11-2008, 12:52 AM   #11
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Originally Posted by JDMWREX View Post
Hi
let me know
Yes the item in still in stock.
Thanks
Ben
Gruppe-S
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-11-2008, 02:33 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-12-2008, 03:48 PM   #13
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-13-2008, 01:47 PM   #14
ljaviation
Member Sales Rating: (18)
Member#: 42270
2003 A&P IA
ww.flyingleafaviation.com
pm'd about header and overnight shipping for today
ljaviation is offline
Old 08-13-2008, 02:25 PM   #15
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Overnight Shipping will be aprox $125 for next day in the 48 states.
Thanks
Ben
Gruppe-S
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-13-2008, 03:13 PM   #16
ljaviation
Member#: 42270
2003 A&P IA
thank you
L J
Old 08-13-2008, 05:05 PM   #17
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
thank you
L J
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-14-2008, 01:34 PM   #18
spooledwrx
Member Sales Rating: (3)
Member#: 73611
Sent you a PM
spooledwrx is offline
Old 08-14-2008, 02:20 PM   #19
ljaviation
Member#: 42270
2003 A&P IA
Parts just came in as promised.
Thanks.
L J
Old 08-14-2008, 02:55 PM   #20
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Thanks.
L J
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-15-2008, 01:39 PM   #21
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-18-2008, 03:43 PM   #22
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-19-2008, 06:51 PM   #23
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-20-2008, 01:40 PM   #24
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Old 08-21-2008, 02:35 PM   #25
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Please Note:
Gruppe-S is offline
Closed Thread
VF34/VF22 In Stock-Equal Length Manifold Free Up-Pipe-Cheap Turbo Backs Gruppe-S Engine/Power/Exhaust 32 03-20-2008 09:23 PM
Accesports in Stock-Gruppe-S Manifolds Free Up-Pipe-Helix Downpiper $199 Gruppe-S Engine/Power/Exhaust 15 02-28-2008 07:46 PM
Accesports in Stock-Gruppe-S Manifolds Free Up-Pipe-Helix Downpipe $199 Gruppe-S Engine/Power/Exhaust 2 02-20-2008 08:58 PM
Gruppe-S Equal Length Manifold-Free Up-Pipe-Engine Rebuild $899-All Helix On Sale! Gruppe-S Engine/Power/Exhaust 46 02-20-2008 08:07 PM
1 Day Sale Helix Downpipes $175- Gruppe-S Manifold $275-Up-Pipe $125- WRX Y Pipe $49 Gruppe-S SCIC Vendor Classifieds 8 01-28-2008 01:10 PM
Message Board Statistics All times are GMT -4. The time now is 09:32 PM.
